Question about Hobart Food Mixers
On a Hobart A200 commercial mixer. On the lowest speed 1 the mixer spins around but stop/pauses for a moment frequently.
It doesn't make any noticeable noises such as grinding and continues on. It does this with both heavy loads bread dough but also with light icings. We recently had the Wheel bushing Worm gear replaced, but I believe it was doing this prior. Grease was repacked when the repair was made. Is this normal or could this be the cause/symptom of the gear shearing on certain spots.
  • Hobart Master
  • 1,341 Answers
It sounds like either a partly stripped gear or a broken driving pin. If it is one of those options though I'm surprised it has not stopped completely.
Posted on Jun 17, 2019
SOURCE:
SOURCE: Hobart A200
Hi I work on these all the time, sounds like a tooth from the one of the gears has sheerd off so making the gear rings rotate when they should sit solid in its casing..... you need to open her up or get a tech to look at it £150 is an approx fix
fritz
Posted on Aug 21, 2008
bigg t
  • 640 Answers
SOURCE: A200 Mixer/Medalist L120 Mixer by Hobart
Where is it leaking grease from?Im a hobart tech and service these mixers.When i go into work i will get you the part # for the grease.You would then have to contact your local hobart branch,tell them the part # and pick up the grease.
Posted on Feb 25, 2008
ricardok45
  • 135 Answers
SOURCE: Hobart A200 noise
Your mixer was built in 1942 and from the sound of it, it's been without grease for some time. Before you dismantle it, try adding new grease to it. This is the less expensive and less time consuming approach. The grease product to look for is Shell Darina XL EP-2, Try to find a local Shell Distributor and see if they'll sell you about 4 tubes of 400 grams each. This grease is compatible with most other greases, so you won't have to remove the old grease before you add the new stuff.
Remove the four screws that attach the Hub to the body of the mixer, pull off the hub. You now have access to the transmission area. work the new grease into the cavity, try to get as much grease as you can toward the back of the compartment. This will be a very messy job unless you have, or acquire a grease gun that the tubes will fit in. Lay the mixer on it's back and let gravity help you to get a lot of grease down through the hub opening. Keep adding grease until you've greased up to the hub opening. Grease the hub gear and then re-install the hub. Raise the mixer to vertical and start up the mixer, letting it run for a couple of minutes. Stop the mixer and shift gears,, once again start the mixer and repeat this procedure for the last gear. Listen for the sounds it was making before, they should be silent or at least muted. If it's still making loud noises, You may well have to take it apart for an overhaul. Dont overlook the planetary gearing, this gearing is not bathed in grease like the trans. Remove the planetery assembly, clean and inspect the planetary gear and the large ring gear in the mixer body. Regrease both and re-assemble. Your mixer is now as quiet as it will get short of a complete overhaul. If this solution works, it has only cost you a few bucks and a bit of time, making this. solution a good one, unless you still have the major noise issues.
I f you've found this solution helpfull, please rate it and Good Luck! ricardok45
Posted on Jan 07, 2009
  • 6 Answers
SOURCE: hobart A200 mixer motor worm gear
sometimes you read of other problems and solutions and it puts you at the edge of your seat. in this case of changing the worm gear on the A200F was cake. when you drop the lower end (3/4 acorn and jam nut), pull out yoke (speed select handle) the center transmision shaft and gears pull right out.worm gear easy to change at this point. if you can change a motor bearing, then you can do this job. Note: change seals and bearings as needed,check all gears,keys and spacers for wear and if you go the mile take gears off drive gears, these are the 2 smaller trans shafts put in lath if you have accsess to one if not roll shafts on flat surface to see that shafts have no bends in them. Also remember when you put the bottom back do not over tighten the jam nut,hold and lock acorn nut, should spin free and have about .016 to .030 movement up or down. Lay out all part on cardboard the way they came out. should go back together easy.
Harry Ooooooooooo
Posted on Jan 13, 2009
bigg t
  • 640 Answers
SOURCE: The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Posted on Jan 14, 2009
Hobart a200 first gear not working
slacken the big acorn nut away from the bottom of the planetary and then tighten the lock nut to the acorn nut. When adjusted and secured, the planetary should have a little vertical play, maybe 1/16".
That will stop the second gear driving from friction from being too tight.
Feb 27, 2014 | Hobart A200 Stand Mixer
Hobart A200 mixer won't start
My fantastic guy just rebuilt my A200. He says it's likely that your back plate is slightly off center so that the center arbor is touching the windings-- any contact and the machine won't run. The tolerances are thousandths of an inch in there.
Nov 21, 2011 | Hobart A200 Stand Mixer
Hello, I have a commercial dough mixer,
it's a standard drive system found on most hobart mixers like the a200 style and you may find only hobart parts will fit it
Oct 10, 2009 | Hobart D300-6036 Mixer
Speed reduction of Hobart A200 mixer
Hi Don. If your mixer is hurling honey, you must be very popular in the ant world...Sorry!
The Hobart electric motor on your mixer was designed and engineered to operate on 115-120 volt current and is the most dependable, and capable commercial mixer out there Is it possible for you to use a commercial Imerssion Blender for the first part of your mixing operation. Once your honey thickens a bit perhaps the a200 wouldn't hurl honey. Another consideration would be to either try a different beater or modify the one you have by removing surface area from the beater. If you remove metal, be sure to do it in a balanced fashion to avoid unwanted vibration in the beater. If you're not up to removing metal, take it to a machine shop and they'll do it for you. It probably won't take long, or cost much, and they have the expertise and the equipment to do it properly. If you found this solution helpful, please rate it. Good luck! ricardok45.
Feb 02, 2009 | Hobart A200 Stand Mixer
A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Jan 17, 2009 | Hobart A200 Stand Mixer
Jan 13, 2009 | Hobart N50 Stand Mixer
Hobart A200 Mixer not working
Sundance,
Please visit the corp website www.hobartcorp.com and click on the "Sign In" link in the upper right hand corner. You'll need to complete a brief registration form, but then you'll land in the Hobart Resource Center.
Hobart no longer manufactures the A200 mixer - but you can review and download a user manual and a parts catalog from the Resource Center on your mixer. That should help you understand the parts need.
We do sell replacement parts direct to end users, just visit our service website at www.hobartservice.com - and click on the "Locate on Office" link. You'll be able to contact your local Service branch to purchase a replacement part OR to have them take a look at the unit and provide a quote on fixing it.
If you have additional questions on Hobart products - please contact me at sherri.wilmoth@hobartcorp.com .
Thanks!
SHerri
Oct 11, 2008 | Hobart A200 Stand Mixer
Same speed
I believe the speed control needs to be replaced. It controls how much electricity is sent to the motor.
Jan 28, 2008 | Hobart A200 Stand Mixer
Hobart a200
will it move in any speed,i need to know this in order to troubleshoot your problem.im a hobart service tech and i service these mixers alot.
Nov 13, 2007 | Hobart A200 Stand Mixer
Food Mixers Logo
27 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Steve Allison
Steve Allison
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
