i install konica bizhub 350 to my network. scanning is going to SMB and very nice, but when i want to print from my PC, it did not print and also give no error.plz immediate help necessary. envoirment is workgroup hv XP.
Comments:
Aug 11, 2009
- thnx for the help. i will do that,but if any problem, so i will contact soon
Aug 12, 2009
- Dear HH
i want to re configure everything for the konica biz hub 350. please tell me how to reset it,after reset i want to install & configure for printing. i have CD. (our network is wireless through router and work group). plz tell me the steps in correct order to follow you.also tell me for to the installation of software, the machine i will connect with pc or router?.thnx in advance for ur kind cooperation and reply.Sabir
Aug 23, 2009
- Dear HH
thanks very much for ur valuable comments.. if any problem occur... i will contact u.. b happy always dear
Reinstall print driver to the PC using same ip address and print test print. next the same procedure go to web browser enter the ip address and choose administrator and the password 12345678. all your question will be in that area. scan, printing and network.
HH
Comments:
Aug 11, 2009
- We will be gladly to help you. I will help you till you solve the problem.
Aug 11, 2009
- please install the print driver and there is a CD that come with the machine or download to konica minolta web site.
Aug 22, 2009
- Hi Sabir, Your printer can be network in two ways. one is locally connected to a server or to the network hub/router. Even your network is wireless wired using ethernet patch cable it does not make no different. You may use the server CD Rom drive to install the driver for the printer. Just load the CD to the driver and the CD auto run it will look for the printer ip address and just follow what will be at the screen choose postscript driver, then have a test print before you complete the setup. Next go to you PC open an internet browser on the address bar type in the ip address of the konica printer and press enter. There is a public and Administrator, sometimes this will log you in to public you have to log out and log in to administrator the password is 12345678 press enter. Click network tab there you can refined and configure it. The next is how to scan. SMB, Scan to box, scan to ftp and scan to email. I will suggest the best is scan to email. all you and to know is what is the smtp ip address or host name. Sometime host name will not work so to know what is the ip address is go to run in your computer and type cmd press enter. type in ping and the host name of the smtp press enter and the ip address will show, write the ip address and input that to printer web browser. turn on the authentication enter administrator email address and the create valid email address for the printer/ scanner enter to printer /scanner email address. input the user id and the password and click apply. go to scanner input your email address and press scan and see if this will send it to your email address. All setting can be access to the printer/scanner web browser. hope this this info will help you setup your printer/ scanner problem.
Once in a while we have copies come out with one of the corners wrinkled and doubled over. Can you...
(More)
Once in a while we have copies come out with one of the corners wrinkled and doubled over. Can you provide a possible solution? Thanks, Mark
