Question about Sony KDS-R50XBR1 50" HDTV
Power switch on/off every 2-3 minutes
I purchased the TV on May 06, and all the sudden a week ago it started to have on/off switch every 2-3 minutes. Now it is unusable. I tried to unplug/plug again multiple times but it doesn't help.
  • oak139jv Dec 03, 2007
    Thank you very much. I changed the lamp and problem disappeared. TV works fine now.
My tv also experienced this... changed out the lamp and resolved the problem
Posted on Nov 28, 2007
Le2412 power on problem
The power supply is failing.
Dec 20, 2013 | Apex Digital LD4088 LCD TV
Wharfedale TV power problems
the problem occurs in ur main board...check all tge resistor in board...the faulty resistor will; allow high voltage to the main board and affect it
Oct 31, 2008 | Televison & Video
About 2 weeks ago my dell 42" plasma started
change your tv main board, your tv board was broken
Jan 16, 2011 | Dell W4200 42 in. HD-Ready Plasma...
I purchased an Sony Bravia LCD 26 inch of KLV S200A series 3 years back. The LCD has now started developing problems like automatically the power goes off when any particular channel is being viewed and...
You have intermitant problems which may be caused by contact resistance or circuit overheating.After it cooled down the tv starts again. Leave TV on standby at all times.
Jan 03, 2011 | Sony BRAVIA KLV26S200 26 in. LCD TV
I bought a 19" element
Is a tv power glitch,shutdown,start again,tv have no problems,wright?Not a problems,if only happen one?If it happen many times,tv have power supply board problems,take ur tv warrenty repair or return ur tv,where u bought it,get a new tv replacment.
Nov 23, 2010 | Element ELC-HS321 32 in. LCD TV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Smoke coming from the back
power board shot. remove power board and purchase the exact board with the numerical stamp on the board usually 12-16 characters. make sure it matches, replace board and reasemble tv and enjoy.
Jan 30, 2009 | Astar LTV-3201 32 in. LCD Television
All TV's in house failing, a few at a time
Hey PNorris,
If multiple electronic devices are failing in your home all at once, I would probably first have to ask if your home recently experienced an electrical storm or major power surge of any kind.
Normally the effects of such large-scale surges are immediately noticeable - TV's and other major electronic devices may fail to turn on, fuses may be blown or circuit breakers tripped, and in some cases electrical wiring may be melted.
If nothing like this has happened recently, low-level power surges may still be a potential cause of this problem. When the motor from any large appliance (such as an air conditioner or refrigerator) turns on or off, it often diverts power to and from other electronic devices using the same circuits. This fluctuation in electrical current may result in low-level power surges to every connected device. While not immediately noticeable, these low-level surges can often cause the eventual failure of (and gradually degrading quality in) many audio/video components.
Typically, the easiest way to avoid situations like this is to make sure that outlets are not overloaded and surge protectors are used with every major electrical device in your home. For older homes however, replacing the house's wiring may be necessary. Homes that were originally built at the turn of the 20th century may not always have wiring capable of supporting the electrical needs of many modern appliances.
Ultimately, this means that in addition to contacting your local TV repair facility, you may want to also speak with an electrician. This is probably the best way to determine whether or not power surges have caused these failures, and may give you a better idea how to proceed.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Apr 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony KDS-R50XBR1 50" HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
