Question about Tablets & eReaders
Whats the best way to replace the charging port on my RCA PRO 10 tablet
  • Tablets & eR... Master
  • 27,930 Answers
SOURCE:
  • 9 Answers
SOURCE: I have an XO tablet for my kids but they've broken
Hi Johhnie,
To repair a charging port you will need the following:
  • fine tip soldering iron (Weller 15 watt)
  • Dremel tool with cut off wheel
  • De-soldering Braid
  • Torx T5 screwdriver
  • small flat bladed screwdriver (optional)
  • Diagonal cutters
  • small hemostat or fine tweezers
  • Panavise, helping hands or similar bench top holding device.
Take off the back cover and remove the battery.
Next, whip out that Torx T5 and remove the screws holding the phone together. On this one, there were only four to remove.
With the screws out, gently pull the phone apart. The lower half of this Motorola clips together, so I gently worked around the edges with a small flat screwdriver until it came apart.
The SIM card board easily separates from the phone via the flat SMD connector. Just gently apply pressure near the connector and it comes right off.
Next, the flat ribbon cable needs to be detached in the same manner, and the main PC board removed from the phone. It should pull right out once the cable is disconnected.
As you disassemble the phone, put each of the pieces into a parts bin. Any sort of container will do, but I'd avoid a static generating plastic Tupperware container.
Carefully place the board in your clamp/Panavise/whatever - I had to line up the buttons with the slots in the vise, or I probably would have damaged them when I clamped the board
You'll need a new connector before you can fix anything.
In order to check the condition of the pins, clip the two tabs that hold the rear shielding on to the connector with a pair of diagonal cutters.
With the rear shield removed, we can access the rear pins - Unlike the front, everything looks pretty good. The advantage of surface mount parts is that they don't require much solder to hold together. Unfortunately, when you're replacing a surface mount part, a small amount of solder can keep you from removing the part without damaging the board.
To keep from burning this foam seal, peel it back and stick it off to the side.
Enter the rotary tool. Sliced the top off of the connector by cutting the sides lengthwise.
Next, cut across the center of the connector. The bent pins should be gently cut loose and the upper half of the plastic connector will probably fall apart. The shielding on the sides should be cut to allow each leg to be removed individually. (Be careful not to cut the PC board below!)
Working from one side to the other, heat up the solder pad on each pin. Then use some tweezers to grip each pin of the connector. (I used a small pair of alligator forceps) If the solder is hot enough, the surface mount pin should come loose with little to no force. It's vitally important to be as gentle as possible with each one. The solder pads on the PC board are very delicate, and easy to pull up if you're not careful. Unfortunately, overheating the pads can also cause them to pull up. So be quick about it!
With the delicate pins out of the way, I carefully cut apart the remaining plastic and removed it.
Finally, the remaining legs of the shielding were heated and removed from the board.
After the new port is aligned (double check the pins in the rear!) solder one of the shielding legs to the board. Double check the pin alignment again, and solder the other legs. Now the port should be solidly mounted.
Next, the pins on the new port need to be soldered. The super fine tip on my 15 watt Weller pencil made this easy. Alternatively, you can use a wider tip to solder things and go back over the pins with de-soldering braid to remove any solder bridges. If you forgot to remove the rear shield, you'll have one hell of a time soldering the pins. On this particular phone, the metal shielding behind the port made it impossible to access the pins without removing the rear shielding.
Regards
Martin
Posted on Jun 19, 2014
vaibhavnath
  • 72 Answers
SOURCE: the charging port hub on my 7 inch tablet Android operating system RCA model numberRCT 6378 w2 DC charging port is broke how to replace how to get the part for the replacement thank you
buy it from the online hub like ebay, or lookout for it in the local market.
Posted on Mar 19, 2015
  • 4134 Answers
SOURCE: The charging ports of my RCA tablet model #RCT6103W46 started giving me problems after I got it from a friend...is there anyway I can charge it by using the HDMI port?
No. HDMI ports are only data ports. There is no power routed through them as there is in USB ports.
Posted on Feb 10, 2016
Testimonial: "Thank You ...."
99rannellis
  • 12731 Answers
SOURCE: Neither port works to charge my prestige elite 10 tablet (wall charger or USB to computer) and the metal tongue inside main charger port is loose/broken &
Your tablet's port is broken or malfunctioning. It probably needs to be replaced.
