Question about LG L204WT LCD Monitor
Monitor turned off and now will not restart (Power light flashing rapidly)
I just purchased an LG L204WT. It worked perfectly for a few weeks. After about 2-3 weeks, it bagan to turn off after about 10-15 minutes of use. When the screen turned off, the power light goes to a rapid flash. After the first few times it could be "fix" by unplugging the power. The "fix" only allowed it to remain on for a few minutes before shutting down again. It now will not power on and the power light contines to flash rapidly.
  • 2 more comments
  • christiansen Dec 08, 2007
    I have the Same LG L204WT monitor .. similar issue - it was working then midway through it seemd to power down. The blue LED power indicator flashes about once every 3 seconds. No matter what I do I can't:
    Power it off using the buttons- only disconnecting Power at Mains works .. When power reconnected monitor is in "on mode" with that little Blue Power LED blinking away at me.
  • apac1979 Jul 03, 2008
    I have the same issue but my blinking just started. I tried turning the power off bu that didn't work for me .. i had to allow for it to wait for it to get itself back together and pop up a screen saying cable was not attacked and this time i hooked up analog cable and it seems to work. but i didn't spend good money for an analog lcd monitor. i CANT turn my monitor off cause if i do it goes back into that cycle of blinking light.
  • Anonymous Mar 16, 2009
    MY LGL204WT WON'T GO INTO SLEEP MODE EVEN WHEN THE SETTING ON MY PC IS SET TO TURN OFF DISPLAY AFTER 20MINS. IT GOES BLACK AND KEEPS FLASHING POWER SAVIING LOGO WITH BLUE LIGHT SWITCHING ON AND OFF
  • gwbrink Mar 20, 2009
    My monitor (LG L204WT-SF) goes black with the blue power light blinking. Power down is not possible other than removing the powe cable. I have had my monitor swapped twice allready by LG, but the problem remains.
    New Friend:
  • 12 Answers
If your LG L204WT will not power up all of a sudden, or takes long to power up, or dies after a while and it has not been exposed to lightning damage then in all likelihood the Electrolytic capacitors in its power supply has started to fail.
Unplug the unit from mains. To open it up, remove the 4 philips screws at the back. Then starting at the bottom corner use a small flat screw driver to wedge the front bezel loose. After removing the bezel the rear casing will also come off the panel. The circuitry case is taped to the panel with silver tape. Loosen the tape, lift the power supply. Carefully unplug the two sets of backlight cables, and the front panel controls to completely remove the circuitry case. Now remove the 4 screws holding the power board and then replace the following capacitors:
You can order caps from most electronic component stores.
You will need to replace:
C105: Electrolytic Cap, 47uF 50V 105 degrees C
C106: Electrolytic Cap, 1uF 50V 105 degrees C
C202,C206: Electrolytic Cap, 680uF 25V 105 degrees C
C203,C204, C205: Electrolytic Cap, 1000uF 25V 105 degrees C
You can always use a HIGHER voltage and a slightly HIGHER uF, and HIGHER temp rating but never lower.
Make 100% sure to observe the polarity when replacing the caps. Electrolytic caps have a clear negative marking stripe on the side coinciding with a black mark on the board.
Posted on Mar 23, 2013
  • Riaan Mar 23, 2013
  • 31 Answers
Sounds like it is defective or was shocked. See if you can swap it out or contact the manufacturer about repair under the warranty on it.
Hope this helps!
Posted on Nov 27, 2007
Dell Inspiron 1721 will not power on,light on power supply flashes rapidly.
First, try and take out the battery and start the computer with just the power adapter. If the power adapter is still blinking, replace the power adapter. If the computer turns on with just the power adapter, replace the battery.
If the battery status light rapidly flashes amber, the battery may be defective. Purchase a replacement battery from Dell.
If the power supply status light flashes, the power supply may be defective. Purchase a replacement power supply.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 15, 2011 | Dell Inspiron 1721 Notebook
When it's on power off it make's a beeping sound, not one tone but it's fast. and when i am trying to turn the power on it wont start untill i pressed the power on/off button in 4-5 min. and yesterday the...
robin almen, If date code on rear is 2006, you will explor these options: 1 DIY refurbishment of units internal power supply printed circuit board. 2. See if LG (lucky Goldstar) has a cash+old unit swap-out program??? 3. Contract out the repair work. ($30 to $75) 4. Trade L204WT for new monitor. 5. Do some reading in the fixya profiles and follow the links you find there, to see if you might be able to do your own repair. Then visit YOUTUBE for repair video clips, searching using this: "lcd monitor disassembly" and "lcd monitor repair" Now it's up to you! What will you do? What will you do? Bye for now. 12fixlouie
Aug 27, 2010 | LG L204WT LCD Monitor
Monitor won't turn on after power interruption
First check all your (computer) connections especially the monitor. If connections are secure, it may just be an application or registry problem. Uninstall the LG monitor software, then reinstall it. If you're referring to getting into the computer case, locate the "thumb screws" at the rear of the case (may be one top and one bottom) loosen screws then slice side panel from case.
To keep your system running lean, clean, and smooth, install Piriform CCleaner, a free app for home users. It's excellent!
Jun 11, 2009 | LG L204WT 20 inch LCD Monitor
Monitor restarting randomly
Rarely does a monitor go out due to drivers. Try another monitor and verify that it isn't the computer (it isn't). If the power light goes out it is the power supply (usually inside) the monitor. If the light stays on, it will most likely be the backlight power unit. Browse the internet for the model and parts. Newer units are difficult to find.
Apr 29, 2009 | Computers & Internet
I'm assuming you mean that you've tested the computer using another monitor and that the desktop proved to be working fine. If that's the case then the monitor needs to see a reputable repair person for repair.
Apr 04, 2009 | LG L204WT 20 inch LCD Monitor
Light on...dont know what it means!!..help
sound like the light you are talking about is the change oil soon light. turn the key to the run position and press the gas pedal to the floor 3 times rapidly, wait a few seconds, the light should start flashing then turn the key off, this should reset the monitor.
Apr 01, 2009 | 2004 Saturn VUE
Lg flatron w2234s monitor is flashing ??
I am going to suggest if it's only 3 months old you should take it back to where you bought it. Mine quit working right a few weeks after I bought it and they gave me a new one. Be sure you take your receipt with you. Even new things can mess up.
Mar 02, 2017 | Computers & Internet
LG L204WT LCD Monitor Logo
1,821 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
