Question about Vibe Audio Players & Recorders
Is ther susposed to be 2 speakers in a vibe DG 478 mine only has one theres a opening for another speakerbut theres no speaker
SOURCE:
SOURCE: Compaq 5000 series JBL speakers
Hi Shockme17, sorry for late response I have been away. Gently remove the frame holding the material speaker cover by pulling it off from the top (the material speaker cover is just a push fit on the main body of the amp/speaker). Don't use any implement, you may damage the cover. Once you have worked the cover off iy will expose 4 screws holding the unit together. Remove those & the unit splits into two parts. JeffuH
Posted on Sep 08, 2008
sicaudio
  • 96 Answers
SOURCE: man
it is impossible to make a dual 2 ohm sub only be seen as a 2 ohm load with out damaging the speaker. there is a way but if i tell you how to do it, then "WHEN" not if but definately when you blow up the sub you will be ticked at me and expect me to pay for it so i am bound by law not to disclose it. being mecp certified and an authorized distributor makes me liable for any
mis-information. and the only way to do it is the worst way to do it that may possibly even cause the amp to blow or even worse the sub can and most times does actually catch fire inside the voice coil.
you have to have a dual 4 ohm.sub to get a 2 ohm load at the amp
Posted on Sep 17, 2008
  • 132 Answers
SOURCE: Relay
its the headlight relay flasher ie high/low beam
Posted on May 28, 2009
  • 182 Answers
SOURCE: hi how do i wire up my vibe speakers to my vibe
u dont want to wire ur speakers to the subs, either get a 4 channel amp and wire them into it or to ur deck directly.the reason u dont want to that cause ull blew up ur speakers
Posted on Jun 29, 2009
dunnbiker
  • 8546 Answers
SOURCE: no sound to remote speakers in dining & deck areas.
Incoming from WHAT? Ampifiers accept inputs via RCA connections and send amplified audio to the speakers via the + and - OUTPUT terminals.
I'm guessing your colored wires are from your speakers and that there is a piece of this puzzle we do not see - how the speakers on the deck and in the dining area are wired.
You say, "was working ok previously"... previous to WHAT? Something changed.
You can probably troubleshoot and resolve this yourself.
Set the amp to a medium output level.
If the wires are simply leading to either or both pairs of speakers you could select any two of them and connect them to one side of the amp. Only a pair going to the same speaker(s) will produce sound. Once you identify one pair, the other pair probably goes to the other speakers. Connect them to the other channel output.
The last piece would be to establish correct phasing between the speakers. Bass response will suffer if they're not IN-phase. Play something with substantial bass. Listen closely, then reverse the wires on one side only. Test again. If it IMPROVES you have it right. If it losses bass, put the wires back the way they were.
Posted on Apr 28, 2010
What is the wiring schematics for an Infinity Gold Amplifier 56007499?
hi,
if thats a dodge this might be it..
Re: Infinity Gold AMP Wire Diagram
Well I don't particularly care for Haynes manuals, but my FSM's did not have anything either. I found this in thejeep cherokee haynes manual and it says that it is for 97 and later models but see if it is close. it looks like there are 2 harnesses so I will list them seperately:
Hartness 1:
[7] Left Soundbar Speaker (+) BR/YL
[8] Left Soundbar Speaker (-) BR/LB
[5] Left Front Door Spkr (+) DG
[1] Left Front Door Spkr (-) BR/RD
[9] Right Soundbar Speaker (+) DB/WT
[3] Right Soundbar Speaker (-) DB/OR
[6] Right Front Door Spkr (+) VT
[2] Right Front Door Spkr (-) DB/RD
[4] Power Amp Relay Feed DG/RD
Harness 2:
[05] Right Soundbar Spkr (+) TN/RD
[13] Right Soundbar Spkr (-) TN/BK
[06] Left Soundbar Spkr (+) WT/TN
[14] Left Soundbar Spkr (-) WT/BK
[11] Passenger Door Spkr (+) LB/RD
[10] Passenger Door Spkr (-) LB/BK
[04] Drivers Door Spkr (+) DG
[12] Drivers Door Spkr (-) LG/RD
[01] Power Amp Feed
[02] Power Amp Feed
[07] Power Amp Ground
[08] Power Amp Ground
The tweeters run in parallel off of the door speakers.... If I can help any more let me know.
