Question about Symbol Cell Phones
Jitterbug flip phone won't turn on after a 2 hour shutoff. a green symbol appears briefly when put in charger. phone is not charging in charger
    Sergeant:
  • 256 Answers
Sounds like battery is dead/end-of-life
Posted on Jun 12, 2019
SOURCE:
  • 18 Answers
SOURCE: headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Posted on Sep 04, 2009
SOURCE: The blue light on my base unit is on but the headset does not app
Unplug the unit -- Then grab the ear peice, and slide off the battery, wipe off the metal prongs ...leave apart for a couple minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the battery to charge. But this should solve your issue.
Posted on Sep 16, 2009
gewiz
  • 1367 Answers
SOURCE: Scooter batteries will not charge. Green light on
ok, this could be a dodgy connection with the batteries or the charger is at fault ?
1. try another charger
2. check the batteries if possible on another scooter.
3. check the connection on the battery and the charge socket connector.
Regards
GeWiz.
Posted on Oct 01, 2009
  • 13 Answers
SOURCE: Xperia x1 won't charge. The charging symbol will
First try to replace the battery, a drained or low voltage battery won't charge up.
For infos on how to fix the Sony Ericsson Xperia X1 Not charging:
http://mobilephonerepairguides.blogspot.com/2011/01/sony-ericsson-xperia-x1-not-charging.html
Posted on Jan 25, 2011
  • 407 Answers
SOURCE: Though my Worx WG781 cordless
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
Posted on May 20, 2011
Hi, My Jitterbug flip phone will not charge up.
Do you know anyone with a similar Jitterbug?
It would help tremendously if you would try charging your battery in someone else's charger.
If the battery charges then your charger is the problem and not the battery. Useful to know.
I am assuming you have wiped all the contacts with alcohol or contact cleaner, to remove any thin film that might be interfering with electric conduction.
Quite often that persistently blinking charge light indicates a battery that has reached the end of its useful life.
If you buy a new battery be certain to charge it at least 14 hours before you ever put it into the phone.
I repair a lot of digital cameras, watches, cell phones, etc. And contacts that need cleaning or degreasing are quite common.]
Aug 22, 2018 | Power Computers & Internet
When I place my cell phone on the wireless charger the dash indicates that it is charging but symbol goes out after five seconds. Does that mean it has quit charging.
-Not sure but here how to test.
Put on the charger for 1-2 hours then unplug it and use it.
You should be able to see the battery level. This is telling you that it take charge or not.
-If it still very low or same as before charge then the battery might be defect. Replace new battery.
Good luck
Mai
Oct 25, 2017 | Symbol Cell Phones
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
My galaxy 4x battery was like down to 2%. I plugged the charger in and it looked lik the little charging symbol was on. Then i powered it off and left the charger in and no green battery indicator cam
Hi, leave your phone down with the charger plugged in for about 15 mins, don't try to turn it on...only after 15 mins. I hope this helps :)
Jan 30, 2015 | Symbol Cell Phones
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Jitterbug phone got wet
you can put the phone and battery seperatly in a bag of rice and leave it overnight. if this doesn't work then its too far gone
Jun 03, 2012 | Samsung Jet S8000 Cell Phone
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
The Jitterbug phone is charged but it will not turn on. Any ideas?
We at Jitterbug are dedicated to providing great service. Thank you for bringing this issue to our attention. I am part of the Jitterbug Customer Service Team, and it’s my job to make sure things like this get made right, and right away. I would like a bit more clarification please. Once your Jitterbug is completely charged and you remove it from the charger, what happens when you press the "On/Off" button to turn your Jitterbug on?
Feb 11, 2010 | One Touch Jitterbug One-Touch Cellular...
No sign of phone charging
I finally have spoken to a very nice youn guy from Sonim Tech Support. He fixed my problem of the phone not turning on.
1. Take out the battery, plug in the mains charger and leave for a few minutes (they say 10 but it took my phone a couple of hours).
2. Eventually the charging symbol will come on the screen, either stady or flashing.
3. Immediately put the battery in the carcass (while it is still connected to the charger), and the charging symbol should stay on.
4. Leave the phone for a couple of hours, disconnect the charger, and the phone should turn on as normal.
This was explained to me, the reason for not turning on was that the software had crashed. This solved it.
Sep 01, 2009 | Sendo Sonim XP1 JCB phone extreme...
Cell Phones Logo
21 people viewed this question
Top Symbol Cell Phones Experts
Marvin
Marvin
micky dee
SSN-MM3
Are you a Symbol Cell Phone Expert? Answer questions, earn points and help others
