LG Incite  Cell Phone Logo
Posted on Aug 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My phone stopped ringing or making any sounds. It shows that there is a call comin through but the ringer is silent and I cannot hear the caller either. Any help?
Anonymous
Level 2:
  • Expert 87 Answers
  • Posted on Aug 08, 2009
Anonymous
Expert
Level 2:
Answers
87
Questions
0
Helped
30551
Points
218
Either u set the ringer off or might their be some problem with ur speaker
2helpful
Blu Advance 5.0 ringer sounds won't work.
Hi if u have silent mode turned on u won't hear a sample ring tone check where u adjust volumes there should b a silent mode on or off..Cheers..
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
3helpful
I have the uniden D1688 phone and the ringer will not ring
I went into the menu and turned off the personal ringer. And that worked for me. When you set up a caller into the phone book it ask you for a personal ring tone. If none is selected none will ring.
1helpful
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
2answers
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
I have the new nokie 6700 slide and the sound just stopped working, it hasnt been wet or anything it just stopped working i cant even hear it ring. please help
Make sure that the incoming call alert (under profile settings) is "NOT OFF"...
Make sure the profile is not in silent mode...
If everything is ok, then probably it may be the ringer might have gone bad... You can take it back to any Nokia care and ask them to check the status of ringer...
Set call rings
From the manual:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press mute/menu OK button to enter the menu. SET RINGER LEVEL 5 shows in the display.
3. Use the CALLER ID-VOLUME ( 6 or 5) button to scroll to your selection. LEVEL 5 is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
Unknown callers wont ring
maybe check on the ringer type for restricted numbers- you can change ringers by all calls, restricted calls, and caller id numbers. your incoming restricted numbers is probably set at none or silent
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
