Very old Sanyo TV channel programming
I aquired a Sanyo AVM270 (1986) TV and I am having trouble programming the stations. There is no auto program that I can find and due to the age of this model there are no manuals to be found on the net.
  • STACHIA Dec 01, 2007
    it keep teling me that my cable is not connected but it is i can change channel but not picture nor sound jut frying noise
SOURCE: sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
Posted on Mar 31, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Posted on Jun 14, 2008
  • 20 Answers
SOURCE: my tv wont let me auto program the channels
if you can get to menu to unlock the channels type in 0000 or 1234 or 9999 or 0001 orif this doesnt work you could take back off tv and remove the little battery that looks like a coin out. becareful, this is high voltage in there.........
Posted on Jan 02, 2009
Slapnuts1975
  • 51 Answers
SOURCE: program an old sanyo tv
You need to go into the menu and set it for cable insted of air/tv. The television is only getting the 2 - 13 because on that setting, its as high as it goes.
Posted on May 20, 2009
  • 10 Answers
SOURCE: Philips Magnavox 2783 c101 - will not auto program tv channels
Ya what you got to do is Grab your tv, and throw it out your window. Garbage tv with built in problems made to be fixed. I had the same tv and i had many problems with it before. Just buy a new one boss.
Posted on Feb 17, 2010
Add a station
This set isn't capable of going over 68, this is all it's programmed for. You will need to get a channel box that overrides the tv's programming in order to add the channel 73.
Aug 27, 2008 | Sanyo DS20930 20" TV
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
Will not find digital tv stations
I'll be glad to assist you in locating the digital channels in the TV.
Make sure that the Cable or Antenna Input is connected to the TV. The Cable and Antenna input can be connected to the VHF/UHF Input on the TV. The TV can search for the channels only if the VHF/UHF/CABLE input is connected to the TV. If you're connecting the Cable box or the Satellite Receiver to the Video or HDMI inputs on the TV, then it is not require to auto program the TV. Here, the auto program may be required in the cable box.
To Auto Program the TV, select the Manual Channel Search option from the Menu option and then select the CABLE, AIR or Digital Add-On option depends on the connection. The Digital Add-On option adds any new digital channels that are found to the Channel Scan Database.
This should resolve the issue. Please feel free to get back to us for further assistance.
Thanks for contacting FixYa.
Aug 04, 2011 | Sanyo DP46848 LCD TV
Only getting some channels to come in...
Check your latest phone bill and see if you have a basic extended package. If you dont you may have been downgraded to only get basic cable which is 2-13.
The auto program adds every channel that the television can detect.
Jan 04, 2009 | Sanyo DS25390 TV
SONY KV32V16...can't get all my cable stations.
I called our cable company about getting a converter box and it ended up I didn't need one after all. The cable rep told me to go to the menu and try the auto-programming. He was familiar with the TV I have and said that a converter box is not necessary. So, I tried the auto-programming and still didn't get all the channels...then I noticed on the menu for the channel set up there was the word "Cable" and after it it said "Off" so, I switched that to "On" and did the auto-programming, and Presto! I got all my channels.
Dec 25, 2008 | Sony KV-32V16 TV
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Menu
I think, Your TV menu item to auto-program has been locked. read its user manaul to unlock it. Many companies gives such lock facility in tv to avoid miss use.
Jun 14, 2008 | Sanyo DS24425 24" TV
Televison & Video Logo
705 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
