Question about Hobart Food Mixers
Hi I have a Hobart se 302 mixer which keeps tripping when we turn it on. It has been fine for many years but has recently developed this fault... What can i do? regards
Hobart single phase made in uk no.1569048 spec e449
    Sergeant:
  • 256 Answers
One of two issues:
-either it has started pulling more amps than needed after many years of faithful service, or
-you now have something else plugged into the same circuit that is causing the circuit to trip
in either case, you will need an electrician to inspect and verify with multimeter (unless you know how to do so yourself). try unplugging any new items you may have purchased since just before the issues started
Posted on Jun 10, 2019
SOURCE:
bigg t
  • 640 Answers
SOURCE: 95 year old hobart mixer: two pole single throw switch
Im a tech for hobart and have seen old mixers but not that old.Hobart wont have parts but you could goto an electrical supply place,take the switch and ask them for something universal.
Posted on Dec 18, 2008
  • 110 Answers
SOURCE: Hobart N50 stator assembly replacement
also it sounds like the st. winding is o.k.sounds like the centrifical switch is staying engaged to long, keeping the st. windig in the circuit too long. would try new switch before rewinding mtr.dont forget to vote thks. monomoy
Posted on Jan 10, 2010
ricardok45
  • 135 Answers
SOURCE: Hobart A-200 serial # ?
Hi. Your mixer was manufactured in 1967. If you plan on keeping it, take the outer cover off, gently remove the two metal dust caps with a small screwdriver and look into each opening with a good flashlight to determine the quality and amount of grease in the trans. case.
Ideally the grease should almost fill the space with no oil visible. If you need to look further, I suggest that you open up the transmission cover, to determine the condition of the grease that lubricates the transmission. If you find that oil is seperating from the grease. you would do well to remove all of the oil and old grease and replace it with either Shell Darina EP-2, or Chevron FM ALC EP-2 grease. It's a messy job, but it will add years of life to your mixer.
Check the planetary seal, remove, clean and regrease the planetary gearing. With a mixer of this age, you never know if it has ever been serviced since it's manufacture or not. The grease must totaly encapsulate the trans. gears. As the grease breaks down it's level lowers and it leaves some of the upper gears without lubrication, and will result in preventable wear.
Good luck! If you found this solution helpful, please rate it. ricardok45
Posted on Feb 26, 2009
  • 3600 Answers
SOURCE: electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Posted on Jul 24, 2009
tooltech75
  • 80 Answers
SOURCE: wiring diagram for a Hobart D340 40qt mixer
i read in the manual that the wiring diagram is located on the inside of the top cover. check it out..
good luck
Posted on Oct 08, 2009
Trying to find the age of a Hobart Mixer serial number 1569386
Contact hobart directly, they tend to keep a record of machines, and would probably be able to as sit you
Feb 15, 2018 | Hobart Food Mixers
Hobart mixer se 302
where i can find hobart se302 motor carbon brushes and brush size
Mar 16, 2012 | Hobart A200 Stand Mixer
I have a Hobart P660 stand mixer. It turns on for a moment then trips the breaker. Would this be a "relay" or "switch" problem?
Hello Pizzaangel,
It sounds like you are having a problem with you Hobart P660, everytime you run it trips the breaker. Sounds like the switch is shorting out. You need to replace the switch and that should solve the problem that you are having.
Feb 15, 2011 | Hobart P660 Stand Mixer
Hobart A120 mixer bogging down
Hi. If the motor does not turn, the problem is electrical. Trace and test the electrical circuitry with the mixer unplugged. Start with the electrical plug and work your way through to the motor and switch connections. An electric motor technician should be called in if you are not familiar with electrical troubleshooting techniques. Good luck!.
If this solution has assisted you, please rate it. ricardok45
Mar 23, 2009 | Hobart Food Mixers
Need to buy a switch for the c-100 hobart mixer?
Hi. Hobart no longer makes or sells parts for the C-100 model. It's considered obsolete.
Your best bet is to locate a used restaurant equipment supply place and ask around. Sometimes these places keep old mixers for parts. Another option is to do a search on eBay, as there are several sellers that deal in obsolete parts. Failing that, a local electrician may be able to fabricate a new one or adapt some some other type of switch.
With a unit as old as this, it's important to maintain a good re-greasing schedule (once every five years), and your mixer will keep on delivering the goods for years to come.
If you found this solution usefull, please rate it as fixya. Good Luck! ricardok45
Jan 31, 2009 | Hobart A200 Stand Mixer
Hobart 20 QT. mixer (HL 200) will not operate on a GFCI receptacle.
you need to replace the gfci,the older gfci's interpret these frequencies as a shock hazard and shut off power to the circuit.you can buy @hobart, part#913053, that should solve the trip problem. dont forget to vote thanks monomoy
Apr 05, 2008 | Food Mixers
Hobart N50 Tripped
The reset button is to protect over amping the motor. The N-50 is not a very strong unit, (commercially), but you won't break a gear. If you overload the unit, you'll either trip the overload (reset button), or you will break the taper pin that attaches the planetary to the center shaft.
If you're looking for a small commercial unit, and you're in the US, look into the 10 qt Precision Mixer.
Apr 04, 2008 | Hobart N50 Stand Mixer
Old hobart s-30 mixer oil
man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
Jan 20, 2008 | Hobart A200 Stand Mixer
Hobart hl600 mixer
I know what these codes are: code 19 is that phase c is over current fault and code 23 is a motor stall fault.I would start by making sure you 3 phase wiring going into the mixer is there.I service these mixers as im a service tech for hobart.these units are very detailed and i can walk you thru some things to check but if you have an electrical problem you most likley will have to call a hobart service tech because we have special equipment to diagnose the fault.let me know it may be something simple as these mixers are usally maintenance free.
Nov 14, 2007 | Hobart HL600 Legacy Stand Mixer
Mixer keeps cutting out! Please help!
As far as I know this is a food mixer. Concrete will definitely cause the overload to trip. Frequent triping has caused the overload to weaken and hence trip at lower values. You probably need to replace the overl;oad
Sep 22, 2007 | Hobart A200 Stand Mixer
Food Mixers Logo
27 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Steve Allison
Steve Allison
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
