Question about RCA Televison & Video
I hane an rca hdmi tv and when i go to menu i can only acces picture audio time setup and the next one there is a picture of a close lock i can't get pass that to get to the channel one
SOURCE:
  • 3 Answers
SOURCE: TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Posted on Aug 20, 2006
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Posted on Mar 10, 2008
IrishDruid
  • 2712 Answers
SOURCE: Dynex DX-LCD37 Audio with HDMI
Try connecting directly instaed of through the switch box.
Posted on Jun 06, 2008
SOURCE: Menu Locked
While in capture mode, hit the green (delete) button.
You can change modes from here. :)
Posted on Oct 30, 2008
SOURCE: Sherwood RD-7502 Hdmi Audio Problem
if you have a tv with outputs you can connect audio wires from your tv output to your audio receiver input and you will have surround sound for everything connected to your tv
Posted on Aug 28, 2009
Testimonial: "That's a good idea. I hope that my TV will output the hdmi audio through the optical output on it. Thanks"
Trying to hook up surround sound receiver just like the manual shows but I cant get any sound from the tv but I can get music from the tuner part any suggestions?
Have you enabled the external speaker option on your TV and the set isn't on Mute? Check that you have the surround system's receiver set to the correct input. Next, check the audio level. On some sources for the TV, I need the volume at 65. Other sources sound fine with the receiver at 45. Check that the audio matches that being sent by the TV. On my TV, I needed to go to the Menu > Audio Settings to find the option for turning on the external speakers. Then I had to set the speaker system to Multi-Channel for our specific setup. (There were several options, including Dolby. For my specific setup, these other options didn't give the correct sound.) Finally try a different audio cable between the TV and the receiver.
I hope this helps. Please add a comment with the make and model number of your TV for additional advice. Adding the type of connection (digital audio (optical/coaxial), HDMI, RCA) will help me suggest potential problem areas.
Apr 21, 2015 | Audio Players & Recorders
No sound when i connect through hdmi cable
Make sure that when you go through the menu on the Sharp, you go to the setup options. Then, go to the video options and check to see what kind of HDMI connection you are using: PCHDMI or AVHDMI. After you've verified this, then go back to the main menu and next check the audio setup (should be below the video setup) and verify that it is using the same connection as the video. It most likely says RCA or line-in, you just need to change it and close the menu.
side note: make sure the volume level is at a moderate level, you don't want to blow your speakers with full volume after you fix the volume issue.
Jun 23, 2013 | Sharp AQUOS LC-40C32U 32 in. LCD TV
I have a Denon AVR 888, I want to use the reciever for my audio coming from my TV, I have plugged in a HDMI into the in port and connected it to my TV, I do not get any audio from the reciever
HI,
If you want to get the audio of tv program through the AVR then your tv should have a HDMI out port. Because you have connected the cable directly to tv. You didnt mentioned anything about your tv (make and model number). So its not possible to give you a final answer.
Check on thing isthere ia nsy RCA audio output in your tv. All tvs will have RCA audio out put. Wich you can connct to the TV /CBL in put of your AVR using a RCA cable. Then select the TV/CBL Using the SOURCE SELECTOR on the frond of the AVR.
Another Way is if there is optical out put on your tv then you can connect the optical out to the AVR's OPTICAL IN 1 or 2 Using an optical cable. Then you have to got to the input assignment menu of
the AVR and then you have to assign the optical 1 or optical 2 to wich you have made the connection. Here i have added the link to the user manual of the AVR. Check the page number 22. Which shows the menu tree. To assign the optical input for TV/CBL you have to go to the Input set-up there you will find the ASSIGN on the under CD,AUX etc menu.
This setup required if you use OPTICAL input of the AVR. Check the page number 14 for the connection diagram.
IF you are going to use RCA cable the simply connect one end of the rca to TV's AUDIO OUT and other end to the TV/CBL input of the AVR. And then select TV/CBL.
Here i have added the picture of RCA cable that you nee for making such connection between TV and AVR.
USER MANUAL
Ajin
Apr 26, 2012 | Audio Players & Recorders
I want to connect my philips home theater to samsung tv so how do i connect plz guide i hv three colour ep pin
Hi, to hook up a Tv to an home theater they are all the same process.
Instruction:
Make sure your playback devices are properly connected to your receiver. Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver. DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs. Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component. If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV. If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your receiver if you want to output your television's audio through your home theatre system. Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television. If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote. When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable. Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Tips & Warnings
Make sure you plug everything into the correct jacks or you will spend unnecessary time trying to troubleshoot why you don't have picture or sound.
Feb 17, 2011 | Audio Players & Recorders
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Connection Problem with HDTV, Receiver, DVR, and DVD
check the setup menu to direct your inputs from the hdmis. its all in the setup menu. good luck
Feb 10, 2010 | Yamaha RX-V463 Receiver
Hi, Just bought a 26" sony bravia tv. I don't use cable or satillite. I just need to find out what kind of cable I need to connect my panasonic DVD player to the TV and which port do I plug it into?
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
Model 60PL9200D/37 no sound
What device is connected to TV: cable, sat box, dvd player? What type of cable are you using to connect to the accessory device?
For a red, white, and yellow cable:
I cannot hear sound from the television when connecting to the AV1 input. What do I need to do?
Answer When you connect the accessory device to the AV1 input of the TV using either component video cables (YPbPr) or composite video cable (Yellow), you must connect the audio output from the accessory device to the 'INPUT AV1 AUDIO L R' of the TV using the RCA audio cables (Red and White).
If the connection is good,
Check to ensure that the AV1 audio source from the TV on-screen menu is selected to AV1.
  1. Press the 'MENU' button on the remote control.
  2. Press the cursor up/down to select SETUP and press the cursor right.
  3. Press the cursor up/down to select SOURCE and press the cursor right.
  4. Press the cursor up/down to select ANALOG AUDIO IN and press the cursor right.
  5. Press the cursor up/down to select AV1 and press the 'OK' button.
  6. Press the 'MENU' button to exit the menu.
Make sure that the volume on the TV and on the device is set at an audible level and also that the sound hasn't been muted.
For HDMI,
The picture quality is good but the TV does not produce any sound when connected to an accessory device with an HDMI to HDMI cable.
Answer
  • The TV's behavior is considered to be normal as some accessory devices have an HDMI audio output setting that requires to be turned on when using an HDMI to HDMI connection.
  • Check the on-screen menu of the accessory device to ensure that the HDMI audio output is set to ON.
  • In some cases, you may need to set the digital out audio stream of the accessory device to PCM.
  • For detailed information, please refer to the user manual of the accessory device.
Apr 07, 2008 | Televison & Video
Help!
Try pressing the HDMI button on your remote a couple of times, pause about 5seconds after each press it might be slow to change. If this doesn't work try connecting just the yellow lead(composite video) into the DVD player to the TV like the old days, probably AV1 or AV2 in the back of the TV. Then access the setup menu(setup button on remote). This will bring up a menu. Use the down arrow on the remote until HDMI setup is highlighted. You should then get a selection to turn HDMI on and select the different outputs(576, 720p, or 1080i). You might actually find the picture to be worse on some DVDs.
Apr 06, 2008 | Televison & Video
Televison & Video Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
