Question about Microsoft Xbox 360 Console
Xbox 360 Im getting No Picture or No Sound on my Standard TV upstairs. What Shall I Do
  • Anonymous Dec 07, 2008
    picture went water colour like turned it off then on again no picture or sound tried different leads and tv and restarted console by turning on and holding right trigger and y button just got couple flickering white lines then nothing got no rrod and can hear console reading disks fine
    President:
  • 4,402 Answers
Read this first
http://forums.xbox-scene.com/index.php?showtopic=610277
Posted on Dec 12, 2007
I have just bought an xbox 360 conected it to my tv allcables connected picture great but no sound
Hi Douglas
I imagine you have bought the new slim Xbox 360? Did you use a HDMI cable to connect it to your TV or did you use the standard cable? If you used a standard AV cable ensure that you connected the red and white cables into the same AV input as the yellow video cable.
Mar 05, 2011 | Microsoft Xbox 360 Console
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
Xbox 360 no sound or picture but with a twist
The towel trick is just that a TRICK. overheating your console
will shorten the life of most of the electrolytic capacitors.
and if it works it will very temporary.
First thing to try
goto gamestop and buy a multi a/v adpter .that will have
many plugs . plug the xbox 360 adapter in and then
plug the S-video into your set and some time you
can get video single from this line even if the main
Red /white/yellow/ line are dead . and since you have
sound from red /white you should be ok.
If the s-video has no output then your going to have
to do what's called an x clamp mod on it or
have a shop re-flow the G.P.U. this is the most
durable repair.
Any questions feel free to ask.
Rob
Feb 18, 2010 | Microsoft Xbox 360 Console
My xbox 360 console will power up as normal and put out sound but no video. i have tried multiple tvs and cables with no luck.
are you on a standard def or HD tvs? b/c if you have the xbox set on high def, then you try to plug it into the standard def then you won't get a picture, but you will get sound. If you don't have a high def tv then go to a friends or someone you know's and plug it in to see if you get a picture.
Jan 26, 2010 | Microsoft Xbox 360 Console
When i plug in my xbox hear sound but no picture, So i got a new xbox and still the same problem my son is crying his eyes out becuase hes has a lousy day at school and im abit angry any help?
You bought a new Xbox ,same problem.
Plug the unit in to another tv . Replace the
a/v cable , if still no picture then take it back
and get replacement.
Sep 14, 2009 | Microsoft Xbox 360 Console
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
No sound threw hd
hey jason,
umm im just throwing suggestions out there, have you tried the sound in all of the sound ports in your tv? and if you already have all i can say is try putting the xbox 360 on another tv to see if your cables are good, if not im guessing its your tv. If you have a newer xbox 360 with a hdmi port just get one of those cables they work great as well.
May 15, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
