Question about Singer Sewing Machines
Singer futura ce 150 carriage doesn't move when turned on design isn't sending
SOURCE:
SOURCE: Singer futura ce-200 problem, pattern mis-alignment
I have had similar problems in the past.
Do you hear a noise from the embroidery unit when the misalignment occurs ? If so, I suspect that your issue may be that you have some resistance under the hoop. Is there extra material that may be rubbing on the machine or catching somewhere. I have found that if I use some masking tape to keep all of the extra material from hitting any other parts of the machine or dragging under the edge of the hoop this error does not occur. FYI: I also stopped using the "optimize stitch speed" option at the same time. I believe that material dragging was causing the problem, but I still wonder about the stitch speed optimization feature.
Posted on Jul 20, 2008
SOURCE: please help
I have the CD, but have just posted a message about the driver not working in the install. So, if you want, I can try to send you a copy, but it's not sure it'll work...
Posted on Sep 16, 2008
  • 48 Answers
SOURCE: Singer FUTURA CE-250 beeping at startup.
To clean the lint is good to thread the machine with unwaxed floss. When it beeps what code does it shows at the panel?
Posted on Oct 17, 2009
SOURCE: Singer Futura 250 under XP - embroidery unit won't move
Could one of you send me a copy of the Futura installation software? I can't find mine and can't use my machine to embroider! Help!
Posted on Dec 10, 2009
  • 233 Answers
SOURCE: Will Mac run Singer® Futura
The software doesn't run on MAC. And you can't get a download directly off the internet, at least not anywhere that I've found. When I couldn't find my disk a few months ago all of my research told me that I had to purchase a replacement CD from Singer.
Posted on Apr 04, 2011
Why cant i install futura ce 150 softwRE with windows 10?
Singer Futura CE-150, I NEED HELP!!! - FreeEmbroideryStuff ...
freeembroiderystuff.embroiderydesigns.com/forums/threadView.aspx?id...
Jul 11, 2014 - 15 posts - ‎10 authors
I just got the Singer Futura CE-150 and every time I start a design it ... Posts: 2/10/2014 11:18:44 PM, RE: Singer Futura CE-150, I NEED ... Futura CE-100but didn't realize it didn't have its original install cd with ... I can't afford Singers price. ... -Software-Download-and-Installation_A287.aspx?id=287&siteid= ...
Singer futura ce-350 software download - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesJavaScript isn't enabled in your browser, so this file can't be opened. Enable and reload. ... Singer futura ce 150 embroidery machine 3900 designs dvd. Top 3 singer ... Singerfutura software for windows 10 memphis soft portal. Using my singer ... Singer futura software installation for windows 2000 xp youtube. Service ...
Singer Futura CE-250 Sewing and Embroidery Machine w
SINGER® FUTURA™ Software Installation for Windows ...? 7:20https://www.youtube.com/watch?v=RDkHyrh0ejkNov 30, 2009 - Uploaded by SingerSewingCompanySINGER® FUTURA™ Software Installation for Windows 2000 & XP ... yes i already have a singer ...Singer Futura will not work with Windows 7 - Microsoft Communityanswers.microsoft.com/.../singer-futura.../da1ea4db-8594-4a12-91d1-d8...I bought a Singer Futura sewing machine and a Win 7 laptop for Christmas. ... can find the right person at Singer to talk to they might let you have a pre-release version of thesoftware. ... What if you download the patch and it still doesn't work? ... if you are using ce-150 go to http://futura-support.com/downloads/ce150.html.
Dec 30, 2015 | Sewing Machines
I have a Futura Ce-150. Do I need special
List of supported by Futura software design formats could be found in the software manual or on futura-support site:
http://www.futura-support.com/futuraSw/embformats.htm
Feb 06, 2010 | Singer CE-100 Futura Computerized Sewing...
I have a Singer Futura CE-150 and it keeps stopping due to "Thread break error" but the thread and bobbin seem okay what could it be?
Either upper thread is not passing through thread sensor area or sensor is broken.
Second possible reason is that if design is not optimized the sporadic speed change provides thread breakage error even if the thread is not broken physically. Make sure your software is updated to optimize it automatically (Futura main menu->Help->Live Update).
Dec 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Design is ready, when green light is pressed nothing happens
I have had good luck contacting the Singer peoplee themselves. Sometimes it takes a couple of days for them to respond. But, if that doesn't help try this.
Can you go forward a few stitches annd then start?
If not, try condensing your design by 1-2%. This was recommended to me by Singer when I had part of a design that wouldn't stitch out. It did the same as your whole design. I tend to think it is the digitizer, not the machine in my instance. Have you tried another design by a different digitizer?
Hope this helps.
Jul 19, 2009 | Singer CE-100 Futura Computerized Sewing...
Futura ce-200 "parked" in wrong position.
I think you might have damaged the embroidary arm.
Contact these people for some advice.
Gezina sewing machine
(012) 335 0636
Feb 27, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
Nov 16, 2008 | Singer CE-200 Quantum Futura Computerized...
My emroidery carrage reads the wrong hoop i have done every thing the manual says to do but it still tells me the small hoop is in when
When using either hoop you should place the frame on the carriage before you send across the design as there's a sensor in the carriage. Also when you send across the design and it asks you if you want the design optimised for speed you must always say YES. If this doesn't work then i suggest sending the machine to your local agent as the sensors may be faulty.
Apr 13, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
24 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
