Question about Acer NSK8458AN Keyboard
Keyboard The numbers to the right side of the keyboard do not work.All that works is the number locks button but the numbers will not. The ones above the letters work but not the ones on the right side of the keyboard.Thanks
  • tkilow Feb 17, 2008
    With my Acer Aspire 9500 notebook, have the same problem.
    With NumLock ON, the fkeys (figures) on the entire pad won't work.
    With NumLock OFF, all the keys are responding correctly.
    Have checked with resident Empowering technique, WinXP forum, Registry values are all ON and correct
  • 59 Answers
Have you tried using the numeric pad while the num lock key is turned on? if this doesnt resolve your problem, you're gonna need a replacement keyboard.
Posted on Nov 27, 2007
Num lock not working. number keypad not working. keyboard numbers are working.
Press the num lock button - usually the top left hand button on the keyboard numbers on right hand side of keyboard.
Mar 02, 2016 | Logitech Computers & Internet
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
My keyboard acts like the shift button is down but when i plug in a usb board it does the same thing.
Check if the CAPS LOCK is on. The key to toggle this is right above the left Shift key (next to A). There is usually a light with the indicator near the top of the keyboard (other lights for Num Lock and Scroll Lock).
You can tell if it is a Caps issue if the pressing the numbers above QWERTY give the numbers not !@ etc.
I hope this helps.
(you should turn off the computer and clean both keyboards. Sometimes, some dirt gets into the keyboard and triggers stray signals. There are a number of cleaning products that work; just make sure the keyboard is dry before turning the computer back on.)
Jul 14, 2010 | Toshiba Computers & Internet
I can get the numbers to work on my keyboard
None of them? Even the ones above the keys? I know that the ones on the right has to be turned on with the numb lock button.
May 21, 2010 | Computers & Internet
The number keys won't work, the ones located on the far right of the keyboard/calculator area....
  • Disconnect and reconnect your keyboard if it is external. Make sure that the connector is completely inserted into the port. (USB plugs fit into ports one way only, and won't allow you to make a connection if you try to connect them in upside-down.) Test the keyboard again.
  • Connect your keyboard to a different USB port.
  • Try a different keyboard on your computer if possible
If same problem occur even though the keyboard is connected in a different computer, then you need to contact a local repair tech and have it repaired.
Thank you!
Feb 08, 2010 | Dell 0Y3740 Keyboard
KEYBOARD NUMBERS
There should be a button called "numlock" which will enable to you use the keypad to the right of the keyboard, however, you don't need to "lock" the keyboard to use the numbers on the top row.
Apr 15, 2009 | Dell 0Y3740 Keyboard
Acer aspire 3003wcli keyboard stopped responding
You probably activated the "Num Lock" accidently. Just hold down the FN and look for the key that says "num lock" Now you should have your keyboard back and the numbers will just type when you hit the numbers key. I did this to myself yesterday!
Dec 06, 2008 | Computers & Internet
Keyboard
Click on start... and then on Run. Type access.cpl and then u will get accessibility options. Click on the Tab "Mouse". You will find a check box "Use mouse Key", uncheck it. It should work. Hope this helps you... :-)
Sep 04, 2008 | HP 386209-001 Keyboard
My numbers aren't working and my num loc is on
i got it!! hold down the 2 shift keys for a few seconds then bamm!!
Sep 08, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Acer NSK8458AN Keyboard Logo
371 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
