SOURCE: controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
SOURCE: Need charging instructions for Air Hogs Havoc
1.Take out charging wires.
2.turn off your heli and insert charging socket into your heli's socket.
3.the charging green light will light up while charging.
4.charging complete, the green light will turn off.
5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
SOURCE: when i turn on the remote control, the red on/off
The batteries in the controller are nearly flat
SOURCE: Brookstone Silver Bullet Helicopter: When I
This is a battery fault, unfortunately pretty common. How old is this helicopter? It may still be under warranty.
Let me know, there is not really much of anything you can do on your end... you are doing everything correctly for sure.
Tim
SOURCE: right out of the box
did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
