Question about RCA F36650 36" TV
F36650 No power, high squeal even without turning on.
My set made the infernal pop and then the picture went out, has the squeal even when not turned on. Did a vac out of dust.
There looks like a cap that is shrunken on the main board under the tube, haven't seen one like that before.
Any suggestions on the problem and fix and also does anyone know what pins to short to make sure all the power is out of this?
  • 2 more comments
  • CaptC Nov 28, 2007
    Rider - thanks for the info, I just ordered the flyback, need to find the HOT online.
    Can you tell me how to de-energize this? I want to live to see it work.
    Thanks.
  • CaptC Nov 29, 2007
    Thank you, will have all the parts next week, lets see how we do!
  • CaptC Dec 03, 2007
    I put the HOT and flyback in and it powers up, get static sound, but no picture. Double checked the solder joints and looked around for anything obvious, but still blank. The part of the tube near the yoke lights up and the remote seems to work ok.
    Any suggestions? I feel like I am 90% there.
    Your the best - I was going to adjust the screen, but glad I didn't first.
    Thanks.
    Novelist:
    Champion:
  • 232 Answers
CaptC, those sets are infamous for that problem, you need to replace the following parts:
Flyback Transformer part # 257805
Horizontal output transistor part # 2SC5148
there is a coil off the base of the driver transistor I think it`s L4401 that should be removed from the set and scrape the wax off the legs then re-install and re-solder it and you should be good as new, good luck
Posted on Nov 28, 2007
  • Larry Eastman
    Larry Eastman Nov 29, 2007
    You can get a good quality HOT transistor here;
    1-800-575-9833 (no generic chinese crap), un-plug the set from the AC outlet for 1/2 hour, with set un-plugged you need to get a 1 foot long lead with alligator clips on both ends, attatch one clip to the shiny metal wire that goes around the picture tube (it`s a bare metal wire) thats the dag ground, attatch the other alligator clip to the metal shaft of a large plastic handle flat blade screwdriver and stick the blade of the screwdriver under the rubber cap where it attatches to the glass picture tube, this will discharge the tube and you can then remove the flyback.
  • Larry Eastman
    Larry Eastman Dec 03, 2007
    CaptC, hook up cable to the set and see if it talks to you, if it does have someone watch the screen for you, and mounted right on the flyback are 2 black plastic controls, one is marked focus & one is marked screen, using a small insulated handle philips screwdriver turn the one marked "screen" SLOWLY clockwise while someone watches the screen for you, when the picture comes up stop and look at it yourself, if it`s still a little dark go back & turn it a little at a time until you like the brightness then stop, if you go too far you will get "retrace lines all over the screen which means your overdriving the tube which is not a good thing, let me know how you make out, Larry
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
TV has power, but picture or sound will not come on.
It sounds like something in the set has failed. These newer TV's have shut down circuits that won't let the set come on if there is a short or excessive voltage somewhere in the set. Most failures in TV's occur at the moment the set is turned on.
Jul 09, 2008 | RCA F36650 36" TV
RCA F36650 36" TV
is the squealing noise from the back of ur set , if so it is ur flyback transformer
May 29, 2008 | RCA F36650 36" TV
Stopped working and squealing sound
Your set is shorted circuit condition. The power supply is making the noise. Unfortunately almost any of the hi current circuits will do this. If picture went out 1st look for video or hi voltage problems.
Jan 11, 2008 | RCA 32F531T 32" TV
No picture no sound only the power light turn on and off
Hmm, sounds like a fuse has blown, and this is a problem that I recommend only those comfortable around high voltages try to fix......
Dec 22, 2007 | RCA F36650 36" TV
No picture High pitch squeal RCA F36650
Confirm service # from back of set = F36650 YX01..........
Transformer red HV lead attaches to CRT & Horiz output
xistor is on heatsink next to transformer = 2SC5148 .........
Rca part # 257805 or ASTI 2078 and 237470 xistor............
Do not use a generic transistor = name brand only............T.
Please rate this solution..............
Nov 12, 2007 | RCA F36650 36" TV
RCA F36650 36" TV Logo
96 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
