posted by 12798mason on Nov 27, 2007
Our chest freeze had ice build-up under the lid (door) we need to replace the inside liner the plastic part that holds the insulation up. This has been a good freeze until now. Model # CB 26DNCWH..Any help would be a help
Solution #1
posted on Nov 30, 2007
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for GE 25.1 cu. ft. / 711 liter Chest
Email this problem
Email this problem
Can you Help with these Freezers problems?
Repair Service
Find Freezer Repairman Near You:
Find Parts