Posted on Mar 05, 2016
  • 52787 Answers
SOURCE: My RCA Viking pro tablet just blinks on and off it isn't taking a charge what do I do?
The battery may have to be replaced
Posted on Apr 28, 2016
What size HDMI is on the viking pro 10?
micro HDMI port
Walmart, eBay and Amazon have these for under $10. You can also google RCA Viking Pro 10 HDMI cable and find the exact HDMI cable.
I've included some steps to take once your ready to connect your HDMI to TV below.
Steps to connect with HDMI cable in place:
Open "Settings" on RCA Viking Pro,
Go to "Display",
Go to "HDMI Settings {Click to configure HDMI}"
Click "HDMI",
You should see a ? appear next to it, and then a confirmation icon in {top left corner} notification area.
Hope this helps...
https://i5.walmartimages.com/asr/a0bb7d1e-b4a7-439b-94c3-d41ae1c4c86a_1.734e671da04dcdb55962c0ffeb8dbc79.png?odnHeight=450&odnWidth=450&odnBg=FFFFFF
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
Mar 25, 2018 | Tablets & eReaders
Where can I purchase a pt425080 battery for a rca tablet
Everywhere! :>)
For RCA 7 Tablet RCT6077W2 Battery PT3867103 MH49370 3.7V ...
https://www.rakuten.com/prod/for-rca-7-tablet...battery...3-7v.../274930413.html
Listed is a RCA 7 Tablet RCT6077W2 Battery PT3867103 MH49370 3.7V 2600mAh - Used. Is your battery not holding a charge anymore? Are you just looking ...
RCA RCT6378W2 Battery Replacement - iFixit
https://www.ifixit.com/Guide/RCA+RCT6378W2+Battery+Replacement/40480 RCA RCT6378W2 Battery Replacement: In this guide you will learn how to remove and replace the battery in your tablet.
Battery Tablet 7 ' eBay
www.ebay.com/bhp/battery-tablet-7 3.7V 3000 mAh Polymer Li ion Battery Lipo For GPS PDA PSP iPAQ Tablet 7" 8" ... Battery Type: Li-ion Polymer Battery. 1 x 3000mAh Li-ion Polymer Battery.
RCA 10 Viking Pro 10" RCT6303W87 Internal Battery ' eBay
www.ebay.com > ... > See more RCA 10 Viking Pro 32GB WiFi Tablet Keyboard Bl... Rating: 4 - ‎5 reviews
ITEM DESCRIPTION. Item was pulled from a working unit and is in great condition. THIS BATTERY HAS TO BE SOLDER. Please check the battery in your tablet, ...
Amazon.com: 4200mAh battery for RCA RCT6203W46 10 ...
https://www.amazon.com/4200mAh-battery-RCA-RCT6203W46.../B013HW5E94 Rating: 3.7 - ‎3 reviews
RCA PRO10 Edition RCT6203W46 10" Tablet PC Digitizer Touch Screen New ... $19.99. 3650mAh Replacement Battery for RCA RCT6272W23 7" Tablet PC ...
RCA ' How to take care of your tablet's battery
https://rcaav.com/how-to-take-care-of-your-tablets-battery/ Learn how to take care of your RCA tablet's battery with these simple and helpful tips.
Bulging batteries in RCA tablets ' KOMO
komonews.com/news/consumer/bulging-batteries-in-rca-tablets-11-21-2015 May 19, 2015 - If you have an RCA 7 inch tablet that was purchased last year- keep an eye on the internal lithium battery. There are reports of the battery ...
Jul 29, 2017 | Tablets & eReaders
How can I bypass the charging port on a textbook tablet
Peter, why would you want to by pass a charging port, if port is not working change it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
Generic TAB Charger port Replacement
Samsung Tab 2 10 1 Charge Port Repair Fix Replacement TUTORIAL Win Samsung...
Jul 24, 2016 | Tablets & eReaders
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Jul 11, 2016 | Tablets & eReaders
Port on 10 inch tablet not working can it be fix
Linda, if it is the charge port, mini USB, yes they can be fixed or replaced by cell phone/computer repair shop.
Check the attached links videos showing port replacement. Good luck.
Toshiba Tablet AT300SE AT305SE Charging Port Repair
Samsung Galaxy Tablet 10 1 Tab 3 10 1 P5200 P5210 Micro USB Port Replace HD
May 03, 2016 | Tablets & eReaders
How to turn on RCA pro 10 tablet unless plugged in.
