Question about Insignia NS- 27" TV27 TV
TV changing channels
Whenever I turn the TV on, it automatically starts going through the channels like one of the buttons is stuck. I took the batteries out of the remote to eliminate that possibility, and that didn't help. I then took the TV apart to examine the circuit board that holds the buttons on the front of the TV. I cleaned all the buttons with alcohol, cleaned connections, and cleaned the dust off everything else, just like I was taught in electronics school. That fixed the problem for 24 hours. I turned the TV off for the night, and the next morning, the problem returned. Any suggestions or other possibilities to try would be appreciated, because now I'm stumped! Hi, I have the same issue with my INSIGNIA TV too ... it automatically starts going through the channels like one of the Remote contorl buttons is stuck. I took the batteries out of the remote to eliminate that possibility, and that didn't help either !!! I need some help with this ... how do I replace the "Front Panel micro switches" ... I can really use any step by step instructions !!!
  • 1 more comment
  • fahadriz8 Dec 24, 2007
    Same problem. its very annoying and this tv is like 6 months old. wtf
  • Anonymous Feb 27, 2008
    same problem
  • Corey007 Feb 28, 2008
    Butal, I have the same problem but I thought it occurred when I was dusting and got an electric shock. I've tried everything as re-auto programing and changing the settings. Looks like Best Buy & Insignia is no help so I may try the "take the TV apart" method. But who knows, this TV is only like 4 months old!! Never, never buy Insignia!! ~ Corey from Canada
  • 88 Answers
Check channel up & down buttom if stuck up. if not, replace eeprom as possible. good luck!
Posted on Jun 13, 2008
2 Suggested Answers
  • 275 Answers
SOURCE: TV changing channels
You seemed to have good knowledge and sense. You did the right thing so far. But, since the problem has reappeared, I suggest that you - at one stroke, replace all the Front Panel micro switches - there will not be more than 6-8. Do not waste time identifying the faulty switc. After all it is only around half a buck a switch! And time is more valuable.
Posted on Oct 02, 2006
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
TV flips through channels at 2 channels per second.
It sounds like a button is stuck or bad. I would spray some electrical cleaner on the buttons 1st. If that don't work, the switch is probably bad.
Jul 23, 2010 | RCA F32645 32" TV
Impossible to change channels, turn TV on, Power and Opc blinking
go into programming mode and search for channels   it will do this automatically to find all antennae and all cable channels    if this is hooked up to a receiver box then only channel 3 will be found or used    also most tvs are computerized these days and at times it will need to 'rebooted'     unplug the power and wait 10 seconds and plug it in again    this may have to be done whenever you are locked out from changing channels or using the volume controls
Nov 05, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv changes channels when turned on.
Be sure your remote hasn't got a button stuck down which is changing channels. If not, take the batteries out of the remote. If this stops the channel changing there is probably some conductve material stuck across the circuit board
inside the remote. If this is the case you have to check inside the remote by openning it up.
Jan 28, 2009 | JVC AV-27530 27" TV
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
TV Changing Channels on It's Own
Are you changing channels with the remote? Try taking the battery out of the remote, its buttons might just be getting stuck? If, when changing the channel by hand, it persists, then it is an electrical problem, and you should contact LG to see about getting your unit replaced.
May 08, 2008 | LG 32LC7D Television
Channel changes automatically
There are a few things that can cause this. #1 most often cause is either something spilled on the channel button or something wrong with the bezel where the buttons are located causing the button to be pressed all the time. Check the buttons on the tv and make sure none of them are stuck. #2 is a bad button (switch). Replace the switch or the control board. #3 is a short on the wiring harness going from the switch to the mian board. Maybe it's squished against the frame somewhere. #4 would be a bad main board. You will likely have to take this unit to a service centre to have it looked at.
Apr 14, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Channel hopping
if the channel change is going up the channel up button on the set is stuck or shorted. if the channels go down then its the channel down button on the set that is stuck or shorted. also check with the manufacurer for software upgrades.
Mar 09, 2008 | Televison & Video
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Oct 01, 2006 | RCA F32649 32" TV
Insignia NS- 27" TV27 TV Logo
162 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
