On my washing machine the pump is rusted on and I can t get off I sprayed with lib model number lsr7233eqo
    Master:
  • 178 Answers
Washing machine drain pump. The pump mounts directly to the motor with two clips. If the washer does not drain then the pump could be locked up or a small object may be clogging it. A small leak in front of the washer could be caused by a defective pump.
OEM Part - Manufacturer #WP3363394
How to get to your pump;
Posted on Jun 12, 2019
SOURCE:
huuum
  • 750 Answers
SOURCE: Kelvinator Chest Freezer will not cool after spray painting rust spot.
Dear Landport2
Welcome to the site,
You said, you have a Kelvinator chest freezer, model number CFS101SM1W. This freezer is in excellent condition and was working ok. I notice that there was a rust spot on the bottom area so I decided to spray paint the entire inside with the appropriate appliance spray paint. After spray painting the freezer will not cool.
How old was your freezer?
This must be an ancient freezer!
And Unfortunately I was not able to tell you to leave it alone and not to turn it off!
You did not cause this!
Unfortunately it was so old that it probably was already on it's last legs.
Here is an interesting report I just read!
Repair or replace your appliances?
When to pull the plug on your old freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model ?
The answer depends mostly on the age of your ,freezer
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old freezers),
paying for a repair makes sense.
Note that freezer under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your freezer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new freezer.
Data also shows that it doesn't pay to fix a less-expensive freezer
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a freezer you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Oct 10, 2008
  • 2336 Answers
SOURCE: prevent Rust
spraying deisel on it will not keep it from rusting it will damage the bike
Posted on Nov 10, 2008
SOURCE: Rust
Yes, Agreed! Do not wash the bike like a car. Wipe them down. Water is the enemy of any bike - especially the electronics and conections. Use silicone spary to keep water form penetrating and cause problems. Silicon will also preserve rubber and plastic parts. But, Be careful! surfaces will become slippery, such as seats, tires, grips, etc.
Posted on Jan 01, 2009
  • 1531 Answers
SOURCE: Rusting lid on top-loading Kenmore Washing Machine
that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
Posted on Jan 23, 2010
jsrock516
  • 5911 Answers
SOURCE: I have a 2005 Whirlpool
The most common cause of the symptoms you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the initial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that may not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are tight. Sometimes these screws will loosen, causing the lid switch make intermittent contact. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list, include helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The lid switch and associated components are usually listed under the "Top and Cabinet" parts listing.
NOTE: Banging or slamming the lid can actually cause more harm than good. These switches are fragile and can break easily in this manner.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. The lid strike (if equipped) usually costs less than $5. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
The part numbers for the model you have listed are as follows: LID SWITCH 3949247, LID STRIKE (Actuator) 358684. If you have questions, please post back and let me know. I hope this helps you.
NOTE: If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you
Posted on Mar 31, 2011
Hi we have a Simpson washing machine mod No swt704 Date 12.06.2012 it's all rusted out my 5 years warranty don't cover this
its a sad day but apart from paint and other
there is very little you can do,.. metal rusts and there is nothing you can do ...i would just spray the affected areas with art shop fixer spray its cheep and a good few coats of it will stop it further rusting
you should use some different grades of wet and dry sand paper to get back too the metal
some masking and primer spray
then a good few tops coats
not much else too add..
Feb 08, 2015 | Simpson Washing Machines
How do I fix extensive rusting under my 2003 nissan pathfinder, I am really worried, please what do I do?
There is a paint on rust converter . You paint it on the rust and it turns it back into metal . After that i would spray the rubberized under coating to protect it.
Nov 19, 2014 | 2003 Nissan Pathfinder
Motor wont run onwhirlpool washing machine lsr7233eqo
Check the voltage to the motor during the wash cycle and if present the motor has failed, check the capacitor if the motor is humming or getting warm. If there is no power then the controller unit is faulty.
Oct 03, 2013 | Whirlpool Washing Machines
Rust under lid and top of barrel.How do I open up the machine to remove rust and paint?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0117d74bc3bdabe782b54341ddab128a
Jan 19, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Need to replace the belt
Spray heavily with coke(soda) and let sit for 24hrs. It should loosen. Used on naval ships for rusted things and somethng in the coke eats away at the metal.
Jun 03, 2009 | Maytag SAV5710 Top Load Washer
Dishwasher not spraying/pumping water in wash cycle
If your dishwasher is filling, draining and the heating element is working then the wash pump motor has probably failed.
You have not provided the manufacturer and model number, so I have no way of knowing if your dishwasher has a separate drain and wash pump motor.
May 03, 2009 | Dishwashers
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