Hi try holding the power button down for 15- to 20 seconds to c if it will reboot. Good luck
Mar 14, 2016 | Tablets & eReaders
Whats the device code 8 letter code
RCAAV ' RCA Tablets - Audio - Video
https://rcaav.com/
Use it as a tablet or a conventional laptop, the Cambio is as dynamic as you are. ... Windows 10 gives you absolutely the best experience for doing what you do, with great ways to ... Our new Android 2-in-1s are your new go-to device. ... Thanks to RCA, cutting the cord and getting rid of your cable bill is a little less painful.Missing: letter
RCA Tablets ' Connect and Pair your RCA Pro 10 Edition ...
? 3:01
https://www.youtube.com/watch?v=sNELPDMQOOo
Apr 21, 2014 - Uploaded by RCA Tablets
RCA Tablets ' Connect and Pair your RCA Pro 10 Edition Tablet... 7:58. RCA Cambio 11.6 Inch Windows 10 Detachable Keyboard... 8:35. RCA Tablet Complete Disassembly - LCD/Glass/Power button fix ... Get embed code.
PAIRING YOUR MOBILE DEVICE TO YOUTUBE ON TV ...
? 4:05
https://www.youtube.com/watch?v=Tc5po_6MdD8
Nov 30, 2012 - Uploaded by Martin Charles Everington
Enter the pairing code shown on YouTube TV. .... le40C650 in the youtube application has no settings.. so i cant pair it... what else can i do?.
Jan 19, 2016 | RCA CA 7" Tablet with 4GB eory 28458515
My Visual Land Prestige Pro Android tablet will not charge
Visual Land Prestige Pro 7D Repair - iFixit
https://www.ifixit.com/Device/Visual_Land_Prestige_Pro_7D
iFixitVisual Land Prestige Pro 7D troubleshooting, repair, and service manuals. ... Tablet is fully charged but it won't stay on ... Why won't my device charge? ... The 7D runs on a newer Android 4.1 Jelly Bean, and has 1GB of RAM, compared to the ...
prestige 7 wont power on - Tabletroms.com
www.tabletroms.com > ... > Visual Land Tablets > Prestige 7
Sep 7, 2012 - 9 posts - ‎2 authors
I found this forum from searching about the prestige 7 and watching the videos ... It showed the charging animation for a few mins and then went off. ... I'd like to figure out what the problem is as I quite like the tablet and it was half .... prestige pro 7d won'tturn on. ,. visual land 8q has power but will not turn on. prestige 10D wont turn on after charging help!
Mar 23, 2014
Visual Land Prestige 10 charging issue
Jan 2, 2014
Ack... Help... Major Battery Issue!!!
Jan 24, 2013
Power Port Charging Issue
Jun 12, 2012
More results from www.tabletroms.com
Jan 07, 2016 | Visual Land Prestige Pro 10D 16 GB Wi-Fi...
My rca 10 inch 32 gb tablet with keyboard turned off one day after I got it for Christmas, It still won't come back on and its been two days, what do I do about it?
Amazon.com: Customer Reviews: RCA 10 Inch Tablet with ...
www.amazon.com/RCA-Inch-Tablet...Keyboard/.../B0...
Amazon.com, Inc.RCA 10 Inch Tablet with Bluetooth Keyboard .... I also bought a Sandisk Class 10Micro SDHC 32gb Memory card to expand the ... So far I am quite pleased with mypurchase of this RCA Pro 10 Edition Tablet .... After using it for ONE week, it completely turned off and never started up again. .... 7 Day Free Return,Shop Now!
Amazon.com: RCA 10 Inch Tablet with Bluetooth Keyboard ...
Amazon.com, Inc.
Rating: 3.1 - ‎179 reviews
Turn on 1-Click ordering for this browser ... 10" Multi-touch; Quad Core Processor; 16 GB Storage; Wireless Keyboard folio ... RCA RCT6103W46 10 Inch Tablet Folio Case - UniGrip 10 Edition - MINT GREEN - By .... I also bought a Sandisk Class 10 Micro SDHC 32gb Memory card to expand the ... Off-angle viewing is poor.
Dec 21, 2015 | Tablets & eReaders
Tablets & eReaders Logo
67 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
