Question about Refrigerators
My refrigerator runs continually. I can't find the manual. and we are facing a heat wave. What can I do, to shut it off, short of unplugging it?
Model number MBB1957VEW2
    Master:
  • 396 Answers
I don't know. a quick temporary fix would be to use a timer
[ rated strong enough ] to turn the power off and on for a while every so many hours.
Posted on Jun 12, 2019
5 Suggested Answers
SOURCE:
jumptrout51
  • 3361 Answers
SOURCE: Fan motor on furnace continues running after cycle is completed.
Your fan time delay relay has failed.
Replace it.
Posted on Mar 10, 2009
  • 415 Answers
SOURCE: Carrier heat pump (basic model) runs at 0 or below
A basic model heat pump with an air handler with electric strip heat generally will continue to run with a call for heat regardless of the outdoor air temperature unless there was an outdoor thermostat (an accessory) installed. There is still heat in the outdoor even at temperatures of zero and below. Generally, there is a balance point of approx 30-35degF that allows the heat pump to heat your house to 68degF without the need for the electric heaters. Below that, the heat pump can still extract heat from outside and "pump" it into your house; however, it will need help from the electric heaters. In temperatures below the balance point, the heat pump will run non-stop. As the temperature in the house falls approx 1 - 2 degF below the setpoint, the electric heaters will energize. So it is not uncommon for the system to run non-stop with the temperature falling a few degrees below setpoint. The colder the outside temperature, the more often the strip heaters will cycle on/off. If your system is well-maintained and operating at proper performance, it is still cheaper to run your heat pump than it is to run on straight electric heat. If you live in a climate where below zero temperatures are normal during the winter months, you might want to research heat pump options that offer higher COP's and increased performance in colder temperature than the basic contractor's model. Start with initiating communication with a local contractor. You will need to consider initial cost and the pay-back period based on your local energy costs and your specific demands you want your system to meet.
Hope this helps!
Posted on Feb 14, 2010
jrlomiteng
  • 21 Answers
SOURCE: refrigerator gsh25kgmc is not cooling
out of freon
Posted on May 15, 2012
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Why does my cooling fan inside the refrigerator keep running?
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
Mar 05, 2015 | Refrigerators
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Microwave continues heating even when off
The microwave has a short. You need to replace it, there's no real fix for it. Keep it unplugged and dispose of it. It will eventually catch on fire, and this isn't an exaggeration.
Nov 28, 2013 | Microwave Ovens
F4 or f5 on board if i unplug it and reset clock turnit on it runs for 2 or 3 sconds the display starts to blink it shuts off and you need to unplug and start over sometimes it will work
see this and fix it. read your section troubleshooting manual .God bless
you
  • F4--Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds.
  • F5--Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds.
Oct 15, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My dryer will not stop running
Timer motor might be shot. Check it for continuity. If you cannot get a reading then your timer needs replacement. If the timer motor is fine check the heating element for short to frame.
Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2012 | Kenmore Dryers
Shuts down, interior lite on tho, plug back in and works - stops
You have a bad thermostat ( the piece where you adjust the coldness of the refrig ) . Once it gets to temp and shuts off , it will not tell the system to start again . Next time not running , tap on the t-stat . If it starts , this tells you the thermostat is bad .
Aug 25, 2009 | Avanti 651WT Top Freezer Refrigerator
Will not keep cooling shuts off
Sounds like a your problem may be in the thermostat. Reason I say that is because when you leave the door open it continues to run and freeze and frost is seen on the freezer walls. I just think maybe the thermostat has become less sensitive to temperature change. To test this unplug the freezer and connect the 2 wires to the temp control together. Then the refrigerator will run continuous until unplugged. Let me know, Sea Breeze
May 21, 2009 | Avanti Compact Thermoelectric Refrigerator
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
