Question about GE Profile Spectra JGBP90 Gas Kitchen Range
My clock stopped working on the display
I tried unplugging and replugging it in but the digital clock does not work all the other functions work
  • Breeeeeeeee Feb 13, 2008
    The clock stopped working on my GE Profile. We reset the circuit breaker to no avail. Then we followed the instructions for the blacked-out screen. All of the other functions work.
  • 22 Answers
The plug on your range may not be completely inserted into the outlet.
Clear all functions and see if the clock unfreezes
After all this, if the clock digits light up, and you still can't use any clock functions, it may be time for a new control panel.
Posted on Dec 03, 2007
  • Frank Reckitt Dec 03, 2007
    The clock may have been put in the black-out mode.
    12-Hour, 24-Hour or Clock Blackout
    Your control is set to use a 12-hour clock.
    If you would prefer to have a 24-hour
    military time clock or black out the clock
    display, follow the steps below.
    Touch the Bake and Broil Hi/Lo
    pads at the same time for 3 seconds
    until the display shows SF.
    Touch the Clock pad once. The display
    will show 12 hr. If this is the choice you
    want, touch the Start pad.
    Touch the Clock pad again to change
    to the 24-hour military time clock. The
    display will show 24 hr. If this is the choice
    you want, touch the Start pad.
    Touch the Clock pad again to black out the
    clock display. The display will show OFF. If
    this is the choice you want, touch the Start
    NOTE: If the clock is in the black-out mode,
    you will not be able to use the Delay Start
    Also see the special features of your oven control section of the user manual.
Sharp Carousel II (R-9H83) loses clock, digital display dims
I think there are some electrolytic capacitors in the power supply to be replaced.Because there are relatively few, it would be good to change them all for more safety
Jun 02, 2014 | Microwave Ovens
Sharp carousel microwave
You may need your main control panel repaired
Oct 21, 2013 | Microwave Ovens
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The alarm display in the lower right corner on model #RC40-A keeps blinking and will not stop. This happens with both wake 1 and wake 2 options. I fixed it once by unplugging the unit but it this did not...
Just reinstall the battries and adjust the time once again.
Battery back-up operation
* This clock radio is equipped with
a memory holding system that can
be powered with 2 "AA" batteries
(included). The power failure
protection circuit will not operate
unless battery is installed.
* When normal household power
is interrupted, or AC line cord
is unplugged, the batteries will
power the clock radio to keep
track of time and alarm settings
programmed into memory.
* When the battery backup functions,
the digital display will not light,
however, the function of alarm
still occurs during the power
interruption if remaining battery
power is adequate.
* Normal operation will resume after
AC power is restored so you will not
have to reset the time or the alarm
To install batteries:
1* Remove battery compartment door
(located at the bottom of the radio)
by applying thumb pressure to the
tab on battery door and then lift
the door out and off the cabinet
2* Insert 2 AA batteries (included).
3* Replace the compartment door
Replace batteries every year.
Power is fed to the unit even
when it is not functioning. To
cut the power supply off, the
power cable must be unplugged
Jul 10, 2011 | RCA Rc40 Clock Radio
GE spectra JBP66 electric oven that displays the F2
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
Dec 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
Microwave panasonic in demonstrateion mode and won't heat remove from lthis mode
First try hitting the Clock pad three times.
Or if it has a Function pad, hit that, then follow the prompts. On some models, it's Function > 0 > 2.
If this is a model NE1257 (the model under which you posted) then it doesn't have a Function pad.
If none of this works, I'd suggest unplugging it for a few seconds or so, then trying again.
If none of this works, then please reply back with your brand and full model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 20, 2008 | Panasonic Pro NE1257 Microwave Oven
Display area and clock will not re-set on Electric Range
on any appliances need to know the model and serial num some problems are model specific
Dec 28, 2007 | Kitchen Ranges
Projection display
I had the some problem a few days ago when we had a power outage during the night. Try unplugging it, leave it unplugged for about 10-20 seconds, and replug it back in. Reset your time on the clock and it should work then.
Nov 08, 2007 | Homedics Sound Spa Premier SS-5000 Clock...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
392 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
