Mistubishi tv wd-52525 blinking green light
I have replaced all of the capsitors 1000uf 16v plus 330 uf 16v still have the blinking light and it just seems like maybe a fuseon circut board? it still doesn't want to power up and green light is bliking rapidly. Please help
  • 2 more comments
  • jen32 Nov 28, 2007
    So this is getting deeper and deeper can anyone send me the service manual for mistubishi wd-52525 ppppppplllllleeeeaaaassseee!
    question could it be the pisco fuses people are talking about? or the ic convergence or maybe something thats cheep and easy?lol the green blink of death
  • jen32 Nov 29, 2007
    Well the way it looks is that there both bad but i read that it could be a pico fuse? or a resistor? does anyone have any info on these?
  • abiquiu Dec 01, 2007
    Blinking green power light after power outage. Unplugging and pressing reset button don't work
    Genius:
  • 1,694 Answers
Research your problem based on your exact model #......
Do not focus on WS-....13 Model # 's........they are not the
same fix................T.
Posted on Dec 01, 2007
  • 179 Answers
This set has many interesting problems with the blinking power light..Disconnect the USB connector from the card reader to the front from the Chassis, if the unit will then boot up replace the Card Reader part # 299P271010...look closely at the main power supply pcb for capacitors that have a "puffy" top.. remove the "e2p" board( it is a small board that plugs into the dm board..try to boot the set again--this time it may take 5 minutes--if it boots then the e2p board is bad (934C121001) if not then the dm board needs to be replaced (934C116002). remember,the new dm does not come with the e2p board
Posted on Nov 28, 2007
    Genius:
  • 1,153 Answers
Go to www.ctechnicians.com and read the directions
Posted on Nov 27, 2007
I have a mitsubishi tv model wd-52525 and the green timer light is flashing and it will not turn on. Just bought expensive bulb and replaced it and still blinking
Probley should check the DM board for bad capastors. DM board is inside of a metal case should be on left side of tv when looking from rear capastors should be marked 16v 1000 uF on them should be 4 of them about 1 inch tall green or black or blue or brown maybe even yellow in color if bulage on top then then thay are bad if not still could be bad common problem need to check may or may not be your problem does couse the power light to blink non stop.
Oct 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Problem with Mitsubishi 52525 TV
A teady blinking green Led is usually caused by the foru 1000uf 16V capacitors on the DM pwb
May 24, 2009 | Mitsubishi WD-52528 52" Television
CAPACITOR 1000 UFD 16V 105C FOR MITSUBISHI WD-52525 52 IN. TV
no you cannot substitute a 680uf 16v 105c in place of a 1000uf
if you want to put a better capacitor in place of the old 1000uf 16v 105c , then use a 1000uf 25v or 35v 105c
the voltage rating will allow the cap to better handle the circuit
Apr 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
3-5 error code on mitsu wd-52725(chassis fan failure)
Check the power PWB pico fuse F9A09 and if thats good check the following capacitors all on the power pwb.
Power Supply
C9A52 1000uF 16V
C9A59 1000uF 16V
C9A61 1000uF 16V
C9A62 1000uF 16V
C9A39 2200uF 35V only some versions
have this cap.
C9A40 2200uF 35V
C9A37 3300uF 16V
C9A38 3300uF 16V
Feb 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Ws-55813 mod. green ld light wont stop blink tv wont turn on
The DM modul is bad. Replace all 1000mF/16V capacitors( be careful with the polarity). After replacing capacitors conect to AC power. Waith about 1min. Green flashing will stop. Turn ON tv. The modul is on the raight hand side next to the main board.
Jan 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No power
they are located on the power pwb There are four 1000uf 16V two 3300uf 16V and two 2200uf 35V that need to be changed
Nov 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62825 Green Blinking light and TV won't turn on
I have the same problem with the green light blinking and the T.V will not come on. I have reset it and unplugged it and everything and still nothing. Can anyone help me
Aug 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I need help with my wd-52525
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
May 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mit 52525 from blinking green light to still green light.
bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking light will not turn on
replace C81A2 C81A3 C81B2 C81B3 on the dm module and C8F19 C8F21 C8F22 C8F27 on the fmt pcb all new caps should be 680uf at 16v instead of 1000uf at 16v
May 06, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Open Questions:
Televison & Video Logo
569 people viewed this question
Top Televison & Video Experts
