SOURCE: need a repair manual for troy bilt tiller
Ddavis:
Have a look on ebay. Do a search for troy bilt tiller manual. There are several folks on ebay that collect and sell on manual on all kinds of stuff. I was able to locate a manual for an old singer sewing machine.
Hope this helps Good Luck Loringh please leave me a rating Thks
SOURCE: both belts shredded. Atlas garden tiller model 12 -5100
I bought a repair manual from Clymer and found the belt sizes for my Atlas 12.5022 tiller. The manual lists a 1/2 inch by by 36 inch forward belt and 1/2 inch by 32 inch reverse belt for the model 12-5100. Good luck. Don't bother to buy the Clyme manual. It isn't very complete.
Bob Mortimer
[email protected]
SOURCE: how do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
SOURCE: Troy Bilt Tiller and Pressure Washer
The carbs are plugged. Take the bowl off the carburetor by loosening the nut on the bottom. You'll want to clamp the fuel line before you do this. That nut has a small hole that goes through the nut from side to side, and one that connects them in the center. Use a wire brush to knock all the deposits loose, making sure that the holes are clean and free of obstruction. Put it all back together, and it should run fine.
SOURCE: broken pull cord on my manual start Troy-bilt Pony
It's definitely do-it-yourself in that no special tools or skills are required, but it can be a little tricky. You can see that the the recoil starter is in an assembly which is spot welded onto a metal cover. You have to remove the entire metal cover that includes the recoil starter. There may be 6 to 10 screws to remove to do that. When you get it off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
