Question about Refrigerators
We have a RQ689N4WF1 Hisense American fridge freezer and it keeps making a loud clicking/clunking noise. Does anyone else have this problem please. This is 1 month old
    Top Expert:
  • Refrigerators Master
  • 25,081 Answers
Warranty call for service check
Posted on Jun 12, 2019
Testimonial: "All i want to know is if other people have the same or similar problem but thanks"
SOURCE:
bobotfel
  • 241 Answers
SOURCE: Can you Help?
Check your blower inside the unit, blower frame may be deformed causing the blower to touch the frame make some noise.
Posted on Mar 07, 2008
  • 66 Answers
SOURCE: Kenmore fridge, about 8 years old, making noise
The compressor on your fridge is mounted on rubber grametts and inside the dome the internal parts the do the pumping of the refrigerant are mounted on springs. When a compressor gets old some people complain about two much vibrating, this could be the rubber grommets the support the compressor. When one of the support springs inside the compressor is broken it will have a distinct rapping sound when the compressor shuts off. There isn`t anything you can do about this, short of replacing the compressor. It will eventually get worse untill something is seriously broken inside the compressor and the compressor will die. You may want to consider replacing the compressor now or purchase a new fridge. You will need to consider the cost of both and the age of the fridge" Is it worth repairing?". You can actualy find a repair company in your area from this site if you like, and compare the costs.I hope I have helped explained the problem well enough for you. I will help you as much as I can.
Posted on Nov 16, 2008
  • 15 Answers
SOURCE: fridge makes a fairly loud humming noise when I close the door
it sounds like your refridgerator might be unlevel try adjusting the legs all the way down to start then level to floor if that doesnt fix it its probably the rubber gromet under the compressor usually there is four of them if one comes out(usually after moving it makes your compressor vibrate you can use almost any gromet of of any junk refrigerator or if you want you can by original replacement parts at one of your local appliance dealer
Posted on Dec 18, 2008
rpbuice
  • 161 Answers
SOURCE: Have a whirlpool side by side american fridge freezer,,
If the fan in the freezer is working.
You can hear this fan running when you open the freezer. Then I think the noise you hear is the fan hitting an ice build up.
This is a failure of the defrost system.
Posted on Dec 21, 2008
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Posted on Sep 20, 2009
Compressor is making very loud clunk when shutting off.
I think the wire was kinda expensive. If I were you I would try to save the fridge. I think you should unplug it for a couple hours, take everything out for a while and remove any ice. Once the fridge reached room temp, the refrigerant should have made its way back to the compressor. Plug it back in and see if it makes the noise again.
It might just be the fan in the freezer. I would try the unplug/deice for a few hour method first because it is free before you try to replace a fan that might be bumping ice. Good luck!
Mar 10, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
Loud clunking noise underneath fridge
its sounds like a spring is broken inside your compressor this you cannot repair you need a commpressor replacement or you can check if your fridge is levell sometimes by levelling the fridge it may reduce the sound thans from gilles
Dec 10, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Cake Display Freezer Compressor keeps freezer cold
Maybe the guy meant the compressor is going bad.
Jul 24, 2017 | Traulsen Reach in Freezer - G12010
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
