Question about Sony KP-57WS500 57" Rear Projection Television
Sony KP -57HW40 - Green Picture Tube - part new/used
I was told that Sony no longer produce green picture tube for KP-57HW40.
Is it still possible to purchase new/used green picture tube?
where & how mach?
Help!!!
  • 2 more comments
  • Gregory Shin Dec 05, 2007
    Thank you Terryfic!
    My Sony serial # begins 901...., still the same part # ?
    Where can I find the rebuilder directories?
    ...I already replaced blue tube last year when they had parts...
    And It's hard to just let go after spending $$$ not long ago...
    Thank you again for the help!
  • JAG715 Dec 14, 2007
    i turn the tv on..it works fine for about 5 min..a green tint will come over the whole picture.it will shut itself off.
    ill switch to video 1 and the whole screen will flash green before going to black.
    im told that they dont make the green tube any more.can i still get it?
  • Gregory Shin Dec 14, 2007
    I contacted company called Video Display Company (800-241-5005) for tube rebuild. They fax me a form to fill out send back to them with the tube.
    Is this the type of work that I should let a repair person do the job?
    Can someone help me with how to pull my tube?
    I'm a computer engineer who never worked on TV before...
    Please drop me a comment. Thanks.
  • Gregory Shin Feb 13, 2008
    By mid of Jan. 08, I completed the task; my TV is now good for few more years (knock on wood...)
    Sent the part for rebuild, received back and reinstalled and many sleepless nights doing adjusting, focusing...
    Rebuilding tube and the technical manual purchase cost me about $200. plus many hours of valuable heand-on lessons.
    Thanks to everyone on this board and FixYa!
    Problem Solver:
  • 7 Answers
CONTACT VIDEO DISPLAY AT 1-318-747-0140 AND TALK TO CHARLIE I GOT MY BLUE ONE FIX IN 6 DAYS!!! AMAZING FOR ONLY $152.00 THATS CHEAP YOU JUST HAVE TO SEND IN YOUR OLD ONE AND THEY REPAIR IT! AWESOME COMPANY!!!
Posted on Mar 30, 2009
But a new TV. If you replace one you should replace all tubes. You can buy a new tv for close to that price
Posted on Feb 12, 2008
    Genius:
  • 1,694 Answers
If your Sony serial # begins 900....., part # is 8-733-652-05
NLA, rebuild only, pull your tube and send to rebuilder.....200.00???? ......................................T.
Posted on Dec 03, 2007
  • Vista Electronics Dec 05, 2007
    Same......generic tube = 07MVC21 = send to company called
    Video Display for rebuild........T.
The screen turns blue after about 2 minutes of turning on the TV
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 25, 2010 | Sony KP-57HW40 57" Rear Projection...
Have Sony Model# KP-57HW40 Big screen rear projection tv..Has blue wavy lines across screen, and sometimes flashes blue, can you give me assistance??
Blue Picture Tube , bad Video IC on Blue CRT board.Or Blue screen drive control to tube needs to be adjusted down some.
Most Likely Bad Tube!
Jul 12, 2010 | Sony KP-57HW40 57" Rear Projection...
Tv comes on for 10 seconds then fades to a green tint then turns completely green for a few seconds than turns off
Symptom shows tv got problem with green picture tube that need to be replaced.
Rear projection tv has 3 picture tubes, red-green-blue to make color picture.
Since its an old model so spare parts would hardly be available and local tv repair shop will help you to arrange required part, if they can.
Thanks.
Apr 16, 2010 | Sony KP-57HW40 57" Rear Projection...
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
Turn tv on screen is light blue then picture fades then, screen shuts off???
Blue tube is bad need to replace blue tube.. Tube no longer avail will need to be special ordered and my run from 350.00 up to replace part.
Feb 04, 2010 | Sony KP-57HW40 57" Rear Projection...
Picture turns green ,usually within 10 minutes of turning it on.It will sometimes go back to normal color but generally returns to green.This happened when the set was much newer and Sony replaced all...
Green Tube maybe trying to short out or you can try adjusting screen drive to the Green Tube by turning control down a notch, Sony had a bad run on these with alot of Bad Tubes.
Dec 08, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony KP-51WS500 projection tv. Screen is green with curved lines
The green picture tube has an internal short. Happened a lot with that model. The tubes are no longer availible. But a reputable company called Video Display will rebuild the tube completely. But the tube must be pulled and shipped to them. Most repair shops would charge around $400 to $500 for the complete job.
Jul 09, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500 green screen then auto shutoff
I have the same tv and it did the same thing only now it has red hues all around the picture as well. The service guy told me it was the green tube and it would be about $500.00 to replace and may not fix the problem. What a p.o.s. I will not be guilty of buying any other Sony products from now on.
Jul 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Blue Screen and TV shuts off
Yes, you are correct on the phrasing. The CRT's were a common issue with these units and all three must be replaced as sooner or later the green will follow the other two CRT's. It was a great model and had a beautiful picture when operating normally. The CRT's are costing about 200 each for rebuild as the green and blue are mostly no longer available. Your repair cost are going to approach $1000.00 or more.
Mar 07, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
1,578 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
