Question about Konica Minolta Office Equipment & Supplies
Konica minolta dialta di 2011 error 0500 code reset
4 Suggested Answers
SOURCE:
idriss47
  • 26 Answers
SOURCE: minolta dialta di 250
Hello
E0500 means :"Fuser problem. Warm-up incomplete"
Posted on Feb 08, 2009
SOURCE: konica minolta di 1611, di
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of BH 164 x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
Posted on Oct 28, 2011
  • 1316 Answers
SOURCE: minolta dialta Di 470 donne code c 0210 puis
C210,transfer/separation corona malfunction.Change or clean the corona wire and the corona holders(white Assembly).
Posted on Jan 23, 2012
I have a photo copier machine minolta dialta di 470 that show error code c-0400
open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
0500 error dialta cf 2002
open front door lay on your back look for the small hole on the right side touch the small switch with a screwdriver to reset the machine must be on
Jan 16, 2014 | Minolta DiALTA Di520 Laser Printer
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
open the front door, upper left small access cover remove. press trouble reset. if the code comes back do not reset problem with the fuser continue reset fuser can catch one fire the will ruin a perfectly good day. have the fuser checked out.
Feb 02, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
About the codes
Sure which one do you want to know about. There are about a 100 or so codes...
Jun 28, 2009 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Konica CF910
You reset the code by pressing the "Trouble reset switch on the Tech Rep setting Switch board, located under the control panel, open the machine front cover its a small circuit board with two small black press type switches (left side switch)
Jun 19, 2008 | Konica Minolta DiALTA CF910 Copier
Code C-0500 on Di 620
Try opening the front door with the copier on, on the right hand side you will see a small cover held on by 1 screw, remove this and press the reset button then close the door. If the error is still present it will return.
May 18, 2008 | Minolta DiALTA Di520 Laser Printer
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
