I get the error message check SP Wire only when Bluetooth is connected to receiver. When I have the Radio on the receiver I do not have a issue. Just with Blue Tooth
Hello Anthony, try your Onkio, with other sources of sound, example DVD or CD and check that the sound is clean and shows no error
Then, look for another player with Blue Tooth connection and try, if you have the same error, you may have to update the Firmware
You go on the Onkio page and you search in downloads and by type of equipment and model, then you download it in an empty Pen Drive, without any file type, then you place it in the Onkio and download it
If this does not correct the fault, I suggest you look for a specialized technical service
Greetings Franco Dosil
Hola Anthony, prueba tu Onkio, con otras fuentes de sonido, ejemplo DVD o CD y comprueba que el sonido sea limpio y no muestre error
Luego, busca otro reproductor con conexi?n de Blue Tooth y prueba, si tienes el mismo error, puede ser que tengas que actualizar el Firmware
Entras en la pagina de Onkio y buscas en descargas y por tipo de equipo y modelo, luego lo descargas en un Pen Drive vaci?, sin ning?n tipo de archivo, luego lo colocas en el Onkio y lo descargas
Si as? no se corrige la falla, te sugiero busques un servicio t?cnico especializado
Saludos Franco Dosil
http://www.onkyo.com/manual/txnr737upg/adv/en/index.html
https://www.es.onkyo.com/downloads/2/6/7/9/5/Manual_TX-NR737upgspo_BAS_En.pdf
https://www.es.onkyo.com/es/articulo/actualizacion-del-firmware-para-el-tx-nr737-119677.html
SOURCE: No video through HDMI section of Onkyo TX SR-805 receiver
My has problems with losing video on HDMI, component, or svideo, this is a piece of you know what!
SOURCE: cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
SOURCE: Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
SOURCE: How do I connect my bose 901 active equalizer to a onkyo tx-sr506
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
