Hi
i trying to tune my URC22B control in to my bush tv but cannot seen to get the codes to work
thanks rob
Doing some searching I came across this, I hope it helps.
From instruction booklet
Power on the control device or VCR and put the tape in.
Press on the SET key continuously,then press the device key you want to set.For example, TV1/2,or VCR1/2,or SAT/CBL or AUX.
Then the LED is on, release the key you press.
Press the SET key again and release it,then you will go into QUICK SEARCH MODE and the LED will flash all the time.
Press the POWER key once at the device,URC22B will send another POWER signal of the next code.(If VCR/AUX, you will press the POWER or PLAY key). Observe if the device works(POWER OFF or PLAY),if it works, go to next step , otherwise repeat the step
whenever you want to leave SEARCH MODE,please press the device key,(TV1/2,or VCR1/2,or SAT/CBL or AUX.)
then the LED is off.
Then check other keys like [CH+/-],[VOL+/-] if they can be controlled.If cant be controlled,go back to the step
Http://www.eserviceinfo.com/index.php?what=search2&searchstring=urc22b-7
here is a pdf manual for the remote control. does any one have the code for a pacific pvtv361 tv/video combi as ive tried to manually set this remote to work for my kids tv and i cant tune tv in
"does any one have the code for a pacific pvtv361 tv/video combi as ive
tune tv in"
many of these combi devices are setup as a device (i.e. DVD/video)
with a built in monitor not a tv with a built in device so try the
DVD/video codes with the DVD/video button.
If they don't work use dotman's method above with the DVD/video button
instead of the tv1/tv2 button. It most likely won't give all the
functionality you would get with the proper remote but you should at
least be able to change channel, turn it off/on, etc.
hope this helps,
Gerndal
CODIGO FOR SATELITE PHOENIX
Download the complete user manual codes from the following link:
http://safemanuals.com/user-guide-instructions-owner-manual/UNIVERSAL%20REMOTE%20CONTROL/URC22B-7-_E
A millenium-hoz van k?d?
tune tv in"
many of these combi devices are setup as a device (i.e. DVD/video) with a built in monitor not a tv with a built in device so try the DVD/video codes with the DVD/video button.
If they don't work use dotman's method above with the DVD/video button instead of the tv1/tv2 button. It most likely won't give all the functionality you would get with the proper remote but you should at least be able to change channel, turn it off/on, etc.
hope this helps,
Enki
Try using the auto search - it may take a while, but hopefully it will find it eventually...
Http://uk.answers.yahoo.com/question/index?qid=20060808123353AAoM27f
SOURCE: URC22B universal remote controller 15 in 1
Remote codes
http://www.remotecentral.com/index.html
081,119 or 026
worked on my bush dvd/tv combo tv part
my remote doesn't work maybe i have to change a code ? anyone have a codes list? pls help me . thank you
i don`t know how to use my URC22B universal control. What can I do?
my problem is :don't description in italian language.what use that for my television.can have instruction in italy.thanh you scusa ma con inglese 0.
I bought this remote on a second hand market and I don't know how to program it for my Grundig ST63-700 TEXT TV set.Please can somone help me,or maybe tell me where to find an operating manual?
Henk Polman.
[email protected]
Can't get the code for a Bush tv to work??
i need to tune my control to my psific tv but it not have a code
crown 1500 dvd there are no codes in your instruction booklet at all do have any codes for this make i have tried all the step that are in the book but none of them work can you help me richard
cant get urc22b remote to work on tv.jim
how do i get my tv to av using the remote so i can play my xbox
DOES A URC22B WORK ON A TOSHIBA TV AND HOW
i cant set the code in my remote control.
how to change TV. color by universal remote?
I NEED CODE FOR VCR PHILIPS
i need URC22B code to activate AS628 DVD, do you have the code?
wont work
i have the same problem as you
how do i get a urc22b universal remote controller to link with a bush 1497 internet tv
I have the above remote URC22B for using on a Deawo telly.. I get the codes to go in and then I am trying to re tune this telly to different channels with the remote and I can`t seem to do it. A friend said it`s the two arrows pointing towards each other and I`ll try that.
Once I`ve got the codes into the remote I then lose them trying to play around to re tune, and have to start all over again. I then repeat this again and again.
Question is how to tune with this remote please. Oliver
[email protected]
icontvcod
Urc22b-7 remote controller manualhttp://www.eserviceinfo.com/downloadsm/1...
Controller stops at 262 but will not control the tv at all.
i have a digital set top box model STB1AW11 need codes for URC22B universal remote controller
I cannot find the control codes for my Bush DVHS2 using a Uinversal Remote Controller URC22B
