Question about Brother MFC 420CN All-In-One InkJet Printer
Brother MFC 5460CN Won't Print w/ Full Black Cartridge
The color cartridges are low; one empty. I replaced the black, but
my printer won't work. I tried the black electrical tape on the nose
of the color cartridges hoping to fool the sensor but it didn't work.
Is there another quick fix I'm missing for this model. I just want
the black to work. Thanks for any help.
  • zoey777 Nov 28, 2007
    Thanks for the quick response. It's MFC-5460CN
    and uses LC51M cartridges. I'm sorry but I couldn't
    make out where the tape goes on your drawing.
    My cartridge is so different...but I did try to tape
    it over the little window where the ink level is..
    only then the cart. snap wouldn't shut.
    I wish I had my HP printer back. Thanks-
  • 832 Answers
What type of machine do you run?!! MFC420 or mfc 5460?!!
Is it a machine with LC51 or LC41 carts?
In both way: Did you check the other carts? It could be that there is another one empty.
Did you stick the tape at the right place, too? The tape should be a bit larger than shown on the pic.
For the LC51 it it the same position.
Did you answer the printers question of changing the cart with YES?
Brother MFC 5460CN Won't Print w/ Full Black Cartr - 2b19414.jpg
Posted on Nov 27, 2007
  • Mix-it-up
    Mix-it-up Nov 28, 2007
    stick black electrical tape around the window (red arrow).
I have a Brother MFC-465CN and it says the Black Ink cartridge is empty. However, the cartridge is full. I cannot print until this is resolved - ow can I fix this?
Hello I am an expert on printers are pretty good Brother.Brother But the ink is running out fast .. I got home Brother MFC-210C.
So I took ink and slid ho.
. I hate Brother printers!. So I broke down and I saw that there is a color sensor and instead I chose colors I had crouched low and showed that the paper is full of the good? Try it at home if you can.
Jul 30, 2012 | Brother MFC 240C All-In-One InkJet Printer
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Where do the ink cartriges on a brother mfc 5460cn fo
Your machine is equipped with an ink dot
counter. The ink dot counter automatically
monitors the level of ink in each of the 4
cartridges. When the machine detects an ink
cartridge is running out of ink, the machine
will tell you with a message on the LCD.
The LCD will tell you which ink cartridge is low
or needs replacing. Be sure to follow the LCD
prompts to replace the ink cartridges in the
correct order.
Even though the machine tells you that an ink
cartridge is empty, there will be a small
amount of ink left in the ink cartridge. It is
necessary to keep some ink in the ink
cartridge to prevent air from drying out and
damaging the print head assembly.
a Open the ink cartridge cover.
If one or more ink cartridges are empty,
for example Black, the LCD shows
Ink Empty Black and
Replace Ink.
b Pull the lock release lever down and
take out the ink cartridge for the color
shown on the LCD.
c Open the new ink cartridge bag for the
color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1).
If the protective yellow caps come off
when you open the bag, the cartridge will
not be damaged.
e Each color has its own correct position.
Insert the ink cartridge in the direction of
the arrow on the label.
f Lift each lock release lever and push it
until it clicks, and then close the ink
cartridge cover.
g If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example,
Did You Change Blck?) For each
new cartridge you installed, press 1
(Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge
you installed is not a brand new one, be
sure to press 2 (No).
If you wait until the LCD shows
Near Empty and Ink Empty, the
machine will automatically.
Find this on page 113 of the manual:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 04, 2010 | Brother MFC-5460CN All-In-One InkJet...
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
Brother MFC 3240 wont print when 1 ink is empty
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 24, 2008 | Brother MFC3240 Multifunction InkJet...
Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother 210C One colour cartridge empty, want to print a black and white fax
Yes, if you dont need the color anymore in future:
You can cheat with empty c/y/m carts by sticking some dark but very thin adhesive tape around the nose (see picture).
After that the printer logic expects the c/y/m carts always as full.
But you cant print any colors within the next 2 weeks anymore because air will dry out the print head (and destroy the color nozzels)!
See brother homepage for instructions on how to print in grayscale only!
Jan 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
581 people viewed this question
James Cagle
James Cagle
Jim Keysor
