Question about Refrigerators
I have an model 83ss raritan icer-ette ice maker on my boat. it seems to work however it allows more water into the ice cube tray and i always get a 2 inch cube of ice in the holder. Cures?
    Sergeant:
  • 256 Answers
How old is the unit? The water delivery pump and hoses will wear out and leak over the years of service. This will happen to ANY icemaker product (refrigerators, etc)
Posted on Jun 12, 2019
SOURCE:
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Raritan icer-ette only filling 5 of 8 slots in ice mold
They marine ice makers are fussy. The ice maker needs to be level or water will drip down into the ice bin. The amount of water entering the tray is controlled by time. The other factor is pressure. The marine water system has a relatively low water pressure as compared from marina water feed.
I would confirm the number of cubes produced from the unit when connected directly to the city water pressure. If at the highest pressure it is below expectations I would follow the video. How Do Adjust an Icemaker Home Appliances
There is a screen filter before the solenoid line that can fill with debris. So you may need to check it if you can not make a satisfactory adjustment.
If you are like me and always work form the internal water tank avoiding a burst water line and "sink the ship" then adjust it for the lower pressure.
Happy Sailing
Dec 09, 2015 | Raritan Icer-ette Ice Cube Maker
Compartment only gets to 32 degrees. compressor runs,fan runs,water valve ok refrigerant ok doesn't get cold enough to activate water valve to fill tray.could it be cold control-relay-compressor ???
Ok 32 deg is freezing. If compressor is running and condenser fan is running and refrigerant psi is good then lets check Malfunctioning water valve assembly, check to see if you are getting water to water valve if so then check to see if you are getting power to water valve. Check mold heater, you don't want mold heater on at this time. It sounds like you are having a water or water valve issue.
Oct 26, 2013 | Raritan Icer-ette Ice Cube Maker
Ice assembly mould has lost its teflon coating
Cheaper to replace machine than to replace plate.
Oct 05, 2012 | Raritan Icer-ette Ice Cube Maker
My icemaker will get cold but wont make ice.
Hi and welcome to FixYa, I am Kelly
Here is what the manual says:
3. Icer-ette freezes but water does not come into mold; no ice production.
_____________________________________________________________
3A. Nonfunctioning water valve assembly. 3A. Clean or replace solenoid valve assembly.
3B. Mold heater assembly. 3B. Contact Raritan Technical Support.
3C. Water supply turned off. 3C. Provide pressurized water.
3D. Icemaker module. 3D. Replace icemaker module.
3E. Cold control. 3E. Replace cold control.
3F. Bad wiring harness plug contacts. 3F. Contact Raritan Technical Support.*
Although this is for troubleshooting non optical sensor refrigerators:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The troubleshooting procedures for cycling the unit are exactly the same,
The ice maker module part number for the 120V unit is PN 628366 (do a net search for this part number and save yourslef a bumch of money if you fetermine your moduleis bad) You start the harvest cycle by removing the front cover and then jumpering test points T to H. The white dial will begin to move if there is power to the module. Remove the jumper when the sweep arm reaches 5" o'clock and let the ice maker automatically cycle. It should harvest, and fill in on complete turn of the white dial. If it does not fill you probably have a water supply or water valve problem. There is an inline input power fuse for the ice maker. Power should come in via the red wire.
Mind you the ice maker has an internal thermostat behind the module assy that has to reach 15 deg F to start the harvest cycle. When you jumper T to H you are bypassing the thermostat. If the thermostat fails or the unit does not reach 15 deg F then the harvest cycle will never begin.
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Raritan Icer-ette Ice Cube Maker
Unit runs but no ice.in searay boat fan does not want to come on. Unit runs. .Live in chatham ont. canada. what to do. dave @beams56@yahoo.com
My unit turns on works for a while then shuts down, fan would not re-start every cycle, causing over heating and shut down, cleaned the fan, oiled the bearings, cleaned all the elec. connections, seems to work now.
Jul 15, 2010 | Raritan Icer-ette Ice Cube Maker
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Jul 19, 2009 | Daewoo Refrigerators
Uline icemaker must be manually prompted to rotate and drop cubes
If your looking for a icemaker it should be part 402. Call U-line with the serial or model number to be sure they made it.800-779-2547
Feb 24, 2009 | U-Line Icemaker
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
