Locking washer came off the bottom of MoJax and how do I get it back on?
How to manually open locked door
First UNPLUG the WASHER.
There is a little white circle plastic lever that feels like an upside down lollipop about 2-3 inches below the door lock behind the front panel.. Pulling that down will unlock the door.
To access from the top of the washer remove 3 screws to the back top of the washer, push it back and then lift the top off the washer. Facing the washer slide your right hand down the space at the front corner where the lock is located. Feel around for the circular part at the bottom of the door lock and gently push it down. The door should then manually click and unlock.
To access from the bottom of the washer. Facing the washer, Remove the 3 screw to the very bottom that is holding the small access panel in place. This allows access to the bottom of the washer. Once removed, reach towards front and upwards to where the door lock is located. Feel around for a circle plastic level. Pull the level down. The door should click and you should be able to open the door.
Apr 18, 2014 | Maytag Washing Machines
Error code f-28
F28 means your washer is locked and not unlocking. To unlock your washer take off the bottom access panel by removing the 3 bottom screws. Reach up near the latching assembly & attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Click if helped.
Apr 30, 2013 | Kenmore HE2 Washing Machines
My washer say f28 it is a kenmore HE2 plus
"F28" means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.Reach up near the latching assembly & attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thank you!!
Jul 18, 2010 | Kenmore HE2 Plus Front Load Washer
F28 code
Thank you!!
Jul 05, 2010 | Kenmore HE2 Plus Front Load Washer
My door lock has locked with the door open , how do i get it to unlock ?
There is a manual unlocking tab located at the bottom of the door lock and switch assembly. Disconnect power to the washer before accessing it.
Remove the three screws attaching the toe panel to the cabinet then pull the panel down and off the cabinet. Prop up the bottom front edge of the washer or cushion and lean it against the wall for an easy access of the screws.
Reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side.
Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel.
Secure the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an HE3t and can't get the door to open. I have tried rewashing the load that is in there, and I have set and unset the lock. What's going on?
Try unplugging the washer for 10 minutes, plugging it back in and test to see if the door will unlock. If it doesn't then you have a bad door lock mechanism or contol board or both. You usually can manually unlock the door by removing the bottom front panel, with the washer unplugged, and reaching up into the door lock mechanism. There is a tab or ring on the bottom that you pull to release the door. Open the door and look for broken plastic pieces on the door strike or in the latch on the mechanism. Usually you won't see anything. If no broken pieces then remove the top panel, washer unplugged, and find the ccu. This is the main control board located in the back center of the machine. Check for loose connections at the ccu and for broken wires. Jiggle and push the wiring connectors into the ccu to make sure they are tight. Plug washer in and test to see if it started working. We have had a lot of repairs with this ccu unit as the relays on the board have a bad weld that gives an intermittent connection, causing this repair. If the washer works by plugging these connectors in tight then put it back together and use it. If it fails again then replace the ccu. In some instances the door lock mechanism can be bad. Unfortunately there is no good test for this. To replace the lock mechanism, you remove the top panel,(washer unplugged). Open the door, remove the three screws that hold the lock mechanism to the cabinet, unplug the 3 to 4 wiring plugs from the lock mechanism and install the new assembly. Good Luck, Appliance Specialists
Jan 04, 2010 | Kenmore HE3T Washer
F-28 code
F28 means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.
Reach up near the latching assembly & Attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 28, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore elite washer control lock on and can't use washer
There is a manual release. You can either take off the kick plate and reach up from the bottom, or take off the top and reach down. It's a teardrop shaped plastic tab coming out the bottom of the lock mechanism, and you just pull it down.
May 24, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
