Question about InFocus LP70+ Multimedia Projector
Wonderwall projector has black spot in middle of screen
Wonderwall projector plays fine for about 3 minutes before a black spot begins to appear and grow larger. What's going on?
  • 3 more comments
  • laura_chr763 Aug 10, 2009
    The spot does go away each time the machine is turned off, cools down, and is turned back on. The spot begins as a dark patch and then becomes a larger and larger dark black circular spot. There is a faint ring around the edges of the spot. The spot is solid black and not pixelated. It almost appears that there is something on the lens blocking the image, but there is not. The spot is not in the center. It appears slightly to the upper left side of the projected image.
  • jasbo
    jasbo May 11, 2010
    does the spot go away and restart every time you turn it on, or has it happened once and is permenant? is the spot circular? is it in the middle of the screen or off center? is it dark black or translucent? is it pixelated or blends at the edges? let me know so i can fully understand the situation and be able to help you better.
  • ali_tariq199
    ali_tariq199 Dec 27, 2012
    i have a medialy h300-tv projector i just got it on christmas, its brand new when i hooked it up to my pc with hdmi it was working until 5min then i can see a litte black blob almost like if the screen was broken, my pj has a 5incg tft lcd screen inside its not a dlp,the blob is kid of like when you drop a screen and it brakes and you can see a blacked out area like dead pixel but its not cuz it goes away when i turn it off and turn it on again comes back aftetr 5min and its out of coloured for the first 5min then it turns into the thing please can you help its a new pj i dont know what can go wrong ?
  • ali_tariq199
  • Femi Elufiede
    Femi Elufiede Mar 13, 2019
    When projector comes up with a growing spot black there is no two ways to it. it is overheating. your cooling fan may be rolling but trust me is not cooling it. Solution: Replace the cooling fan if possible a higher speed and it will never repeat itself. 100% banker
    New Friend:
Tranlucent dark spot on Optoma image. Looks like something is on the lens.Off center--top to bottom. Cleaned lens, blew out case, changed bulb, still with dark spot.
Posted on Nov 15, 2009
    New Friend:
My guess is that you have the projector flat on something? I did that and got the spot right away. The directions says NOT to lay flat, you must use the arm/handle so it will not overheat. Next time you get the spot pick the projector up and it should go away in about 10 seconds. It is overheating. Use the arm/handle, if you need it to sit level place a wii game or something similar size in the back to level it out.
Posted on Dec 26, 2009
Yes it is true the projector needs to "breathe" so no you cant lay it flat you must elevate it using the silver handle. The spot will go away, speaking from experience!!!
Posted on Apr 09, 2010
  • Ona Ramsay Oct 20, 2018
    I have my projector on a stand& still getting black blob .... wonder if cooling fan could be the issue???
    New Friend:
We just bought an ANDROID Projector. It has the same black spot. We took it out of the box, plugged it in, and turned it on. It worked good for a couple minutes then started to get the black spot in the middle of the screen that got larger and larger until it covered most of the screen. We turned it off for about 5 minutes. Then everytime we turn it on now it gets the black spot after a few seconds of running. It wasn't laying flat so it had good ventilation. It doesn't have anything blocking it. Don't know what's wrong with it. Can someone help???
Posted on Aug 20, 2016
  • Robert Wisler
    Robert Wisler Feb 13, 2018
    I have the exact same problem
    New Friend:
I\'m having the same problem. ? Big black spot that gets bigger and bigger. Turn off and back on and its gone but comes back a couple mins later. It has been beaten well and even given an extra fan to help ......What do i do
Posted on Oct 03, 2014
    New Friend:
Your projector is overheated. Make sure you do not have anything covering the fan, and that you power source is connected directly to a wall outlet, not a power hub.
Most of the people cover up the fans so that it wont be as loud. You can simply find these silencers on amazon, but the air will still flow to the projector.
Posted on Feb 27, 2012
    New Friend:
What??The directions say do NOT lay flat, and use something to level it out. I'm sorry but I just cannot make sense of that!!!!
Posted on Jan 20, 2010
SOURCE:
How to fix wonderwall projector after being unplugged while red light and fan were running
PDF]Download - MS Customer Care
mscustomercare.com/forms/ProjectorIM.pdf
getting started with the projector. 14 n. (1 se') ... I The projector can project up to 90" (228 cm) diagonal image. ... I Once powered on, the fan and the lamp will run instantly.... WHILE THE RED LIGHT IS BLINKING ... light bulb. I Turn off the projector, unplugthe power and allow it to cool for 30 minutes as it runs at an.
