If the main PCB is still pulsing the "beeper" even when unplugged, it would be the on board capacitors still charging it. Apart from changing the main PCB, I would suggest you leave it unplugged for as long as necessary to fully power down the capacitors. It will take a few hours or more. Try using the machine when it has stopped beeping. It may then be OK. If not, a board replacement will be the only solution.
SOURCE: washer keeps beeping
HATE TO SAY IT BUT THE BOARD WOULD NEED REPLACEMENT.BEEPING NORMALLY INDICATES A FAULT CONDITION WHICH WOULD STOP THE CYCLE(WASH) OR THE COMPLETION OF A CYCLE.
SOURCE: dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
SOURCE: Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
SOURCE: My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Testimonial: "You confirmed my suspicion Thanks "
