Question about Ricoh Office Equipment & Supplies
Hi, I’m Elvis. Just bought a Ricoh Aficio MP C2550 from a friend’s shop. He was using it when I bought it, I got to my shop and having problems printing with it. Problem is, when networking it, the computer can’t locate the IPv4. If I punch in the ipv4 too the computer can’t locate the printer automatically. I have to select it manually. Hence after installing if I issue a print command it doesn’t print
    Sergeant:
  • 256 Answers
So many things missing here....
network addresses being used, drivers being used, operating system being used, DHCP or manual IP
Posted on Jun 12, 2019
5 Suggested Answers
SOURCE:
SOURCE: Ricoh Aficio 450 paper format printing problem
This could be a few things, first thing i would try is to go in page setup under the program you are using and make sure paper is set to auto select (File>page setup). The program will override the print driver.
next make sure the driver setting (paper source) are also set to auto. make these changes by right clicking on the driver>printing preferences.
third I would go to the copier, Make sure the tray are set to the proper paper size and the display paper size matches the tray
Posted on Dec 28, 2007
prashanthcl
  • 460 Answers
SOURCE: Ricoh printer printing error: undefined offending command: mz
it is a logic card problem. so pls checked it from service center.
Posted on Aug 25, 2009
  • 114 Answers
SOURCE: Can't print color or use finisher on our network ricoh from Mac
Sounds like you may not have the correct driver installed and also not configured right for devices
Posted on Mar 19, 2010
SOURCE: ricoh aficio mp 1600 L printer driver has been
E000002-0000 le code panne ci dessous
Posted on May 28, 2010
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
I have 2 accounts and I need to get a count for each account. How do I do that?
  1. the web image monitor is the easiest under the address book which means you must log in & It has to be networked.
  2. Under the counter in system settings the counters should be separated.
Mar 06, 2014 | Ricoh Aficio Mp C2550 Copier
Dec 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio MP C2550 does not default to one to one copy after use for 2 to one (front to back) the next person to use it gets charged for 2 copies when they only wanted one.
The machine should be set up so that it resets each and every time the card is ejected.
You might find the setting in user tools, but some where on the machine there should be a setting that resets the machine upon card removal. typically machine are set to reset after so many seconds of inactivity, but on coin and or card controlled machines you want the reset at card removal. You may have to have your service tech come in and set it up as it may be in Tech settings, if not in usee tools on your machine.
Hope this is of some help.
Ed
May 06, 2009 | Office Equipment & Supplies
Open Questions:
54 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
