Hello, indicate the brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: the sound on my car stereo won't come on but when
This is going to be a short somewhere in your speaker wires. I know that doesn't solve your problem and it's a pain to find shorts sometimes, but it's one of those needle in a haystack problems sometimes. Hope you find it and good luck!
SOURCE: sound not working properly!!!
Our sound on our windows 7 computer stop working any solutions
SOURCE: I connected a after market
If you got the stereo used the speaker wires might not work. I stereo only puts out sound thru the RCA output using an amplifier.
SOURCE: sound comes in strong and weak at different times
It could be that or a loose wire to one side of the speakers in the set. If it does it often enough locate where the actual sound for each side of the set is located---when it does it get close and listen---if one side is low or distorted you know it is either a connection or speaker on that side OR since most sets have a left and right channel for sound--the issue is in one side.(circuit problem)
SOURCE: why is no sound coming out of stereo
Did you press one of the speaker buttons?
Did your cat chew the speaker cords?
Pressed the mute button?
Turne the volume low before pressing any button.
