Question about Samsung Washing Machines
I just replaced the support flange in my Samsung washer. When I place it in the first part of the tube with the bearing, it spins freely and smoothly. But when I place the second half of the tube on and tighten it together, the drum seem to be too big for the tube and is not spinning freely.
SOURCE:
catriver
  • 878 Answers
SOURCE: Whirlpool Duet Washer
dc, drop the front bottom panel and make sure the 4 shocks are connected to the tub and bottom panel, then check the front and rear counterweights. They may have loosened up. Remove back panel or top to check the rear counterweight. The top removes by removing the 3 screws in back and it slides off. If all this checks ok then I would suspect the rear bearing wollowing out. Catriver..post back.
Posted on Apr 02, 2007
  • 1294 Answers
SOURCE: Shocks broke, now drums spins freely
What you need to check thoroughly are the belt & the 2 shocks (dampers). The dampers should be replaced & fitted tightly, broader ends fitted below.
Posted on Mar 17, 2008
  • 574 Answers
SOURCE: Replaced broken washer belt, but drum still won't spin.
you may have a bad bearing in a pulley,could be motor coupling. Take belt off and spin motor shaft and pulley both ways if it's free, then its more than likely not the motor. Now spin the drum with belt off and see if it does the same as with the belt on if it does it has to be a bad bearing or coupling to the drum. hope this helps
Posted on Aug 24, 2009
Testimonial: "Thanks for your input. I'll look into it. If the problem is a bearing, is it an easy fix or should I start saving for a new washer?"
heatman101
  • 43501 Answers
SOURCE: Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Apr 15, 2010
Testimonial: "Ok that was my guess. That answer was lightning fast. Thx you very much. Will remove it. test it and post if the problem is fix. Thx again"
blueextc3221
  • 15935 Answers
SOURCE: how to remove the spin tube t bearing
Rear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud "rumbling" type noise during the spin cycle, excessively vibrates, or won't spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven't done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o'clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o'clock position.
- With both hands gradually work your way around to the 4 and 8 o'clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
Error code E58
If you have a front-load washer that was manufactured by Frigidaire, the E58 error indicates high current on the motor. This could mean that the motor is bad, the bearings that the tub spins on are bad, or a problem with the speed control board. To test this, you'll need to access the motor and tub area of the washer. Unplug the power before opening the washer. Take the belt off the motor pulley and check if it spins freely. If it doesn't, then replace the drive motor. If it does spin freely, check if the large pulley on the tub spins freely. If that doesn't rotate, you'll need to replace the outer tub and spin basket in order to replace the failed bearings. If the pulley rotates easily, you'll need to check the motor windings. If the resistance is between 4-6 Ohms, the speed control board is probably faulty. If the resistance is not in the correct range, the motor is bad and needs to be replaced.
A Frigidaire washer technical data sheet is available here: http://manuals.frigidaire.com/prodinfo_pdf/webster/134542000.pdf .
If your washer is under warranty, contact the manufacturer. If you add a comment with the model number of your washer, I may be able to provide a source for the parts.
I hope this helps.
Apr 27, 2016 | Washing Machines
Samsung WA422PRHDWR/AA not draining
i had a the same issue and my fix ended up being the leveling sensor. repair man said if you tilt your washer to far in any direction it throws it off...hmmm
Dec 27, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
I have a gleh1642fs4 model that drum will not spin?
I have a GLEH16242 Frigidaire/Electrolux stacking washer/dryer. The main bearing went out on the washer. I did the expensive fix of replacing the outer drum/bearing assembly in hope of nothing going wrong. Everything went together well, but now it won't go into high speed spin. It does if I have no clothes in it, but as soon as I introduce clothes it only does the 'medium spin' but never advances to the high. I've changed shocks, confirmed the door switch is working properly and double checked level. Even placed it on a big thick sheet of plywood in hops of stabilizing it more. It does have a wobble to it when it starts spinning, but when it kicks into medium spin, is smooths out.
Oct 11, 2013 | Frigidaire GLEH1642DS Front Load Stacked...
My kenmore front loading washer is screeching during spin cycle and seems to be spinning poorly at times. what is going on?
The wash drum should spin smoothly by hand without much noise. It is supported with two sets of ball bearings. If the water seal fails, water starts to leak into the inner bearing and they start to rust causing a loud noise especially during the spin cycle. The only way to fix it is to replace the bearings and seal. It a big and expensive job to replace the bearings since you literally need to take your washer apart to get to the bearings. Sorry.
Oct 07, 2010 | Kenmore 44102 Front Load Washer
Rattling sound and vibration while spinning
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. The other possibility can be faulty motor causing the bearing to rattle/. Check out both the motor as well as spin bearing. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Samsung SW62ASP Top Load Washer
Makita 9523NB angle grinder is suddenly suffering vibration and some emitted from motor before stopping. I have replaced brushes (original brushes were hardly worn) as 1 of the springs had little tension...
You say it spins freely but is it smooth. If not it could be one or both of the bearings the armature spins on. More likely than not you have one or more fan blades broke or missing. Not much weight by themselves but at the speed these things spin the more blades broke off, the worse the vibration. You have to romove the brushes, take off the gear housing and remove the armature to check both the bearings and fan.
Aug 03, 2010 | Makita Saws
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Whirlpool Duet washer...after problem with it getting out of balance due to not draining and trying to spin with a heavy load, I have since noticed if I place my hand inside the tub..it will spin freely...
Your original problem is likely to have damaged the bearings and the spin tub shaft... the shocks can fail, but that would not affect the fitment of the shaft and bearings.
Apr 21, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