[PDF]Checking Projector Status - Epson
https://files.support.epson.com/Epson.../450W_460lampStatus.pdf
EpsonIf your projector isn't working correctly, first turn it off and unplug it. Then plug the ...doesn't solve the problem, check the lights on top of the projector. What To Do Whenthe Lights Flash. The lights on ... If you continue to use the lamp after the ... P Red. Off. Flashing red. There is a problem with the fan or temperature sensor.Missing: wonderwall
Canon Knowledge Center - Turning On and Off the Projector
Jan 18, 2016 | Sharper Image Wonderwall Entertainment...
When i plug it in makes noise like it will power up but when i press the power button nothing happens
Review: Discovery Wonderwall Multimedia Projector ...
? 15:01
https://www.youtube.com/watch?v=GYrFFrbWm5U
Dec 3, 2010 - Uploaded by georgef551
This is a review of the Discovery Wonderwall MultimediaProjector, ... twist the lens to focus the image, up to at least 120" (can go farther), but you'll ... RGB elements, which stands outlike a sore thumb when video gets .... The bulb will just make the display more true, and possibly, ... sound compared to 3m?Missing: power ‎power
Discovery Expedition Wonderwall Entertainment Projector
www.amazon.com/...Wonderwall-Entertainment-Proje...
Amazon.com, Inc.
Rating: 2.7 - ‎60 reviews
Amazon.com: Discovery Expedition Wonderwall Entertainment Projector: ... color contrast, volume control, distinct power on/off button, LED indicator light .... A lot of reviews complained about the fan noise and speaker level, but I thought .... I got it for Christmas to play video games on and you can't even make out the words.
Amazon.com: Discovery Expedition Entertainment Projector ...
www.amazon.com/...Entertainment-Projector/.../B002...
Amazon.com, Inc.
Rating: 2.5 - ‎267 reviews
Jan 05, 2016 | Discovery Channel Discovery Expedition...
No picture comes out when i plug in my wonderwall projector?
Could be no power where you plugged in or a bad light, switch or fuse if it has one. Check the wiring for burned connections.
Oct 08, 2014 | Discovery Channel Discovery Expedition...
Vivtek d510 projector has black and white spots covering 1/3 of projected image
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Jan 02, 2014 | Vivitek Office Equipment & Supplies
Is there any way that I can connect my new WONDERWALL projector to my laptop computer
The wonderwall does NOT have the proper inputs for use with a computer for good reason.
A wonderwall projector is NOT a projector that is good enough to be used for movies or games and it would be embarrassing to make a presentation on one. It has WAY less resolution than even old fashioned standard definition TV. Standard def Tv is 720x 480 pixels at 30 cycles. A wonderwall is 480x 240 pixels which is appx. the resolution of a screen on your phone. That's 345,600 for STANDARD def versus only 115,200 pixels for a wonderwall. When you blow that up to 3 feet wide, it'll look pretty mediocre. We have one just like it and we use it to project VHS onto our garage during Halloween and Christmas.
It IS perfect for fun and might be ok to watch old VHS tapes but watching a dvd on one is horrible.
Your 1440 has VGA outputs. A wonderwall has AV (red, white yellow) inputs. You can buy a vga to AV adapter for less than 10 dollars almost anywhere. You don't even need to go to a specialty electronics store.
Dec 17, 2012 | Discovery Channel Discovery Expedition...
Black spot on projector screen
Hope there's a dust/scratch in your Projector lens face.
Try it by cleaning your lens face of your Projector and see.
Thanks for using
FixYa
Aug 29, 2012 | Cell Phones
73' Mitsubishi has magenta splotches moving around screen and eventually getting larger until whole screen is covered.
bad main digital board. It's the bottom board on the left, try Encompas Parts to get digital board.
Nov 27, 2011 | Televison & Video
Plays for couple minutes or hours, then goes
Have you considered checking the lamp? It could be going bad.
Nov 15, 2009 | Dwin TransVision 3 Plus Multimedia...
InFocus
Hi there
That is a definate Mainboard replacement.
Must warn you that it could turn out to be a expensive exercise
Feb 06, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus LP70+ Multimedia Projector Logo
9,518 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
