Question about Toshiba Satellite M105-S3004 Notebook
Power issue Here are the problems:1) Computer works on battery only eventhough it is plugged into AC and does not charge either. Computer shut off when the battery is complete drained. 2) Batt gets charged only when computer is shut off.3) Computer works on AC when batt is taken out although it shuts off time to time.Any help is greatly appreciated.Thank You and have a blessed dayToshiba model # M105-S3004
  • 89 Answers
Sounds like a bad motherboard. What brand is it?
Posted on Jan 11, 2008
Laptopp plugged in not charging
What's your OS? Someone claimed to have resolved this problem following the steps below:Shut down Computer. unplug AC. Take out battery. Plug in AC. Start up computer. Disable Microsoft ACPI CC Method Battery Shut down computer. Unplug AC. Insert battery. Plug in AC. Turn on. Enable Microsoft ACPI.
Then it was working.
Original post:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/gateway-laptop-plugged-in-not-charging/6db4fe50-d318-44da-a938-2fc58f4bbe7b
Of course, there were some different voice on this post. Have a read, and may this help.
Nov 20, 2011 | Computers & Internet
The window is suddenly shutting down everytime i open it, eventhough it is fully charged?
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 25, 2011 | HP Pavilion dv6000z Notebook
Its that the battery is not charging, and on the power meter icon its blinking four times orange and one time green. If I remove the battery, the laptop works with ac adapter. but if I reinstall the...
Check for a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 06, 2011 | Dell Latitude D610 Notebook
Battery not charging
Hi. I would suggest that you powerdrain your computer might fix this. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. If this doesnt work try to powerdrain again the laptop then just use the ac adapter to turn on your computer and that is without the battery. If this one work consider replacing the battery or you call the tech support dept of HP if you are still under warranty so that they would replace it with a new battery without any charge. Hope this helps.
Jun 03, 2010 | HP G60-120US Laptop
Battery problem
all laptops are capable of running strictly on ac power. if your battery is not charging it sounds like time to get a new one.
you can get one here:
http://www.atbatt.com/laptop-batteries/b/toshiba/m/satellite-m35x-s161.asp
Sep 14, 2009 | Toshiba Satellite M35X-S161 Notebook
Acer Aspire 2920 won't turn on, although plugged in with battery
First of all, what I'm about to tell you are general troubleshooting techniques - I make no claim that they will fix what you describe, but they may help lead you to a solution.
  1. Unplug the AC adapter and remove the battery
  2. Plug in the AC adapter and attempt to power on the laptop
  3. If it doesn't power on, see #6 below. If it does power on, but doesn't boot the OS, restart - pressing [SPACE] as the first Windows splash screen appears. When prompted, choose to delete the hibernation file and start a system boot.
  4. Shut the system down, disconnect the AC adapter, reinsert the battery, and attempt to power the laptop. If it doesn't start we know, at the very least, there's a battery problem.
  5. Plug in the AC adapter. If it shuts down immediately, or won't power back on after a shutdown. . .
  6. . . .there's a problem with the system board, probably the ciruitry associated with charging the battery.
I hope you 'see the light'. Good Luck!
Jun 15, 2009 | Acer LXA3706003 Notebook
Getting hot underneth
Both batteries could be dead. But if you bought a new battery, it's unlikely. I don't know what green light you see, but if it's on the power adapter, it just means it's turned on--not that it is charging.
Two possibilities: Your power adapter is bad or the motherboard is bad. Because you say the computer works if plugged in, then you have ruled out the adapter.
You should be checking/cleaning the battery contacts and if all else fails, going for a new motherboard.
Jan 16, 2009 | IBM ThinkPad T22 2647 Notebook
Power will not turn on??
Try this:
1. unplugging the power cable
2. removing the battery
3. plug in power cable
4. switch on and start up
If this works, shut down, unplug and replace the battery.
Hopefully your problem is resolved.
John (Computer Tuition, Blackpool)
Nov 08, 2007 | Compaq Presario 900 /1500 Series EVO...
Help me pls
please check your laptop
working without power ?
if not, remove the battery and refix the battery properly.
eventhough problem persist, battery problem.
Nov 04, 2007 | Computers & Internet
Toshiba Satellite M105-S3004 Notebook Logo
94 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
