I have an alico dj-fit radio need manual it is a ht portable radio
I have alico dx 70 only puts out 10 watts on 8o meters and less on some
Is your antenna good on SWR?. check it with an antenna Anaylzer so you can see all the bands with the meter.
Any ham operator should be able to help you with this. if you have any near you.
Find a club in your area.. they normally will have test equipment for club use.. that members can use. or maybe a member will come help you check it out.. the good thing about Amateur radio is you cannot be charged to check anything out.. just parts cost of a fix. its a hobby not commercialized like other radio services.
Jan 25, 2016 | Radio Communications
Edison scratch 2500 professional portable dj system manual
can you scratch with virtual dj with the Edison scratch 2500
Jul 23, 2013 | Audio Players & Recorders
To RESET all programs Frequencies on my IC-H16 portable radio.
You can download and review the manual for the Icom IC-H16/U16/U2 HT here. This radio is an Amateur Radio Service transceiver, and will require an FCC license to transmit. No license is required to monitor or listen to the radio. Keep in mind, the Amateur Radio Service is NOT part of "CB" or "FRS" radio services - neither of which require a license to transmit.
When you read the manual, you'll quickly see that there is no "reset" function available. There are only 16 memory locations, so you can simply lock out channels you no longer wish to monitor or you may program any valid frequency in the range supported by the radio. Doing this, in combination with setting the squelch or tone will prevent the radio from opening a particular frequency(s) when the corresponding memory location is scanned.
I hope this helps and good luck.
May 04, 2011 | Motorola GPS
Need a user manual for ht 1000
For this concern that you're looking for the user manual for this device , you can go to this link then download the user manual save a copy of the manual to your computer or print it out for future use.
http://www.repeater-builder.com/motorola/jedi/ht1000-specs.pdf
Jan 06, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Opperational use
Radio Shack has a basic programming page here.
Mar 22, 2009 | Alinco EBP-48M,...
Need manual and installation cd
The software to run the DJ system is available to download from the logitech website - you can also download online radio stations from here. Once you have the software, part if it is an interactive manual. The link you need is http://www.logitech.com/index.cfm/439/216&cl=gb,en?WT.ac=sc|downloads||dd
Hope this helps?
Marc
Jan 14, 2009 | Logitech Wireless DJ Music System (966194)...
Alinco dj-v5 HT deviation adjust
To adjust the deviation of this radio, you don't have to take it apart. If you take the battery pack off, there is a sticker on the back of the radio saying Alinco. Pull that sticker off and underneath are the variable resistors. See the service manual for more details on how to make other adjustments.
First, make sure you note the present position of this pot so you can turn it back if you have to.
If you don't have any equipment to measure deviation, make a contact on the repeater and try turning the pot in small increments and ask the person to help you set the deviation so your voice sounds good through the repeater.
Once set, if the repeater has a touch tone test, go through and make sure all your tones are being properly decoded.
Please let me know if I can be of further assistance to you.
- Jim
KA3EBX
South Hills ARC
www.sharc.net
Feb 26, 2008 | Radio Communications
27 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
