Question about MSI K7N2 Delta-ILSR (MS-6570-030) Motherboard
Installation i've a compaq v710 i'm attempting to install windows it has the error your computer doesn't have a hard drive ,your hard drive isn't functioning properly!?whas the next step thadd i should take to get the installation completed!
  • Ralph Savaerna
    Ralph Savaerna Nov 27, 2007
    hard disk hard disk can't be found or isnt functioning properly?!
    Champion:
  • 209 Answers
Unplug you hard disk, then switch on without your hard disk let your xpcd in your cd rom to run after reading your cd ''saying, no hard drive found'' switch off then plug it in your installation will proceed
Posted on Nov 27, 2007
After installing windows 7 my cd drive doesn't work. I've tried new drivers and disabling it and everything else I can think of... can anyone help?
Are you sure that you have installed the correct driver? Try going to the website of your computer's manufacturer and get the driver from there.
David
Mar 26, 2013 | Dell Inspiron 1525 Notebook
NTLDR compressed on a Compaq Presario SR105CL cant enter bios to set to boot
Step 1:
Which operating system ?
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT.32 New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. b> Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer. If you are attempting to BOOT from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt. If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt. Press any key to boot from the CD
Mar 10, 2013 | Compaq Presario sr1055cl PC Desktop
Restore disk has been lost. I need to know how to change bios to allow straight Xp to be installed
This isn't a bios setting, it's a setting that Compaq put somewhere (probably the MBR) of your OS to only allow it's restore discs.
If you want to use straight Windows XP OEM discs, just boot to the disc and you'll be able to install Windows. If that doesn't work, just format your hard drive(you'll lose everything) then boot to the XP and install that way.
Jun 11, 2011 | Compaq Computers & Internet
I can not install windows xp on my compaq cq62-231nr when trying it give a blue screen error have no problem installing windows 7 spec amd v120,2gb ddr3,atiraden 4250 ,sata hard drive 320gb,bios...
You need to add the SATA hard drive controller to the XP installation CD using the program NLite.
Follow this guide:
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Nov 04, 2010 | Compaq Presario CQ62231NR Notebook
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
PXE - E63 error
This error is related to the hard drive.
It could be a faulty connection on the hard drive - try re-seating the hard drive.
The hard drive may be faulty - go into the BIOS and see if the BIOS detects the hard drive.
If the BIOS cannot detect the hard drive then the hard drive may be faulty ot the laptop's hard disk controller could be faulty.
To determine if the hard drive is faulty, remove the hard drive and connect it into an USB hard drive adapter and plug this adapter into a working compute's USB port. If this computer cannot see this hard drive as an external hard drive then this hard drive is faulty and needs to be replaced.
When the new hard drive is installed in the Compaq laptop, insert your Windows installation CD and install Windows, plus the Compaq's device drivers and your programs to get a working laptop again.
May 26, 2010 | Compaq Evo N610C Notebook
Xp not install in compaq presario cq50 139wm
In Windows XP, The STOP: 0×0000007B: error often occurs if you move a hard drive that contains Windows XP to another computer or if you have just installed a newmotherboard or drive controller. This error occurs in these cases because your registry does not contain driver entries for the current motherboards drive controller. So in effect, the device driver that Windows XP is loading from the registry will not work with the new drive controller.
Fixing the STOP: 0×0000007B: Error:
The easiest approach to fixing the error is to locate download and install the latest hard drive controller driver for your motherboard. In many cases the driver in question controls a ATA or SATA device.
There are other problems including viruses that can cause this error and information regarding these causes can be found HERE
Jan 01, 2010 | Computers & Internet
Laptop compaq v2000
your windows install is screwed up. i'd dig up your Windows XP CDand pop that in and do a repair install. if it still doesnt work then i'd enter the bios setup (hit F10 on compaq boot screen) and look in there for "Hard Drive Test" and run that. be aware it will take 70 mins on a 60GB hard drive, and longer for a bigger drive. if the hard drive passes the test then you may want to boot up the XP cd and do a fresh install, opting to format the drive. be aware that formatting WILL delete anything and everything on the laptop.
if the hard drive fails the test, then obviously you need to get a replacement drive and reinstall Windows on that. if the hard drive failed, any data on it is most defenetly toast.
Aug 16, 2008 | HP Compaq Presario V2000 Notebook
Hard drive problems.
You,ve got a couple Of options Here.
1: you can replace the hard drive with a replacement, install windows. Then add the corrupt drive, and attempt to access it That Way.
2: You Could attempt To Repair, the Hard-Drive With A Tools-Disk. Containing partition Managers Et,c.
3: you could try starting your computer, with Windows Operating System Or Restore Disk In Drive D:/ Or CD/DVD Drive, In The hope That Windows will re-install, overwriting any corrupt Or deleted Files, And restore your Drive To It,s Original state.
4: you Could send your Hard-drive To Me, Where I can attempt Data Recovery For You.
There Will Also Be Other Problems posted.
Mike @ compurepair.
Feb 28, 2008 | HP Compaq Presario V2000 Notebook
MSI K7N2 Delta-ILSR (MS-6570-030) Motherboard Logo
52 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