-Mike.
https://forums.off-road.com/jeep-mid-sized/105694-infinity-gold-amp-wire-diagram.html
Oct 01, 2018 | Infinity Car Audio & Video
Vibe DG-478
Why didn't you read the instructions?
Pairing Bluetooth Devices
Posters often ask "How do I pair my Bluetooth ???" Insert whatever device you have at the question marks.
Generally, you need to read the instructions for the camera, headset, speakers or whatever the Bluetooth device is.
Roughly speaking though.
Settings - Bluetooth - Search, on the Android, iPhone, Windows phone whatever.
With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. On my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it. This is the part people usually don't do and ask for advice, thinking it will do this automatically.
When the Android device recognises it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes).
Posted by Andrew... on Nov 19, 2016
Dec 10, 2016 | Cars & Trucks
My UC-280 speakers worked well for last 5 years. But now wire connection to the left side speaker has broken. Now I need to open the speaker to fix the broken wire connection. I could not find any screws...
first,i never seen uc 280 speakers & dont know if it is a wood or a plastic speaker enclousure. 1. try looking 4 screws again, you might have missed them 2. if you sure there are no screws,you may have a plastic speaker box that was put together with crazy glue. in that case you will have to look for seams to crack or pry with two large flat bladed screwdriver or two very stiff puddy knifes. if you cant find a seam good enough to get a screwdriver into to start the pry job, you will have to take a stiff thin bladed knife that you dont mind ruining the looks of and heat the blade
red with a propsine tourch $12.00athome depot or a gas stove
burner will do & saves you $12.00. even an electric stove burner might work if you put the knife blade on the burner & a heavy black cast iron fry pan in the top of the knife blade.
anyway,one you get the knife blade or flat screwdriver tip hot,you can ment a slot through the plastic enough to get a pry started.
by now you realize that we are going to make somewhat of a mess of your speaker box, but if it is crazy glued together,this is all that can be done about getting it apart.right now,you dont have a working speaker. you may end up with a working speaker that looks like it survived world war 3 in bad shape, but best I can do,so sorry.if you can pry it appart enough to get inside and reconnect the wire, the test to make sure speaker does work,we ate ready to glue it back together. A hot melt glue gun from you local dollar tree or dollar store will do the trick or a tube of crazy glue.alternately,you can use the engineering llc solution
which is ,if its susposed to move and dont, use wd40 but if its not susposed to move but does,use duct tape.
so you can use a good grade of duct tape to hold your speaker box together with,if need be.
in the past,we have used hot melt glue gun to reattach the plastic front of a vw passat so it would be flush with the front fenders when a sheet metal screw didnt work good. used the hot melt to keep the sheet metal screw from coming out and to hold the edge of the plastic in flush to the fender edge. god help who ever takes that apart again. hope he is a good problem solver because that vw solution was from mickey mouse enginenering, llc
Oct 13, 2013 | Audio Players & Recorders
No matter what i do, my speakers sound very basey, ther is no mid or treble and tried everything 2 correct it through my mixer 2 no avail, is ther sum setting that is needed 2 correct this problem
This is not likely to be an amp problem unless there is a built-in crossover. I don't recall if the 26oo has that option. Check for that first. Other than that, you probably have blown tweeters in the speakers. Check the speakers and update this with your findings.
Dan
Nov 25, 2010 | Peavey Pv 2600 Power Amplifier
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;MY SPEAKERS DO NOT WORK IHAVE ASUS 478
Are the sound driver loaded?? They are on the mobo disk....if so borrow some speakers and plug into the GREEN port on mobo
May 12, 2010 | Intel ASUS P4SC Socket 478 Pentium 4...
