Question about Measuring Tools & Sensors
I have a HVR505G, it spins up but the green laser takes about an hour or more to light
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
My green laser 200mW do not work
I know one thing about green lasers. They go on and on and they are visible for miles if you could see that far. I only know what a green gun laser can do. Only draw back is they are traceable. So if you want to have something you can see well, go green. Buy so rechargeable batteries to save money and you'll be fine not sure if that helps any, but I just now the power of green
May 20, 2014 | Cst Stanley Fatmax 77 224 RL350 Hz/Vert....
When i insert a disk it does not spin to read it and i hear 3 knocking sounds
The motor for your xbox has been damaged, so it is unable to spin the disk to read it, the knocking sound is the motor trying to work but failing. You will have to speak with a technician to get it fixed and/or replaced.
Mar 01, 2011 | Microsoft Xbox Console
Indesit WIXL143 stops part way through program
Technical Jargon error F02 Motor jammed / tacho detached: check motor & module connections
Basically the strong possibility of a faulty Motor
Mar 21, 2010 | Washing Machines
Yellow / green light will not go off when charging
Its likely the batteries will take at least several hours to fully charge, if not more. NiCad batteries are slow charging and usually need 4-6 hours for a full charge. Keep them on longer or even overnight but make sure you remove them in the morning. You will probably find the light turns green after 4-6 hours of charging. If lights stay yellow and green after 12 hours of charging, it may indicate a fault in the battery itself where it will not accept a charge.
Jun 18, 2009 | Ryobi Multi-Volt Battery Charger
Pioneer PD-F505 Cd Player - The player picks up the CD and it starts spinning. A high pitch squeel sound starts as soon as the CD starts to spin. The unit spins the CD for about two to three seconds and...
Sound like laser assy defected in any case you need a Technician from Pioneer or they are trained by Pioneer is very complicated to remove the laser and replace it you need an osilloscope to aligment a new laser and special disc to do that. It might not worth to repair it, the laser itself a bout $110.00 Aus
Nov 30, 2008 | Pioneer Audio Players & Recorders
PS2 Slimline Dies
did you try cleaning the ps2 take it apart and clean it
Jan 14, 2008 | Sony PlayStation 2 (PS2) Compact System...
Measuring Tools & Sensors Logo
24 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
