Question about Kenwood TK-3100K2 (2 Channels) 2-Way Radio
Tk-3100 how can i change the code on the radion it has 2 channels and then it also has codes?
  • wfgh Feb 20, 2009
    Well, Not the SAME problem. Mine is -- no matter how you program it, both channels stay on 462.675. I programmed each channed a dozen times, with the radio beeps telling me it was set up and ready to go, but with no avail. When you turn it off, hold PTT and turn on, it will give you the beeps you programmed each channel,fro one to eight,
    No Good !
    Any Ideas !
    Vernon wfgh907@radio.fm
Hi Tucaraca.
With the radio OFF, switch to CHANNEL 1, press the SQUELCH and the PTT at the same time. Turn ON the power switch while keeping the PTT and SQUELCH until the LED indicator turns RED.
Release the buttons and then press the PTT to CHANGE the FREQUENCY.
Press the PTT once each time until you get to the right frequency you desire. The 8 standard frequencies are as follows: 464.500, 464.5500, 467.7625, 467.8125, 467.8500, 467.8750,467.9000 and 467.9250 MHz. Once you get to the frequency you use, wait a few seconds and listen for the confirmation tone. Each frequency has a different confirmation tone so take note in case you need to program a second radio.
After you hear the confirmation tone, press the SQUELCH to confirm, and then press the SQUELCH again to lock the new frequency. Wait until the LED turns off, then switch off your radio.
Same procedure for CHANNEL 2.
WARNING: You must be legally licensed to use any frequency on any PLMRS such as the TK-3100 series. You must also apply for FREQUENCY COORDINATION and submit FCC form 601. FCC can impose steep fines and imprisonment if they catch anyone using an unlicensed radio on a controlled frequency. Visit FCC.GOV for more information.
Posted on Dec 24, 2007
I bought additional kenwood tk 2100 radios and they are not sending the signal to my existingones. The fcc numbers and interior tk numbers are the same. How to I get them on the same frequency.
To change the channel frequencies on your TK2100, simply press and hold the PTT switch ("talk button") and Monitor key, then turn the power on. Now press the PTT switch again. The light should change from orange to red and a beep should sound. Next, adjust the channel switch to the channel you wish to program. Now simply press the PTT button to choose between 4 to 8 possible frequencies, depending on your model.
You can find the manual and frequency graphs here: http://www.heritageresale.com/documents/TK2100OwnersManual.pdf
Aug 26, 2011 | Kenwood...
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
I have the radion shack hdtv remote. Cat no
Download the manual and codes from here
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/15135-manual.zip&area=other
Here is how to set the code...
1. Turn TV on
2. Press TV button on remote
3. Hold P button on remote until LED blinks twice
4. Enter the first 5 digit code for Magnavox TV's
5. Press Power button - TV should turn off. If TV doesn't turn off repeat steps 2-5 with the next 5 digit code, until either TV goes off or run out of codes.
6. If out of codes use searching for code method below...
TV codes for Magnavox
10047, 11454, 10054, 10154, 10000, 10250, 10051, 10180, 10060, 10030, 10171, 10092, 10706, 11913, 11904, 11755, 10019, 11365, 11254, 10802, 10386, 10282, 10020, 10187, 10186, 10024, 10179, 10096
Searching for code
1. Turn on TV.
3. Press and hold P button until LED blinks twice
4. Enter code 991 on remote - LED blinks twice
5. Press 1 - Device key blinks twice
6. Press Power button once
7. Press and release CH+ key until TV turns off.
At this point in the manual, the manual is only correct depending on what type of TV you have.
In the manual if you press the Power on button the TV should turn itself back on, the fail to state that not all TV's turn on by the power button, the majority now are triggered to turn on, on channel change, however you can't use channel change here to check it as you'll go to the next code... here is my solution...
8. Turn TV back on either using original TV remote, or buttons on front (most TV's if you change channels they come back out of standby mode, very few now turn on by pressing the power button).
9. Press Power button on remote - TV should turn itself off again.
10. Press P button on remote to lock in that code.
If the device does not turn off press CH- to go back through the codes, press and release P button when TV turns off.
Finding code
If you used the search function you might want to know what code it's using. To do this follow these instructions...
1. Press TV button
2. Press and hold P until LED blinks twice
3. Enter 990 and LED blinks twice
4. Press 1 and count number of times LED blinks this is the first digit of your code (e.g. 1 blink = 1, 2 blinks = 2, etc).
5. Repeat step 4 pressing buttons 2 - 5 for the other digits (e.g. for the second digit press 2 count number of blinks.. etc)
At this point the manual doesn't tell you how to get out of this mode, I presume pressing any other button on the remote other than 1-5 will take you out of this mode, either that or leaving the remote alone for 5 minutes.
Nov 08, 2009 | Radio Shack (15-2147) Remote Control
Unable to connect to my works existing network of tk-3100 w/tk380
The pl tones are wrong. It will not work unless you know the PL or DPL.
Jul 05, 2009 | Radio Communications
Need manual for kenwood tk-270 transceiver does any one no were i
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor KeyOff = off1 = Monitor momentary2 = Monitor Lock3 = Squelch off momentary 2. Scan KeyOff = offCo = carrier operateTo = Time operate 3. Dial KeyOff = offOn = enable 4. TA keyTA = talkaroundRV = ReverseOff 5. Lo KeyOnOff 6. PriorityNone1 = fixed2 = selected 7. Fixed Priority ChannelTurn selector to channel 8. Look back time ATurn selector to time in seconds 9. Look back time BTurn selector to time in seconds 10. Revert Channel1 = Selected2 = Last Call3 = Last used4 = Selected + Talkback5 = Priority6 = Priority + Talkback 11. Tx Dwell timeTurn selector to time in seconds 12. Drop out delayTurn selector to time in seconds 13. Time out timerTurn selector to time in seconds 14. Tot Pre-alertTurn selector to time in seconds 15. Tot Rekey timeTurn selector to time in seconds 16. Tot reset timeTurn selector to time in seconds
Apr 27, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
Compatability
The Kenwood TK-3200LU15 is the 2Watt replacment model for the TK-3101. the TK-3202 or TK-3203 are 4 watt models that can be used. Although, they have to be programmed with the frequencies and codes you are using. The TK3101 came with defualt GMRS/FRS frequencies.
HiTechWireless.com
Jan 14, 2009 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
TK 3100, No communication, codes check out OK
Try one of the side buttons to see if you can hear squelch noise. If so, hold it in then talk on an existing unit. If you can hear it, then the squelch code is wrong, if you still can't hear it, then the frequency is wrong or the unit is defective.
Geno
Jan 16, 2008 | Kenwood TK-3100K2 (2 Channels) 2-Way Radio
Kenwood TK-3100K2 (2 Channels) 2-Way Radio Logo
727 people viewed this question
Top Kenwood Radio Communications Experts
Jaime Hernandez
michael galang
Steve
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
