My remote will not turn on the sound bar - Televison & Video
    Top Expert:
  • 727 Answers
Please repost and add details. Brand, model what actions you have taken, etc.
Posted on Jun 12, 2019
SOURCE:
Need instructions lg sound bar remote control akb74815321
  1. Turn on your Sound Bar.
  2. Select LG TV function by using FUNC on the remote control or F on the unit until the correct function is selected.
  3. Set up LG Sound Sync (Wireless) on the TV. Refer to your TV's instruction manual for detailed steps
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 11, 2016 | LG Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
How do I fix the sound bar? When I use the remote to turn the sound up, the sound bar goes all the way up and when I try to turn it back down, it goes all the way down.
Sounds like you have a resistor fried in the sound bar. A electronic's repair shop should be able to find and repair it.
Jan 13, 2015 | Televison & Video
Whenever I turn my LG sound bar off it automatically turns back on, I have turned it off on the bar itself and the remote it is still doing it
Remove the batteries from the remote. If the probkem stops then the remote maybe defective or it might need the conductive pad cleaned. If the problem persists with the batteries removed from the remote then the problem is with the sound bar itself.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 20, 2014 | Televison & Video
The remote isn't working
A few things to try:
1) Make sure Batts. are in correctly.
2) check in all around the sides back and under the sound bar for a reset button.
3) Clean the IR emitter on the remote and the receiver on the bar. On the remote it will be a reddish plastic window or a small bulb looking thing on the front. The receiver may be harder to find. I suggest just giving the entire front of the sound bar a good cleaning. I have had remotes stop working because there was to much dust built up on the receiver. I have also found that my kids handled the remote with dirty fingers and had gotten peanut butter on the emitter! Good Luck!
Jun 25, 2014 | Vizio High Definition Sound Bar
Vizio sound bar codes
If you get a Vizio sound bar it comes with its own remote control and is, therefore compatable. If however, you want to control all of your electronic devices with one control, instead of searching for the particular codes just spend some small amount on a universal remote unit which has instructions that come with it that show you how to have the remote find and store codes for a whole bunch of devices including the sound bar!
Jan 01, 2013 | Vizio High Definition Sound Bar
Need 3 digit code for vizio vsb200 audio bar for a clikr-5 UR5U-8780L-TWM remote
There is no listed 3 digit code. You will have to do a code search. Press and hold the Ok and Aux button for 3 seconds. You will have to press the CH+ or CH- (does not matter which) for upwards of 400 times but the code is in there somewhere between 290 and higher, I lost count. Here are two tips. Move the cable box out of site of the remote and expect the TV to turn off when it hits its code. This will make you think you have found the code as the sound will go off. Don't fall for it. Look at the light on the sound bar only. Once the TV turns off you will need to have it;s remote handy to turn it back on so you will hear the sound again.
Once you pass 290 or so go slow and don't miss the light going out on the sound bar or you will have to do it all over again.
Once you turn the sound bar off press the AUX button again to lock in the code.
It's a pain but the code for Vizio sound bars is in there, don't let them tell you it's not. Took me about 7 tries to find the sequence and make the mistakes but my Vizio bar is now Programmed to the Cliker-5 and works fine. Good Luck.
May 19, 2011 | Televison & Video
I Have a 5.3 IR Remote and a vizio VSB200 Sound Bar. The remote will not program to the Sound Bar. The Optical Audio is connected to the TV. What do I need to do.
lojr,
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE buttons at the top of the remote light up.
filestream.ashx?id=435
2. Press the RECEIVER POWER button on the remote.
filestream.ashx?id=436
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the sound bar turns off. This process may take several minutes.
filestream.ashx?id=438
4. Press POUND (#) on the remote. The VCR MODE button will flash three times.
filestream.ashx?id=440(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press VOLUME on the remote to confirm the remote controls the sound bar. If this does not work, return to Step 1.
filestream.ashx?id=442
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
Jan 13, 2011 | DISH Network IR Remote Control
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