How do you mount new speakers in the front doors of a 2004 Vibe
Hello vobsterman,
While some new speakers do not match up directly in the vehicle mounting location, the procedure for mounting them is basically the same. First of all, you need to make sure that your speakers are the proper size to fit your vehicle. If you do not know what size your old speakers are, you can usually find out at www.modifiedlife.com. Then for a list of speakers that fit, go to Crutchfield's "outfit my car" and enter the vehicle information. If any special adapters or spacers are needed, the Crutchfield site will detail them. If you purchase speakers from Crutchfield, any mounting accessories and adapters are included free.
After you have your new speakers, remove the old ones using the instructions contained in the supplied "master sheet" for your vehicle and replace them with the new speakers.
Hope this helps.
Jul 15, 2009 | Vibe SA40 Car Speaker
Hi how do i wire up my vibe speakers to my vibe sub
Jun 26, 2009 | Kicker KX500.2 Car Audio Amplifier
Wire color codes for '95 Ford stereo
i will post 96 Taurus. Not sure if the same as 95. you did not say which radio you have, base or premium.
please rate as fixya if this is what you need
Base Audio System With/Without Cassette Player
Pin Number Circuit Circuit Function 1 729 (R/W) Battery Feed 2 57 (BK) Power Ground 3 434 (LB/BK) Pulse Width Modulated Illumination Signal (Analog) from Headlamp Switch 4 1002 (BK/PK) IGN/RUN/ACC 5 640 (R/Y) IGN/RUN/START 6 694 (BK/LG) Logic Ground 7 — Not Used 8 — Not Used
Pin Number Circuit Circuit Function 1 593 (DB/W) Tape Audio RH + 2 594 (GY) Tape Audio RH - 3 57 (BK) Ground 4 833 (T) Audio Communications Protocol B 5 1068 (LG/BK) Audio system ON 6 723 (GY/R) Phone Wake Up 7 — Not Used 8 59 (DG/P) Rear Defrost 9 503 (BR/LG) Tape Audio LH + 10 504 (W/PK) Tape Audio LH - 11 — Not Used 12 832 (LB/PK) Audio Communications Protocol A 13 — Not Used 14 — Not Used 15 1010 (DB/O) Heated Back Window 16 — Not Used
Pin Number Circuit Circuit Function 1 803 (BK/PK) RH Rear Speaker (-) 2 802 (O/R) RH Rear Speaker (+) 3 811 (DG/O) RH Front Speaker (-) 4 805 (W/LG) RH Front Speaker (+) 5 801 (T/Y) LH Rear Speaker (-) 6 800 (GY/LB) LH Rear Speaker (+) 7 813 (LB/W) LH Front Speaker (-) 8 804 (O/LG) LH Front Speaker (+) 9 — Not Used 10 747 (R/PK) Power Antenna (Up Signal) 11 — Not Used 12 694 (BK/LG) Ground 13 694 (BK/LG) Ground 14 720 (R/Y) B+ Supply
Mar 06, 2009 | 1995 Ford Taurus
Need wireing schamatic for 1988 ford ranger (audio)
LG/Y --Power
Y/BK --Ignition
BK -- Ground
LB/R -- Illumination (+)
Or/Bk -- Illumination (-)
DG/O -- Right door speaker (-)
W/LG -- Right Door Speaker (+)
O/LG -- Left Door Speaker (-)
LB/W -- Left Door Speaker (+)
If it has rear speakers:
O/R -- Right Rear Speaker (+)
Bk/W -- Right Rear Speaker (-)
PK/LG -- Left Rear Speaker (+)
T/Y -- Left Rear Speaker (-)
Hope this helps
Feb 24, 2009 | 1988 Ford Ranger
22 people viewed this question
Top Vibe Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Vibe Audio Player and Recorder Expert? Answer questions, earn points and help others
