Question about Brother MFC-8440 All-In-One Laser Printer
Button stuck down
How do you remove the operator panel to get to the buttons. I see no simple method
  • Brother Master
  • 1,113 Answers
There is no simple method, doc feed gota come off then scanner. then operations panel
Posted on Dec 08, 2007
Hp 3050 power button quit functioning; cannot press it down. Is this self reparable?
To fix the power button, which is stuck down or does not spring back up....remove the panel which has the all the buttons and the power button, the panel does not have any screws to remove, you got the pull it out from the lower side and move slowly towards the top. Once the panel is free, you will see that the power button is connected with a small plastic connector which would be broken, fix the broken piece or get a new piece and the problem is fixed........
Nov 19, 2011 | HP LaserJet 3050 All-In-One Printer
I want to remove memory card from nokia n81 8gb supported cellphone
it doesn't have an external memory card that you can remove... it does have an internal though but removing it might completely break the phone...
you can refer to the link to checkon the complete specification of you phone: http://www.gsmarena.com/nokia_n81_8gb-2085.php
but you can reformat the memory to factory settings though:
reformatting NOKIA N Series phone:
simple ways to format your Nokia NSeries cell phones.
(Please do remember that some of the steps below will clean up all your data in phone so remember to make up backup copy of it. Otherwise you will end up loosing them forever.)
Method:1
1. Switch off the phone.
2. Hold down the following three buttons: Green (call answer button, * button, and '3? button. 3. While holding these buttons, press the power button and switch on the phone. 4. When the message 'Formatting' appears on the screen, release all of the buttons.
Method: 2 ( Hard Format)
2. Hold down *#7370# button. 3. While holding these buttons, press the power button and switch on the phone. 4. When the message 'Formatting' appears on the screen, release all of the buttons.
Method: 3 Soft Reset
2. Hold down *#7780# button. 3. While holding these buttons, press the power button and switch on the phone. 4. When the message 'Formatting' appears on the screen, release all of the buttons.
just leave a comment if you have additional queries...
---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"----
Thank you for choosing fixya
Roger
Sep 06, 2011 | Nokia N81 Smartphone
Menu dialogue box continues to pop up every few minutes
Had the same problem with mine. Annoying as can be. Then again, I got it free because of that....
The solution is actually very simple: take a knife and remove the menu button, take a pliers and remove the little black button. Done. (If you can, get the settings to be acceptable for your use first!)
Down side is I haven't found a way to adjust the settings after that, but you can still switch between HDMI, VGA, and DVI fine.
Probably more technical fixes out there, but it works quickly and it's free to do in less that 2 minutes.
Aug 18, 2011 | ASUS VK222H Monitor
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
How to clear timer mode on air conditioner
Very simple. Remove batteries from remote and after sometimes replace batteries and use the remote.
One more method, press timer button and then press < or > till it comes to 00.00. And then press set button.
Another method, press timer on and then press cancel button. Hope, helpful?
Feb 11, 2011 | Fujitsu 36CS Air Conditioner
I cannot adjust the stations, switch to CD or Radio mode or anything as it's stuck on one XM station. The presets won't even change the station. I noticed the disp/title button seems to be sort of stuck...
Yes, Disp/Title stuck button could be cause of no other button function because one button can be operated at one time in these units and if any button stuck for some reason, other buttons would be inoperative.
Take off front panel by pressing eject button at lower left side and try to release Disp/Title button with finger nail, if that does not help then remove screws at back of front panel, take off back cover then take out circuit board carefully and press gently, little bit Disp/Title knob from inside front panel to send it back in its original position then put circuit board and put back cover and tight screws.
Check Disp/ Title button gives little click sound while pressing as other buttons give that sound. Put front panel in unit and check.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 13, 2010 | Alpine CDA-9820XM CD Player
How to remove deep freeze on my computer?
simple. go to control panel. here click on "Add or remove programs" button. now list will appear of installed software. click on remove button for that software you want to uninstall.
May 19, 2010 | Computers & Internet
B6300n Printer: Hello i have oki B6300 printer and its showing e...
Step#1: Turn on power, press the left and right arrow buttonssimultaneously,, release both buttons then press the online button to get intothe DIAG. Menu Step#2: Press the down arrow button twice the operator panel willdisplay Diag.Menu Adjustment Step#3: Press the right arrow button the operator panel will displayAdjustment DC131 NVM R/W Step#4: Press the down arrow button the operator panel will readAdjustment DC132 Set Serial Step#5: Press the right button the operator panel will read SerialNumber XXX Record this serial number SYS1: XXXXXX Step#6: Press the Down Button 24 times. The operator panel should readDC132 Set Serial Target PWA SYS1 Step#7: Press the Select button Operator display Enter Serial No. 000000 Enter the serial number thatyou recorded in step#5 Action: Please reference this photo as a reference for the up, down, left, andright keys, when performing the following procedure. Step#1: Turn on power, press the left and right arrow buttonssimultaneously,, release both buttons then press the online button to get intothe DIAG. Menu Step#2: Press the down arrow button twice the operator panel willdisplay Diag.Menu Adjustment Step#3: Press the right arrow button the operator panel will displayAdjustment DC131 NVM R/W Step#4: Press the down arrow button the operator panel will readAdjustment DC132 Set Serial Step#5: Press the right button the operator panel will read SerialNumber XXX Record this serial number SYS1: XXXXXX Step#6: Press the Down Button 24 times. The operator panel should readDC132 Set Serial Target PWA SYS1 Step#7: Press the Select button Operator display Enter Serial No. 000000 Enter the serial number thatyou recorded in step#5 Step #8: Press the select button operator display Re- Enter Serialnumber XXXXXX enter the serial number from step #5 again. Press Select Step #9: The operator panel will displa Note: The Operator will now display "DC132 Set Serial NumberCompleted". Step #10: Press the left and right arrow button, release both buttonsthen press on-line button to get into the Diag MODE Step #11: The operator panel will display Exit Diagnostics Incomplete Exit Step#12: Press the down arrow button the operator panel will read ExitDiagnostics Complete Exit Step #13: Press the select button the operator panel reads Complete Exit If OK Press SEL Step #14: Press the select button the operator will read Please Reboot Printer (103-208) --Power the unit OFF Wait three seconds then power the unit back ON.Operation is now complete.--
May 17, 2010 | OKI B6300n Printer
I put a mini disk in my macbook not knowing it would not load - now it will not eject
Be persistant-shake the F&^% out of it. Face it with the disk slot facing down and just shake it a few times. Worked for me.
Sep 15, 2009 | Computers & Internet
GHW9100LQ1 machine stuck in control lock mode
Press and hold the "END OF CYCLE SIGNAL" button for three seconds and it will unlock the control panel. At least, I think that is the button for the Whirlpool Duet. If you look closely at the front panel, it will clearly state "Press and Hold for 3 Seconds to Lock" on one of the panel buttons (should be all the way to the RIGHT HAND SIDE). This button is designed as a safety feature to prevent small children from being able to operate the washer and inadverntenty getting locked inside the unit. If holding the button fails, unplug the washer for at least 30 minutes to reset the computer. I hope this helps.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Brother MFC-8440 All-In-One Laser Printer Logo
43 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
