Question about Refrigerators
My side by side fridge isn't cooling. Lights on the inside of the fridge will come on, but on the door where the ice/water dispenser will not work.
The panel on the door where it tells the temperature (above the ice/water dispenser) will not come on and the dispenser itself will not work. The freezer will not freeze or anything.
  • 692 Answers
Before you spend a lot defrost/ unplug. lets the ice in the crossovers melt. plug it back in and see what you get.
mike
Posted on Jun 12, 2019
Testimonial: "It's been unplugged for days and it doesn't still doesn't work. But the lights on the door and the ice/water dispenser wouldn't quit because it is frozen up and needs defrosting, would it? That would be an electrical problem I think. A friend told me its the fan motor, but I don't understand how that has anything to do with the lights and stuff either."
  • Tiffany Root
    Tiffany Root Jun 13, 2019
    Sorry, I was trying to make that a comment, not a testimonial lol
SOURCE:
  • 1462 Answers
SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Posted on Mar 20, 2007
SOURCE: Freezer Not Freezing and Water Not Working
similar problems however check the connection to the fan motor, one of my connection to the motor was rusted off.
Posted on Oct 02, 2007
  • 958 Answers
SOURCE: Kenmore refrigerator
hi fperry74,
please look at the back bottom part of the refigerator , if you could see a small condenser fan there. it might not be running or running very slow. correct that problem then.
that is why your panel is very hot because a condenser line passes thru that panel and if the fan is not running, then the temperature gets very hot.
the efficiency of the fridge is also affected.
i hope i was able to solve your problem.
pls rate me.
tnx
drcool
Posted on Jul 23, 2008
larryyb
  • 291 Answers
SOURCE: Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
Posted on Nov 25, 2008
SOURCE: Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Posted on Feb 20, 2010
Fridge isn't cooling
Its defrost issue.The defrost assembly parts are not functioning right causing the problem.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Kenmore Side by Side Refrigerator
The ice dispenser and water dispenser on the door will not work
"Prepare for the worst" This is a problem i'm currently dealing with at the moment, ice maker thaw'd and refroze the ice as a block, binding the crusher turbine till it quit working. then water dispenser started spitting till it quit working, but anyway i disconnected the ice maker and water dispenser power hookup, because when i tried to use it it was drawing off the power of the fridge. now i'm to the point where fridge clicks like the relay is going out. in the back of the freezer below the ice maker tray i removed the clip or screw to where when it clicks i can hand spin the cooling fan on the click, and fridge starts up and runs, but don't remove this panel because having it on helps the air push into fridge compartment and keeps cooling elements from turning to a block of ice, " so long story short " its either your cooling fan or relay on chip board that starts cooling fan, i'm no expert but this is where i'm at hope it helps.
Jan 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Amana side by side with ice/water in the door freezer stops freezing about 8 yrs old
First of all the worst thing you can do is set your fridge on the highest setting even though it has it. That's live reving your car to the red line just because it has it. As far as your challenge is concerned, it sounds like a breach in the seal of the fridge or dispenser. Check to see if the ice despenser is closing properly after use and check the door seal to make sure it's closing tight when the door is closed. To do this, simply inspect it for any bad wrinkles, cracks, folds, etc. if none are visible close the door on a dollar bill and make sure it holds securly all the way around the door. I f it doesn't, the seal may need to be replaced and/or the door is warped. If you continue to have issues, post again, we will work this out.
Jan 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker works but water won't dispense
There is a know defect with the freezer side door. read more at http://www.houstongofarappliancerepair.com/Refrigerator.html
Also, If you call and haggle GE they may send you a new freeezer side door. Or, You may actually try turning fridge off, leaving door open for about 4 hours and then try it again. As strange as this sounds it has worked for some of my customers.... When "air-bubbles" get into that line it can freezer inside the door a small section of water line because the insulation in freezer side door isn;t thick enough... More can be read on this problem at http://www.houstongofarappliancerepair.com/Refrigerator.html
goodluck...
Dec 01, 2008 | GE Profile PSW26P Stainless Steel Side by...
My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
Nov 14, 2008 | GE PSS26SGRSS Stainless Steel Side by Side...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water/Ice Dispenser Does Not Consistently Work
Sammy, I am having the same problem with my 695. I have a call into subzero service and will let you know what I find out.
Thanks for your help as it fixed my problem as well, albeit temporarily.
Alan
Jan 12, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
