Projection TV TV  cannot  turn  on  look  like  no  power.
  • 3 more comments
  • 5007 Dec 05, 2007
    Fuse is fine and nothing look burn.
    More information I have When I plug TV
    I will see the light on diode (It's look
    like glass head) about 5 - 6 position but
    just short time (2-4 sec)the light it all gone.
  • 5007 Dec 05, 2007
    Model Hitachi 50SBX70B 1998 PROJECTION COLOR TV
  • 5007 Dec 05, 2007
    Before contact with you I already clean and check burning and change new Fuse.
  • 5007 Dec 05, 2007
    I am mechanical I know very little about
    electrical but I try to fix by my self
    because that TV somebody give it to me and
    I don't have alot money.
    How to check horz.transistor and How many
    transistor have to check
  • 5007 Dec 07, 2007
    Thank you so much.
    It's over my skill I have to let fixer
    do it.
    President:
  • 4,402 Answers
There are so many things that will cause no power, check fuses
and anything that looks burnt.
is about the only thing i can recommend
Posted on Dec 05, 2007
  • 3 more comments
  • Cary Farah
    Cary Farah Dec 05, 2007
    Do you have make and model number?
  • Cary Farah
    I don't know what your technical abilities are, first check horz. transistor if shorted, then i would turn the board over and see if there is any cold solder joints or cracks in the solder connections if everything is still ok next then i would replace the convergence amp IC's
    this doesn't always fix it.
    heres some likes on how to replace them and i would replace both.
    http://cmpalmer.blogspot.com/2006/11/fix...
    http://home.earthlink.net/~oleg.filippov...
  • Cary Farah
    theres only one it should be on a heat sink and it should be very large with three legs coming out also should be close to the flybak transformer red think wire connecting to the pic. tubes.
    you have to unsolder it and the check it with a multimeter, take one lag and put the meter on that one then check the other legs with the other meters probe do this for all three legs and then do it in the opposite direction using the reverse probe of the meter
  • Cary Farah
    that should say red thick wires to pic tubes
  • Cary Farah
    Cary Farah Dec 08, 2007
    please rank me 4 would be nice
The red power light comes on but nothing else works on my hitachi 53FDX01B PROJECTION TV
silly question but have you tried turning it on with the remote. if a tv has been turned off by remote and then power goes, turning it on by the tv switch will put the tv back in stand-by mode and you need to use remote.
just a suggestion.
Dec 13, 2013 | Hitachi 53FDX01B 53" Rear Projection...
I have a 42 inch toshiba 720 dlp hdtv, and it wont turn on. i press power to turn it on, it tries to fire up, the lights under power and lamp start blinkin green, and then orange, but then just stops and...
Tv "LAMP" LED light indication is blinking or lite up?The tv projection lamp insisde this tv now like 1 1/2 or 2 years already?Tv on and used daily like 4 or 5 hours everydays?Yes.The tv projection lamp life are over.The tv require a new tv projection lamp.Still have problems after this the tv board that call the Ballast board it is dead too,must require changing too.The Ballast board only job are to help to fire up the tv projection lamp and keep it lit.
May 01, 2011 | Toshiba 46H84 46" Rear Projection...
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Power problem with Zenith D56W25 56 in. Rear Projection Televisi
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
Apr 18, 2010 | Zenith D56W25 56" Rear Projection...
Turn on tv and standby light flashes 6 times
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue.
Follow the steps below to perform a power reset:
  1. Turn off the television.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Oct 16, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Projection tv won't turn on
Ur DM power board is dead,have burn capacitors,check all the puff up capacitors,and replace it.
Sep 22, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My panasonic rear projection tv will not power on and no lights turn on. Any suggestions?
Please plug TV in another power source and turn it ON,
if still does not turn ON, unplug AC wire of TV, take off back cover and follow AC cord f TV that will take you in power supply board, find fuse nearby and check is it blew off? if yes, replace it with same ratings written on it.
Plug TV in AC wall socket and turn ON, if fuse blow again that means power supply section in TV got problem and need qualified tech to find out and replace components or power board.
Thanks.
Sep 18, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Cannot turn on TVour TV model is 60SBX78B, Hitachi project TV
If your remotes are out of the room and you try to turn and it still wont come as it should ,then You have a problem with the power switch or the supply, your unit needs to go to the shop . Sorry. DFD
Apr 11, 2009 | Televison & Video
Televison & Video Logo
220 people viewed this question
Top Televison & Video Experts
