How to adjust time in eq 308 cth hygrometer ? I am unable to adjust it.
Is there censor available for a 308-2316 weather station that will make the outdoor temp more accurate?
The most important things to remember with weather stations are placement and battery power. To get an accurate reading, you must have the sensors in the proper spot. If they are on a roof, they must be at least 3 feet above the roof. The batteries should be changed yearly and replaced with Lithium type batteries. Your sensor suite is a combination of anemometer and thermo-hygrometer. You may be able to purchase another temp sensor. The manual shows multiple channels for that application. Send them a message and ask: http://www.lacrossetechnology.com/support/contact_lacrosse.php
Mar 16, 2015 | Measuring Tools & Sensors
Tip
Equinox EQ-310-cth thero/hygro/clock
i have Equinox EQ-310-CTH
thermo meter how adjust the clock
on May 26, 2010 | Health & Beauty
How does a hygrometer work?
This site has a good explanation for a what a hygrometer does and how they work. http://science.howstuffworks.com/nature/climate-weather/meteorological-instruments/hygrometer-info.htm
Jan 21, 2014 | Measuring Tools & Sensors
Are there different types of hygrometers?
there are a few different kinds, the main ones are psychrometers, electrical hygrometers and dew-point hygrometers.
How does a dew point hygrometer work?
A dew-point hygrometer uses a metal mirros to catch moisture from the air to tell you the dew point, at what temperature the condensation appears is the dew point. For a better and more clear explanation see http://www.ehow.com/list_7153637_types-hygrometers.html
What is a hygrometer?
A hygrometer is an instrument for measuring the humidity of the air or a gas.
Jan 30, 2013 | Measuring Tools & Sensors
The Hygrometer on my Air-O-Swiss U7142 reads 25% all the time. I assume its not functioning properly as I have other hygrometers in the house which say higher readings. Is there a known way to fix this? I...
I have got the same problem with my u7142 unit. This most probably means that the hygrostat inside is either broken or it has been heavily covered with the "white dust" in case the demineralization cartridge has not been changed for a long while.
To resolve it you have two options: either clean the humidity sensor or replace it. The sensor is at the bottom of the front panel, so you need to disassemble the front panel only, no need to open the whole unit (note that there are 2 screws at the bottom holding the front panel also). You need to get the sensor out from the printed circuit to open the cover and clean the surface of the sensor with something (blowing air does not help; you need physically touch the surface with something). If it does not help then you can go for the second option to replace the sensor, the type used in the unit is SYH-1. It is not a pricy element so you may go straight to the replacement if you find a shop nearby to buy it. I have simply replaced the sensor and now the unit is showing the proper humidity value and adjusting the steam automatically again.
Mar 03, 2011 | Air-O-Swiss U7142 Humidifier
Adjust EQ on my IPOD nano
The EQ does not have a on off switch. Just chose what you want it to be by clicking on it. If the problem still occurs refresh your ipod by hold the menu and center button at the same time, then try again.
Jan 27, 2009 | Apple iPod nano
Fostex mr16 eq/presets
In short - No. The Eq menu is the only way to affect the frequency levels on the inputs, but if you select stereo buss and listen to the inputs, you can hear the effect of each Eq on the relevant input.
Dec 22, 2007 | Fostex MR16HD/CD Digital Recorder
23 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
