Question about Zenith H27E35DT 27" TV
Changing the default channel
I use several of these (H27E35D) in my hotel. I recently installed a sat. tv system and need to have the tv's set to channel 3 when turned on. Currently, when a guest turns on the tv, it is set, by default, to 50. Thank you in advance for your help.
J. Janoe
Comfort Inn Half Moon Bay
  • salamandre Dec 15, 2008
    I do actually have the same problem. I bought one of these tv sets in a liquidation sale from a closing hotel. I learned that it was initially settled "hotel mode" with special codes. I have used an universal remote but it has not settled the volume and the start problems which are still blocked. Would you know the codes to change this please. Thank you.
  • dexterrobyn Feb 15, 2009
    I have a zenith 27" television
    that is defaulted to channel 4 when turned on instead of channel 3. I
    want to set channel 3 as the default channel and I don't how. I also
    have a problem with the volumn. It has to be turned all the way up to
    be able to hear it. How can I reset the volumn to a normal setting?
I have a zenith 27" television that is defaulted to channel 4 when turned on instead of channel 3. I want to set channel 3 as the default channel and I don't how. I also have a problem with the volumn. It has to be turned all the way up to be able to hear it. How can I reset the volumn to a normal setting?
Posted on Oct 03, 2008
Hi i have a same problem with my TV and i solve this problem.
please fill free call me.
541-345-0579 ext.0
ask for kirit patel
Posted on Feb 20, 2009
  • 50 Answers
I believe you will have to have a tv tech. do this adj. , this is set in the factory service menu which he or she can access.
Posted on Nov 28, 2007
Zenith hotel TV turns itself on
Most of the Hotel sets use a different remote to enter the hidden menus--the system that set uses was likely on channel 81 and where it was used they needed it to come on at a specific time----going to get that specific service remote and info on how to change settings---this is the issue with buying these commercial sets.
Zenith is part of LG but different phone numbers etc
May 24, 2012 | Televison & Video
Default channel
What is the Brand name and model number to your TV?
May 18, 2012 | Televison & Video
I have a Phillips Tv That I have bought off of my employer (Hotel Industry) with the Model # 32HF7544D/27 and I'm unable to get it programmed to channel 73 which is what my Satalite company uses (
Hotel sets use a special remote with specific instructions--you need to get that remote and the instructions---hotel knows that..........
Apr 08, 2012 | Televison & Video
I recently got a Zenith H2522DT tv from a hotel that was upgrading all of the tvs to flat screen digital units.. There was no remote control with the tv. When I got the set home, I plugged it in and...
Possible that you got a bad unit. Is there any indicator light that flashes when you turn on the tv, feel free to send feed back good day and best regards.
Aug 14, 2011 | Televison & Video
Need hep programming a new uniden bcd396xt scanner
Unfortunately, you didn't specify if you needed assistance with programming digital or conventional radio systems.. but here is the info for conventional systems. Since a conventional system is really a collection of frequencies, the first thing you need to know is the frequency for each channel you want to program.
  1. Go to the Program System menu and choose New System .
  2. The scanner will prompt you for the System Type. Select Conventional .
  3. When the scanner prompts you confirm, tap YES .
  4. The scanner creates the system with a default name. Select Edit Name if you want to change it.
  5. If you need to change any of the system properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel group Each conventional system can contain up to 20 channel groups, and all systems must contain at least 1 channel group.
  1. On the Program System menu, select the system you just created.
  2. Go to the Edit Group menu and select New Group .
  3. If you need to change any of the channel group properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel in each group Each conventional system can contain up to 1000 channels in each group, and all groups must contain at least 1 channel.
  1. On the Edit Group menu, select the channel group you just created.
  2. Go to the Edit Channel menu and select New Channel .
  3. Input the frequency for this channel in MHz.
  4. If you need to change any of the channel properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Mar 04, 2011 | Uniden BCD396T Handheld Scanner
Unlockin all the channels
In order to get all the channels u have to have the original remote or a universal remote that has a menu button, an enter button, and directional pad (the directional pad cannot control the volume and channels it must be for navigating). push and hold the menu button, the menu will appear then disappear, once it disappears release the button and enter 9876 then press enter. a different menu will appear and it will b three black lines, one at the top of the screen, one in the middle and one at bottom. the middle line has 3 sections the first part is the item number the second part is the description and the last part is the on/off switch using either a 0 or 1. push down on the directional pad until u get to the 00 factory settings 0 and change the 0 to a 1 with the right button on the directional pad. then scroll up to 20 channel lock 0 (i think its 20, it may be like 22 but it is in the twenties for sure) and change the 0 to a 1. then go back down to the 00 factory settings and change the 1 back to 0 then turn the tv off. when u turn the tv back on it will either automatically ask u to auto tune or u will have to go to auto program to program the channels. there are like 80 different menu items, be sure not to mess with any other ones unless u know what ur doing, u could cause ur tv not to function properly or even be able to turn on.
this problem frustrated me greatly and im very happy to help whoever i can with the solution
Feb 07, 2009 | Zenith C27A24T 27" TV
Problem programming zenith tv
Same solution as before using the factory set-up menu changing the channel search parameters either CATV/Antennae
Jan 26, 2009 | Zenith B25A02Z TV
Zenith Concierge hotel tv wont work with my xbox 360
I doubt the TV even has a tuner if it is designed for a hotel. It may be a "dumb" receiver, nothing else. Do to channel 2 and then press the down arrow for channel, does it flip to 138 or AV1?
Mar 19, 2008 | Zenith C27A24T 27" TV
Trying to get channels above 42 to 99
I had the same problem the solution is you have to get institutional remote and reset the tv from commercial mode to consumer mode and then you will have access to the full menu. go to www.phillipsitv.com to get the directions. I actually asked a Hotel could I borrow their master remote used it and took it back and my tv works fine. Hope this helps.
Dec 01, 2007 | Philips Magnavox 27MS343S 27" TV
Sat/cbl button defaults to channel 17
maybe you programmed it with the wrong code sometimes that happen try the other codes that come with it make sure everything works before you think u got the right one.
Jul 01, 2007 | RCA RCR450 Remote Control
Zenith H27E35DT 27" TV Logo
553 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
