Calibration area full optimum calibration area
Can not copy any music cd i always get this message
  • p0mmy Nov 28, 2007
    i am on x 4 its partitioned in 2 sections user partition and system yes everything is on c drive its a 150 gb harddrive a 136gb available the wierd thing is i can copy dvd but not cd
    ive just added external writer same outcome cal area full
    p0mmy thanks
  • 25 Answers
Hi p0mmy,
I need to know some info before I can attempt to help you.
What OS are you running? How is your system partitioned, is everything on a C:Drive? What size is your harddrive? How much available free space is on your harddrive?
--RoadHawk
Posted on Nov 27, 2007
  • Mort Lebow
    Mort Lebow Nov 29, 2007
    It appears that you definitely have enough disk space on your C:Drive. How much rRAM is installed in your sys? What software are you using to perform the copy.
    It sounds like it may be a driver issue. So, I would uninstall the software for the burner, reboot, and reinstall it.
    NOTE: Be sure to disable your AntiVirus and PopUp when doing the install...! Hope this is helpfull...
    --RoadaHawk
2006 Expedition overhead compass reads "N" when heading "E". Wonder how to reset it so it indicates the direction accurately.
Yes. Wish I could tell you which button for sure, but to reprogram the Compass you hold one of the buttons and drive in a circle one or two times to reacquire your position.
Apr 08, 2013 | 2006 Ford Expedition XLT
How do you calibrate the compass on a 2002 Ford Windstar
Copied from alldatadiy.com for 2002 Ford Truck Windstar V6-3.8L.....
Compass Calibration
1. Start the vehicle and locate the compass module mounted on the base of the mirror.
NOTE: For optimum calibration, drive to an open, level location away from large metallic objects or structures. Switch off all non-essential electrical accessories (rear window defrost, heater, A/C, map lamps, wipers, etc.) and make sure all doors are shut.
2. Press the RESET button until RESET to CAL is displayed in the message center display.
NOTE: To exit the calibration adjustment mode before carrying out a compass adjustment, turn the ignition switch to the OFF position.
3. Slowly drive the vehicle in a circle no more than five times at no more than 5 km/h (3 mph) until CIRCLE slowly changes to CALIBRATION COMPLETED in the message center display.
Jun 21, 2012 | Cars & Trucks
Opc error.. it wont record any source..
Web search "optimum power calibration error". The manual incorrectly calls it Optimize Power Control on Page 2. It has nothing to do with the source and all to do with the media and how the laser calibrates to it.
Sep 20, 2011 | JVC XL-R5000BK CD Player
I have a Phillps 870 CD rcorder. Have been using TDK Music CD-RW, 4x, 700mb discs. Just bought new discs from same manufacturer and sames epcs but get OPC FAILED message
Welcome to Fixya.
OPC stands for Optimum Power Calibration. basically, it's a small test to write on the media and read it back for self calibration of the laser power.
I'd try different blank discs to see if it's sensitive to some. Of course they recommend only Philips brand but most major brands should work. Sometimes the "times x" recording rating needs to be higher or lower.
You can also try to turn unit on at least 30 minutes or more before use (this seems to work best for me)
The bottom line is that certain media and certain writers just don't get along, so there are no permanent "Fix" for this issue as every CD recording device encounters such once in a while.
Here's an excerpt from one of the tech members who experienced this problem :
"If I have an OPC Fail message, I try another blank. If
I find that they consistently fail (about half a buck wasted) I move
the stack over to the computer (which seems to work fine with these)
and buy another stack of blanks of a different brand next time I see a
good price..."
Hope this helps, Thanks for using Fixya.
Jul 09, 2011 | Audio Players & Recorders
What is opc
"OPC stands for Optimum Power Control (or Optimum Power Calibration,
depending on who you believe; the process is sometimes known as Dynamic
Power Control (DPC) or Direct Read During Write (DRDW)). Most CD-R units
do a power calibration test before writing to adjust the laser power to the
correct strength. Different brands of media and different recording speeds
require slightly different power levels. Too much power can create oversized
marks which can interfere with each other, and too little power can produce
undersized marks which, in extreme instances, can cause read failures.
The recorder reads a recommendation for the initial power level from the
Recommended Optimum Recording Power value from the ATIP (section (2-38))
on the disc. This is used as a starting point for a series of write tests
in the Power Calibration Area (PCA) of the disc.
Running OPC goes a step farther by actively monitoring the write process
and adjusting the laser power as needed. If the writer encounters dust or
fingerprints, the laser power can be increased to burn through the
obstacles. This is especially useful for discs that are moved around
between recording sessions, such as CD-RW discs or multisession CD-Rs."
See this:
http://www.gallagher.com/music/cdr.htm
Cheers,
Kevin
Jan 25, 2010 | Philips CDR765 2-Disc CD Recorder
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
Power Calibration Error.
first re install your nero .and
A) Power Calibration is controlled by the recorder. Before any write operation, all recorders must do a 15 step power test to determine the optimum power for writing to the CD; this is called "Optimum Power Calibration"(OPC). And during the write, it continues to do this test to get the best write throughout the whole CD; this is called "Running Optimum Power Calibration" (ROPC). This whole process is controlled by the recorder, though initiated by programs such as Nero. There is an area on the inner part of the CD for the test and test data info to be stored. You can use this area up to 999 times.
So, when you receive the "Power Calibration Error" or "Power Calibration Area full" error message, then the cause will be either poor media, poor Power, or a defective Recorder.
POSSIBLE SOLUTIONS:
1) A might enable the OPC on this medium
2) Try another brand of CDR or CDRW media.
3) Also try different power connectors, and for recorders, do not share power with other devices. It needs its own power connector. If this occurs with an External recorder, the power source in the chassis could be the cause. Take the recorder out of the external chassis, and connect it internal, as a test.
4) Try different configurations, such as taking the CDROM to the Primary IDE bus as Slave, and have only the recorder connected to the Secondary IDE bus as Master.
5) Send the recorder in for Service.
Here is the direct Link: http://www.nero.com/en/632181809668074.html#23
I Hope this helps,
Feb 12, 2008 | Ahead Software Nero 6.0 (60045) for PC
Power calibration area full
There are many facts cause "Power calibration area Full" error. First of all clean up your TEMP files. Make sure DVD media you are using is supported by you DVD Writer. CDs are rather easy to write. DVD requires more precise laser beam to channel as its more dense than CD. So physical facts like dust on the lens might be a factor too. Also firmware update for your DVD Writer will be a great step. These are the main factors.
Good Luck
Dec 30, 2007 | Fujitsu Siemens AMILO Pro V2010 Notebook
Dvd recorder problem - model CMWR10D6
Might be the PCA aka power calibration area portion of the lens that reads that might not be reading it. Here is a little bit more info on PCA.  Power Calibration Area of a recordable or rewritable disc that precedes lead-in and the PMA, where the optimum laser power level for writing can be determined by a recording drive
Nov 07, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Computers & Internet Logo
54 people viewed this question
Alun Cox
David Payne
David Payne
