Question about Magic Chef Kitchen Ranges
I have a magic chef rev range and I am looking for 3 burner inserts #7214po15-60 or something to replace it . It seems to be no longer available
    Top Expert:
  • Magic Chef Master
  • 21,949 Answers
Try manufacturer possible replacement number --appliance repair shop -online search
Posted on Jun 11, 2019
SOURCE:
  • 1314 Answers
SOURCE: Magic chef oven wont turn on
yes oven ignightor to confim this try broil if it lights then its bottom oven ignightor get back wit me ill outline procedure
Posted on Dec 29, 2007
  • 1314 Answers
SOURCE: magic chef range
if you give me a model number i be might be able to help try here get your model number off the serial plate from the range http://www.maytag.com/support/manuals_literature.jsp if that dont work reply to this thread with model number
Posted on Jan 15, 2008
  • 1314 Answers
change the bottom ignighter just because it glowes doesn't mean its getting hot enough to open the safety valve you should see two screws at the bottom of the floor of the oven cavity after removing the racks remove those and remove the floor then you will see a deflector shield remove that to get access to the ignighter take out the two screws and install the new ignightor and reassemble
Posted on Jan 21, 2008
heatman101
  • 43501 Answers
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Posted on Sep 30, 2010
espressonist
  • 1711 Answers
SOURCE: lp to propane conversion
LP ( low pressure) is the same as propane gas. Do you mean natural gas.
So LP to Natural Gas ?
Posted on Nov 23, 2010
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Cgr3765adc, during bake mode upper burner does not ignite, gas smell. upper burner does ignite during broiler mode however. this problem seems to be in control module perhaps, not with igniter or burner...
In bake mode only the bottom burner will ignite. The gas smell could be caused by improper adjustment of the air intake on the bake (bottom) burner or something (foil) covering the holes in the oven cavity floor.
Jun 10, 2009 | Magic Chef CGR3725ADS Gas Kitchen Range
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 | Ovens
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Maytag/Magic Chef CGR1110ADW gas range
heatman101
adfaf
Dec 09, 2008 | Magic Chef 31000 Gas Kitchen Range
Kitchen Ranges Logo
23 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
