Question about Canon Office Equipment & Supplies
Canon Pixma MP760 printer, i get error code 2.178.0 half way through scanning a doc.
    Sergeant:
  • 256 Answers
Posted on Jun 12, 2019
Testimonial: "no help at all you have done is direct me to my Canon inquiry"
  • SSN-MM3 Jun 12, 2019
    ok, let me an a55 about it since that question on that site was posted 2 MONTHS AGO.......
    what OS?
    what drivers?
    what other programs were you running?
    what kind of network setup do you have?
    list the devices you have that control the network?
    submit a transcript of all troubleshooting conversations you have had with Canon?
3 Suggested Answers
SOURCE:
  • 479 Answers
SOURCE: canon mp760 printer overflow full, have parts and service manual. Need code to get going again
there is no need to change the ink absorbing sponges at all ,,as i hve solved this problem myself for many of my clients i m sure that it will work for u too if followed properly step by step:
It could be due to "waste tank full" alarm; you may need to reset the waste tank counter.
reset sequence for a MP760 printer that works for F30 and F50 as well. Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
ur printer absorber will reset and will work properly and u will be back to work.try doing it one more time if u miss something .
please take a moment to rate the solution after u get ur problem solved
Posted on Oct 03, 2008
SmartFix
  • 89 Answers
SOURCE: Canon Pixma MP760 no error code
First you must remove the printhead and power on again, if it only has printhead error then printhead is the culprit. Otherwise you must press a key sequence to display the numerical error code and know what part of the printer is failing, purge unit, feed assy, or dirty encoder strip.
Please rate my response!! Thanks, SF
Posted on Jan 28, 2010
Jan 28, 2010 | Canon Office Equipment & Supplies
Can not photocopy
once scanned a document needs to be save din a file format that the PC can read..doc docx..pdf..txt..go into Word or whichever word processing app you use and click import, from TWAIN device
Jul 23, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Can't work out how to scan multi pages to one file Canon Pixma MP
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=11010#DownloadDetailAct
This is a direct link to the download page for your manual. Please rate me if you found this useful.
Jan 16, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Canon Pixma mp760 - won't power up or initialize
I found this on another forum it'll clear the EEPROM so give it a go.
MP750 / MP780 waste ink counter reset instructions..
1. Service menu: Menu -> Scan -> Copy -> Scan (one at a time in sequence)
2. Select "TEST MODE"
3. Select "[8] ETC.."
4. Select "[4] EEPROM CLEAR"
5. Select "[1] INK COUNT"
6. Press the [OK] button.
7. Press the [Stop/Reset] button (returns you to the TEST MOD sub-menu))
8. press the [ON/OFF] button (which resets the printer)
TIP: Don't rush the printer as it can often take considerable time to respond to your commands. Frantic button pressing will just push the printer into snail mode (ie: slow as heck!).
Patience :)
Hope that helps... :)
try that, i stole it off http://www.stevesforums.com/forums/view_topic.php?id=87060&forum_id=40 <http://www.stevesforums.com/forums/view_topic.php?id=87060&forum_id=40> -----
Feb 17, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Canon pixma mp760
OK help for Canon PIXMA PM760 drivers, try this web addy below, it should be able to get you along the road to recovery. I havent seen any web address promoting the full setup CD, which has the actual setup routines. Perhapse if there is such a CD avaliable it ........ http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=11010
Just double click the above addy and it will take you stright to what yoou need.
Dec 12, 2007 | Canon PIXMA MP760 All-In-One InkJet...
Canon Mp760 Error 2,178,0
unplug the scanner for a few seconds and plug it back in
Apr 28, 2007 | Canon PIXMA MP760 All-In-One InkJet...
41 people viewed this question
Clive
Clive
old marine
old marine
